Topic: LPD6803 adalight issue (Read 1 time) previous topic - next topic
lewye
Mar 17, 2015, 02:07 am Last Edit: Mar 17, 2015, 02:10 am by lewye
Arduino working code does not work teensy3.1     pin 11 pin 13 tied  teensy3.1
Code: [Select]
TCCR1B |= clockSelectBits;                                                     // reset clock select register
I get an error
TCCR1B' was not declared in this scope
 teensy3.1   LPD6803 led for How do I find the code to work
please help
Code: [Select]
 * A 'fork' of the adalight code, with a nice case statement.
 * Tested with the LPD6803 50 led string
 * should work with the WS2801 as well
#include "FastSPI_LED.h"
#define NUM_LEDS 110
 * pin 11 -> blue  for the LPD6803 'yellow' for the WS2801 string
 * pin 13 -> green for the LPD6803 'green' for the WS2801 string
#define PIN 4
#define MODE_HDRA 0
#define MODE_HDRd 1
#define MODE_HDRa 2
#define MODE_HDRhi 3
#define MODE_HDRlo 4
#define MODE_HDRchk 5
#define MODE_DATAr 6
#define MODE_DATAg 7
#define MODE_DATAb 8
// Sometimes chipsets wire in a backwards sort of way
struct CRGB { unsigned char r; unsigned char b; unsigned char g; };
struct CRGB *leds;
unsigned long t,
  startTime,
  lastByteTime,
  lastAckTime;
uint8_t hi, lo, chk,
  mode          = MODE_HDRA;
int channels,channel;
  FastSPI_LED.setLeds(NUM_LEDS);
  //Change this to match your led strip
  FastSPI_LED.setChipset(CFastSPI_LED::SPI_LPD6803);
  //FastSPI_LED.setChipset(CFastSPI_LED::SPI_TM1809);
  //FastSPI_LED.setChipset(CFastSPI_LED::SPI_HL1606);
  //FastSPI_LED.setChipset(CFastSPI_LED::SPI_595);
  //FastSPI_LED.setChipset(CFastSPI_LED::SPI_WS2801);
  FastSPI_LED.setPin(PIN);
  //Change datarate to match your led strip as well
  FastSPI_LED.setDataRate(3);
  FastSPI_LED.init();
  FastSPI_LED.start();
  leds = (struct CRGB*)FastSPI_LED.getRGBData();
  clearLeds();
  Serial.print("Ada\n");
  lastByteTime = startTime = lastAckTime = millis();
int readByte(){
  while(Serial.available()==0){
    //FastSPI_LED.stop();
  //FastSPI_LED.start();
  return Serial.read();
void clearLeds(){
  memset(leds, 0, NUM_LEDS * 3);
  FastSPI_LED.show();
  delay(20);
void loop(){
  int16_t c;
  c = readByte();
  t = millis();
  if((t - lastAckTime) > 1000) {
    Serial.print("Ada\n"); // Send ACK string to host
    lastAckTime = t; // Reset counter
  if ((t - lastByteTime) > 5000) {
    mode = MODE_HDRA;     // After 5 seconds reset to HDRA
  lastByteTime = t;
  lastAckTime = t;
  switch(mode){
  case MODE_HDRA:
    if (c == 0x41) {
      mode = MODE_HDRd;
  case MODE_HDRd:
    if (c == 0x64) {
      mode = MODE_HDRa;
  case MODE_HDRa:
    if (c == 0x61) {
      mode = MODE_HDRhi;
  case MODE_HDRhi:
    hi = c;
    mode = MODE_HDRlo;
  case MODE_HDRlo:
    lo = c;
    mode = MODE_HDRchk;
  case MODE_HDRchk:
    chk = c;
    if (chk == (hi ^ lo ^ 0x55)){
      mode = MODE_DATAr;
      channels = (long)hi*256+(long)lo;
      channel = 0;
      // wrong checksum, reset header
      mode = MODE_HDRA;
  case MODE_DATAr:
    // we are in the data business ;-)
    // ignore all data for channels higher than NUM_LEDS
    if (channel<NUM_LEDS) { leds[channel].r = c; }
    mode = MODE_DATAb;
  case MODE_DATAb:
    if (channel<NUM_LEDS) { leds[channel].b = c; }
    mode = MODE_DATAg;
  case MODE_DATAg:
    if (channel<NUM_LEDS) { leds[channel].g = c; }
    channel++;
    if (channel>channels) {
      FastSPI_LED.show();
      mode = MODE_HDRA;
      mode = MODE_DATAr;
  default:
    // I should not be here, back to
    mode = MODE_HDRA;
Riva
Don't PM me for help as I will ignore it.
Grumpy_Mike
Quote
I get an error
Yes because the processor inside a teensy3 is not the same thing as the processor inside an Arduino. That TCCR1B is a processor timer register which simply does not exist inside an teensy.
lewye
I have no information about software  How it works well get my teensy3
Grumpy_Mike
Quote
Yes this is correct.
Unless it has been designed to work on the teensy3 it will not work on it. This applies to all code that access the fundamental hardware inside the chip.
lewye
#5
Mar 18, 2015, 12:25 pm Last Edit: Mar 18, 2015, 12:36 pm by lewye
So the above code Arduino due also trying to ?
2 Arduino Uno with arduino occur due to the difference in speed up to 150 LEDs?
Grumpy_Mike
Quote
Yoda speaking like you are.
Quote
You got me on that, no idea what you are saying.
lewye
Arduino due Does the above code works
Grumpy_Mike
No.
That is a different processor to the Uno.
