Guten Abend,
ich wollte gerade mal das Bsp-Sketch "udpntpclient" laden...
Normalerweise sollte doch im serialmonitor die zeit angezeigt werden oder?
Bei mir kommt nix...
Habe andere Sketche probiert, die auch im Serialmonitor schreiben, da gehts.
Meine baudrate is 9600
Habe Arduino 0022 aufm PC.
Mein Borad ist ein Mega 2560.
Muss man noch was beachten oder wo liegt hier der Hund begraben?
Danke für eure Hilfe.
Hier der Code aus dem BspSketch
Udp NTP Client
Get the time from a Network Time Protocol (NTP) time server
Demonstrates use of UDP sendPacket and ReceivePacket
For more on NTP time servers and the messages needed to communicate with them,
see http://en.wikipedia.org/wiki/Network_Time_Protocol
created 4 Sep 2010
by Michael Margolis
modified 17 Sep 2010
by Tom Igoe
This code is in the public domain.
#include <SPI.h>
#include <Ethernet.h>
#include <Udp.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = {
192,168,1,177 };
unsigned int localPort = 8888; // local port to listen for UDP packets
byte timeServer[] = {
192, 43, 244, 18}; // time.nist.gov NTP server
const int NTP_PACKET_SIZE= 48; // NTP time stamp is in the first 48 bytes of the message
byte packetBuffer[ NTP_PACKET_SIZE]; //buffer to hold incoming and outgoing packets
// start Ethernet and UDP
Ethernet.begin(mac,ip);
Udp.begin(localPort);
sendNTPpacket(timeServer); // send an NTP packet to a time server
// wait to see if a reply is available
if ( Udp.available() ) {
Udp.readPacket(packetBuffer,NTP_PACKET_SIZE); // read the packet into the buffer
//the timestamp starts at byte 40 of the received packet and is four bytes,
// or two words, long. First, esxtract the two words:
unsigned long highWord = word(packetBuffer[40], packetBuffer[41]);
unsigned long lowWord = word(packetBuffer[42], packetBuffer[43]);
// combine the four bytes (two words) into a long integer
// this is NTP time (seconds since Jan 1 1900):
unsigned long secsSince1900 = highWord << 16 | lowWord;
Serial.print("Seconds since Jan 1 1900 = " );
Serial.println(secsSince1900);
// now convert NTP time into everyday time:
Serial.print("Unix time = ");
// Unix time starts on Jan 1 1970. In seconds, that's 2208988800:
const unsigned long seventyYears = 2208988800UL;
// subtract seventy years:
unsigned long epoch = secsSince1900 - seventyYears;
// print Unix time:
Serial.println(epoch);
// print the hour, minute and second:
Serial.print("The UTC time is "); // UTC is the time at Greenwich Meridian (GMT)
Serial.print((epoch % 86400L) / 3600); // print the hour (86400 equals secs per day)
Serial.print(':');
Serial.print((epoch % 3600) / 60); // print the minute (3600 equals secs per minute)
Serial.print(':');
Serial.println(epoch %60); // print the second
// wait ten seconds before asking for the time again
delay(10000);
// send an NTP request to the time server at the given address
unsigned long sendNTPpacket(byte *address)
// set all bytes in the buffer to 0
memset(packetBuffer, 0, NTP_PACKET_SIZE);
// Initialize values needed to form NTP request
// (see URL above for details on the packets)
packetBuffer[0] = 0b11100011; // LI, Version, Mode
packetBuffer[1] = 0; // Stratum, or type of clock
packetBuffer[2] = 6; // Polling Interval
packetBuffer[3] = 0xEC; // Peer Clock Precision
// 8 bytes of zero for Root Delay & Root Dispersion
packetBuffer[12] = 49;
packetBuffer[13] = 0x4E;
packetBuffer[14] = 49;
packetBuffer[15] = 52;
// all NTP fields have been given values, now
// you can send a packet requesting a timestamp:
Udp.sendPacket( packetBuffer,NTP_PACKET_SIZE, address, 123); //NTP requests are to port 123
