Topic: IDE 1.6.3 paste code problem (Read 1 time) previous topic - next topic
PaulHsieh
Hi, I'm a Arduino beginner, but I met a little problem bug me a lot.
The following is my environment :
Mac Air 13''
Mac OS 10.10.2 Yosemite
Arduino IDE 1.6.3
The question is, when I copy some code and gonna paste it using command + v, it will paste twice at a time. For example, I copied string "Serial.print("test")" and paste, it will paste "Serial.print("test")Serial.print("test")", but when I use toolbar > edit > paste or right click on mouse and select paste will not occur this problem. I've search this issue on Google but still not find anyone met the same problem like I met. Dose anyone can help me for this problem? Really thankful.
I tried to delete and download again, also restart the mac. Thanks!
federicofissore
I can't reproduce it. Just tested on a mac. What's your keyboard layout?
lordton
same problem here.
yosemite
retina imac
Eienn
Time to time I have the same problem with double paste when using CMD+V
The strange think here is that a problem happens regularly but no always.
No matter it's copy-paste from-to same sketch or from outside source.
But, if i'm using Edit>Paste mostly it work correctly.
Arduino IDA 1.6.5
OS X 10.11.1 (15B42)
MacBook Pro 13" Mid-2012
Prob1995
Same problem here.
Arduino IDE 1.6.5
OS X 10.11.1
MacBook Pro 13" Early-2015
LouisHuang
Switch to another input method editor.
That's how I avoid this problem.
If my current IME is traditional Chinese, the problem appears.
If I switch IME to English, the problem is gone.
mknippen
This bug still exists in 1.8.5 on Mac, 10.13.3.
To reproduce:
• Set your keyboard to something other than the default. (I use Dvorak = QWERTY command)
• Copy some text with Command-C, or with your mouse
• Paste inside Arduino with Command-V.
Expected: The text to appear once.
Actual: The text appears twice.
This happens with the laptop keyboard, and with an external keyboard.
sterretje
Issues could be reported on github. This is probably the best place (although not sure): https://github.com/arduino/Arduino/issues
As I don't have a Mac, I can't report it as I can't provide additional information if needed.
If you understand an example, use it.
If you don't understand an example, don't use it.
Electronics engineer by trade, software engineer by profession. Trying to get back into electronics after 15 years absence.
