Topic: Solved:time lag as encoders control the mouse via Arduino serial communication (Read 3979 times) previous topic - next topic
Robin2
Glad to hear it is working.
I wonder should you use both IF and WHILE like this
Code: [Select]
if(Serial1.available()>5) {
  while(Serial1.available > 0) {
It does nothing if there are five or fewer characters, but then it reads all that there is.
You might want to look at the examples in serial input basics which read from the serial buffer in the background until all the data has been received.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
33chen
sure. I am looking at the link now and it is very comprehensive. Great work, Robin2.
33chen
Robin2,
Again the link is quite informative. a question to your exemplary code in Serialinput link. How should I operate the serial monitor to see the parsed message of "This is a test, 1234, 45.3". When I upload the code and then open the serial monitor, there is no any text coming out. Should I type This is a test, 1234, 45.3, and then hit Send.
Thanks a lot.
Code: [Select]
// simple parse demo
char receivedChars[] = "This is a test, 1234, 45.3" ;
char messageFromPC[32] = {0};
int integerFromPC = 0;
float floatFromPC = 0.0;
char recvChar;
char endMarker = '>';
boolean newData = false;
Serial.println("<Arduino is ready>");
parseData();
showParsedData();
void parseData() {
    // split the data into its parts
  char * strtokIndx; // this is used by strtok() as an index
  strtokIndx = strtok(receivedChars,",");      // get the first part - the string
  strcpy(messageFromPC, strtokIndx); // copy it to messageFromPC
  strtokIndx = strtok(NULL, ","); // this continues where the previous call left off
  integerFromPC = atoi(strtokIndx);     // convert this part to an integer
  floatFromPC = atof(strtokIndx);     // convert this part to a float
void showParsedData() {
Serial.print("Message ");
Serial.println(messageFromPC);
Serial.print("Integer ");
Serial.println(integerFromPC);
Serial.print("Float ");
Serial.println(floatFromPC);
Robin2
You don't need to enter any data in the Serial Monitor. Try pressing the reset button on the Arduino (assuming it is NOT a Leonardo) while the Serial Monitor is open.
The code only runs once when the Arduino restarts.
The parse example simulates the situation where you had used one of the other examples to put data into receivedChars[]
Do let me know if you can't get it to work
...R
33chen
I See. Thanks. Sorry, unfortunately, I am trying with my Leonardo board. It didn't work that way somehow.
Robin2
Change the code to this and it will print out every two seconds (I hope).
Code: [Select]
char recvChar;
        parseData();
showParsedData();
        delay(2000);
void parseData() {
Hopefully also another example of the convenience of using functions.
...R
33chen
It works. I can see the output from Serial monitor. Just curious: my results look like this. Is there something else I should change as well? Thanks.
Code: [Select]
Message This is a test
Integer 0
Float 0.00
Integer 0
Float 0.00
Integer 0
Float 0.00
Robin2
Thanks for pointing that out. I learn new stuff every day. It happens that the strtok() function alters the array receivedChars[] by replacing the commas with \0.
That means that it only works properly the first time. And, because I was just testing it in setup() I had not been aware of that.
On your Leonardo you may not have seen the first printout.
This version should work repeatedly.
Code: [Select]
char tempChars[32];        // temporary array for use by strtok() function
char recvChar;
byte dLen = 0;
        // this is necessary because strtok() alters the array
        //   in this case replacing commas with \0
    strcpy(tempChars, receivedChars);
    parseData();
    showParsedData();
    delay(2000);
void parseData() {
  strtokIndx = strtok(tempChars,",");      // get the first part - the string
I will add a note to my serial input basics Thread.
Thanks again.
...R
33chen
Hossifer
Senior Chen,
(I realize this post is three years old).
It seems you might be utilizing some type of potentiometers for position-acquisition.  If that is accurate it seems you might be acquiring analog voltage correlations of your "definite" position upon what seems to be two axes, or ranges of motion, encoding it digitally via your robot's hardware, decoding it with your arduino code, reincoding it into relative position data, which is used for your mouse function.  Could there be a more (application-dependent) streamlined process to do so by bypassing the robot's means of ADC and running your sensors directly to your Arduino's analog inputs for processing via on-board ADC?  Not sure if this would save any time three years ago, but just curious.
Thanks man.
Bill.
