Topic: Servo motor problem with arduino (Read 1 time) previous topic - next topic
anjali_yadav
Mar 01, 2015, 08:58 am Last Edit: Mar 01, 2015, 09:00 am by anjali_yadav
i m having problem with servo motor with arduino.I m using mg995 servo motor. when i m increasing the given angle of servo by 10-10degree( example - 0 , 10,20...180) thn it's working nice but when i gave angle like45 degree when it is at 0 degree, thn it start giving problem.
it feel like motor gets confuse where it should move to get that 45 degree
in short : 1) it was at initial 0 degree 2) i gave input serial 120 degree
3) thn it move bit clock wise diction
thn it stooped
4) after sometime , it
move anti click wise 120 degree
Robin2
#1
Mar 01, 2015, 11:27 am Last Edit: Mar 01, 2015, 11:28 am by Robin2
You will have to post your code if you want advice about why your code is not doing what you want.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
TomGeorge
#2
Mar 01, 2015, 01:45 pm Last Edit: Mar 01, 2015, 01:46 pm by TomGeorge
How are you powering your servo, do not use the 5V pin on the controller, it cannot supply yhe load demanded by the servo?
The servo needs it own power supply.
Can you please post a copy of your sketch, using code tags?
Can you please post a copy of your circuit, in CAD or a picture of a hand drawn circuit in jpg, png or pdf?
Tom...... :)
Everything runs on smoke, let the smoke out, it stops running....
anjali_yadav
 :-X my code is this :
#include <Servo.h>
Servo servo;
int servoPin = 9;
servo.attach(servoPin);
servo.write(0);
Serial.println("Prog Intiallized Successfully...");
  if(Serial.available()) {
    Serial.println("Data received..");
    int angle = Serial.parseInt();
    Serial.println(angle);
    servo.write(angle);
    delay(15);
    Serial.println("Exiting If..");
anjali_yadav
i m giving  it 6 v external supply
Robin2
Your code works pefectly on my Uno
...R
zoomkat
Make sure the arduino ground and servo power supply grounds are connected together.
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
anjali_yadav
which servo motor you r using and what current and voltage you are giving?
anjali_yadav
I m using mg995 servo motor  and giving 6 v ,500mA
TomGeorge
Can you please post a picture of your project.
Tom... :)
anjali_yadav
This the circuit diagram which i m using,
Robin2
500mA may not be enough current for your servo. Try a pack of 4 AA NiMh batteries and see if that solves the problem.
I just tried the code with a very small servo to ensure there is nothing wrong with your code.
...R
anjali_yadav
how much current it supplies 4 AA NiMh batteries  bcz i need to run 4 servo motor
anjali_yadav
700 mA will be enough for 1 servo or should i give more bcz according to my calculation(my project) it have to give around 9 kg-cm toque
