Topic: Flux Capacitor Sketch (Read 2836 times) previous topic - next topic
Elykem
A few years ago I built a flux capacitor and documented the build in a youtube video. I've fielded many, many request for the sketch and promptly sent it out via email.  I finally took the time to post it here for anyone else trying to do the same.
A few notes.
1.  Like most projects, I didn't do this sketch alone.  I got ideas from this forum.
2.  Its not the most efficient code, I know.  If you care to improve it, PLEASE do and post your update.
3.  Its not a perfect replication of the light sequence in the movie but I liked how it turned out and only the hardcore BTTF fans would call me on it.
4.  If you care to watch my youtube video, here is the link.  Be nice.  It was a weekend project and I loved it. youtube.com
Anyways... here you go.
Code: [Select]
 * PIR sensor tester
int ledPin = 13;                // choose the pin for the LED
int inputPin = 2;               // choose the input pin (for PIR sensor)
int pirState = LOW;             // we start, assuming no motion detected
int val = 0;                    // variable for reading the pin status
int ledPin1 = 9;
int ledPin2 = 6;
int ledPin3 = 5;
int ledPin4 = 3;
int surroundPin = 11;
int fadespeed = 10;
int timeTravelSpeed = 80;
int timeTravelLength = 25;
  pinMode(ledPin, OUTPUT);      // declare LED as output
  pinMode(inputPin, INPUT);     // declare sensor as input
  //Serial.begin(9600);
void loop(){
  val = digitalRead(inputPin);  // read input value
  if (val == HIGH) {            // check if the input is HIGH
    digitalWrite(ledPin, HIGH);  // turn LED ON
    runlights(); //run the light show!
    if (pirState == LOW) {
      // we have just turned on
      //Serial.println("Motion detected!");
      // We only want to print on the output change, not state
      pirState = HIGH;
  } else {
    digitalWrite(ledPin, LOW); // turn LED OFF
    if (pirState == HIGH){
      // we have just turned of
      //Serial.println("Motion ended!");
      pirState = LOW;
void runlights(){
  //Speed up loops
  for (int fadeIncrement = 20; fadeIncrement <=100; fadeIncrement +=2){
    for(int fadeValue = 0 ; fadeValue <= 255; fadeValue +=fadeIncrement) {
      analogWrite(ledPin1, fadeValue);
      delay(fadespeed);
    for(int fadeValue = 255 ; fadeValue >= 0; fadeValue -=fadeIncrement) {
      delay(fadespeed);
    analogWrite(ledPin1, 0);
      analogWrite(ledPin2, fadeValue);
      delay(fadespeed);
      delay(fadespeed);
    analogWrite(ledPin2, 0);
      analogWrite(ledPin3, fadeValue);
      delay(fadespeed);
      delay(fadespeed);
    analogWrite(ledPin3, 0);
      analogWrite(ledPin4, fadeValue);
      delay(fadespeed);
      delay(fadespeed);
    analogWrite(ledPin4, 0);
  //time travel loops
  for (int timetravel = 1; timetravel <=timeTravelLength; timetravel +=1){
    //turn on surround lights
    for(int fadeValue = 0 ; fadeValue <= 255; fadeValue +=15) {
      analogWrite(surroundPin, fadeValue);
      delay(fadespeed);
    //Run time travel lights
    for(int fadeValue = 0 ; fadeValue <= 255; fadeValue +=timeTravelSpeed) {
      delay(fadespeed);
    for(int fadeValue = 255 ; fadeValue >= 0; fadeValue -=timeTravelSpeed) {
      delay(fadespeed);
      delay(fadespeed);
      delay(fadespeed);
      delay(fadespeed);
      delay(fadespeed);
      delay(fadespeed);
      delay(fadespeed);
   //fade out the surround lights
    for(int fadeValue = 255 ; fadeValue >= 0; fadeValue -=15) {
      delay(fadespeed);
xyster101
I am using your code and love it! What is the surroundPin light used for on yours?
xyster101
I finished up mine too.
https://youtu.be/dbO3RTeSHmQ
http://forum.arduino.cc/index.php?topic=461869.0
Thanks for the help.
curseofkazar
Hey, I'm also building my flux capacitor. Do you have a wiring diagram?
