Topic: Share your Gcode! (Read 13458 times) previous topic - next topic
kengdahl
One of the good ways of calibrating a printer is to print the same G-code on a similar printer and comparing the results.
I propose that you post your Gcode bellow (in a link) and attach a picture with the results.
This could be booth to help others and get help with a tricky print.
benvolio9mm
Great idea. Will do as soon as I get my Materia up and running. Still in assembly.
dp_1
#2
Apr 27, 2015, 03:55 pm Last Edit: Apr 27, 2015, 03:56 pm by dp_1
So, let's start with something easy: the classical calibration cube.
It is one of the first objects I printed (the first had too thin walls and broke when I removed it from the print bed :) )
Print settings:
perimeters: 3
top solid layers: 3
bottom solid layers: 3
layer height: 0.3mm
infill: 10%, honeycomb
temperature: 185°
first layer temperature: 200 (I had best results for first layer with this instead of the default 230)
Print time: 5-8 minutes, not sure
Images:
Cube
Bottom layer
Gcode: http://pastebin.com/raw.php?i=rYngwiRV
dp_1
Prendete quello che dico come un suggerimento, non mi assumo responsabilità di nessun tipo
ejo60
#3
May 14, 2015, 07:13 am Last Edit: May 14, 2015, 07:18 am by ejo60 Reason: I added a link to the wordpress website
The caffeine molecule
https://www.thingiverse.com/thing:618654
http://pastebin.com/ZQpyu6Z8
I modified the printer with a heated bed set-up as discussed here, this is IMHO the only way to get something flat in particular when there is a lot of contact area
https://ejo60.wordpress.com/2015/05/09/add-a-heated-bed-to-your-3d-printer/
kengdahl
Thank you all for posting your prints :)
normoldboy
#5
Jun 10, 2015, 04:16 am Last Edit: Jun 23, 2015, 03:50 pm by kengdahl Reason: Added click friendly link :) and the picture in the body
I have produced a M6 wrench a small four prong wrench with the Materia 101 that produces consistent copies.
The G Code can be found at:  https://www.dropbox.com/s/v89odickmt257co/M6Tool.gcode?dl=0
I will post  picture as soon as I figure out how.
The picture can be found at DropBox:
The code runs for about 9 minutes and can confirm your machines consistency. It can also be used as a 6mm wrench for your tool box.
CrossRoads
Reply and Attach it. Might have to resize it down if it's too big.
kengdahl
So I tried printing the 3Dbenchy boat with the Materia and I'm quite happy with the results
Here is my Gcode
Studiosus
Print settings:
perimeters: 3
top solid layers: 3
layer height: 0.3mm
temperature: 185°
Images:
Cube
Bottom layer
dp_1
I tried to print this cube and it starts off but soon ends up on a wild mess of filament strands, the extruder head gets clogged up with filament. But it does something that's the good news :)
Need to sort out what is wrong. Thanks for sharing!
