Topic: SPIMemory library - Formerly SPIFlash - now supports basic SFDP! (Read 65150 times) previous topic - next topic
Saikiran25
I am writing a code for w25q16bv flash memory. it had commands to erase the data upto 4Kb, sector erase upto 64Kb and total chip erase. but I only need to erase 256 bytes in a specified location. i tried writing 0xFF by using SPI.transfer(); function but no use. is there any way to resolve this problem?
Marzogh
You cannot write 0xFF to locations that already have data in them - they need to be erased properly.
The only way for you to erase a memory section that is smaller than 4KB would be to use a buffer. Roughly speaking, your code should do the following:
  • Figure out which 4KB block contains the 256 bytes that you need erased.
  • Copy the data in the whole of the block over to another vacant block and during this process, set the 256 bytes that you want to erase to 0xFF - or if your microcontroller has enough RAM, just hold the entire 4KB in the RAM as a byte array
  • Erase the 4KB block on the flash memory (containing the 256 bytes you need erased)
  • Write the byte array you have put aside in step 2, back to the newly erased 4KB sector on your flash memory
Et voilĂ ! The 256 bytes you want to erase will have been erased.  ;D
Marzogh
Just pushed an update through to v3.2.0 with the following changes:
- The Library is now called SPIMemory, not SPIFlash. The reason for this change can be found here.
Enhancements:
- The library now gathers sfdp information through _chipID(). SFDP information is collected when available, otherwise the library defaults to using code from v3.1.0 to ID the chip.
- The library now does the following - if the flash memory chip is compatible with the SFDP standard
  - Identifies the flash memory chip using the Serial Flash Discoverable Parameters standard. (JESD216B)
  - Identifies the following opcodes from the SFDP tables and uses them to read/write data:
         - eraseSector, eraseBlock32K, eraseBlock64K
  - Reads timing information from SFDP to accurately time the following operations:
New flash memory chips supported:
- All flash memories compatible with the SFDP standard (as at JESD216B) should be compatible with the library
- LE25U40CMC from ON Semiconductor
- A25L512A0 from AMIC
- M25P40 from Micron
- AT25SF041 from Adesto
- S25FL032P from Cypress/Spansion
New Microcontrollers supported:
- ATSAMD51J19 ARM Cortex M4 (Adafruit Metro M4)
I've started work on proper documentation. As polaroi8d pointed out here, the old ReadMe was getting far too unwieldy and the Github Wiki is not the easiest thing to poke around. By the time the next release rolls around I hope to have the documentation done - (Rst + Sphinx). Check out the progress of the documentation here! Any recommendations are welcome  8)
kucukkose
Hi Marzogh
Did you received your JV series.
I am using W25Q64JV and i updated the library 3.2.0.
But library gives Error code: 0x0B
Thanks
Ergun
Hi mate,
Thanks for the heads up. I've got some JV series coming in from AliExpress, but this being AliExpress, they're probably a month or so away form getting to me in Australia. :/
I'll see if I can figure out what's going wrong (in theory) by looking at the timing on the datasheet and get back to you as soon as I can.
The current release version is v3.0.1 and that's what is available from the library manager. I'm still testing v3.1.0 is all platforms that library supports and should hopefully have it out before this week ends.
Feel free to pull down a zip of the development branch to test with your hardware. The code is pretty much good to go and just needs some battle testing before I sign off on a release.
If you are looking at using filesystems, Adafruit's SPI Flash library has quite good filesystem support with the ability to mount the chip up as a mass storage device. However, this is something I've only ever played around with on the M0 Express line of boards and I don't know how it works (or if it does) outside of the M0 / SAMD21 line.
I would like to - someday incorporate a filesystem into my library, but I have two problems with that:
  • I have no idea how filesystems work, much less how to implement one on the Arduino platform :P
  • My main aim with this library has been to get it to work as fast as it can while maintaining read/write integrity. AFAIK, putting a filesystem in there reduces this speed enormously.
I use the library with my environmental sensor units as a way of storing lots of data as (byte arrays) on an SPI Flash chip. When it fills up I write all of that data to an SD card in one go. This saves a ton of power when you have a low-power environmental sensing / logging system deployed in remote areas for extended periods of time. I borrowed this idea from EKMallon's fantastic Cave Pearl project. He uses EEPROMs to buffer data but I've found that using SPI Flash in combination with an SD card works equally well - especially when I use a TPL5110 timer to cut power to the entire system when it doesn't need to be operational. :)
Marzogh
Hi Ergun,
As I replied on your bug report on Github, I have received my W25Q64JV and tested it with v3.1.0 & with v3.2.0 and they work fine - no errors thrown at all. Could you please respond to my reply there?
Marzogh
Just pushed an update through to v3.2.1 with the following changes:
Bugs squashed:
- Fixes issue #135 : The addition of the SFDP checking to _chipID resulted in a sudden (very large) increase in compiled code size. As of the current version (v3.2.1), SFDP checking is an user controlled option. To get the library to work with SFDP compatible flash memory (that might not be officially supported), the user must uncomment '//#define USES_SFDP' in 'SPIMemory.h'.
- Moved bool _loopedOver from being a local variable in getAddress() to a global one. Now it actually does what it was meant to do - i.e. prevent looping over data a second time.
Enhancements:
- As of v3.2.1, SFDP parameter discovery is an user controlled option. To get the library to work with SFDP compatible flash memory chips that are not officially supported by the library, the user must uncomment '//#define USES_SFDP' in 'SPIMemory.h'.
- The way the basic functions execute has been modified to keep the function runtime the same (or improved) while reducing their memory footprint.
Test sketch - FlashDiagnostics.ino from v3.2.0 with #RUNDIAGNOSTIC commented out
Test platform - Arduino Pro Mini 8MHz 3.3V
Library versionCompiled code sizeSFDP discovery% Difference from v3.1.0
v3.1.017652 bytesNot supported0%
v3.2.020104 bytesSupported & enabled by default+13.9%
v3.2.117854 bytesSupported & enabled+1.1%
v3.2.115316 bytesSupported & disabled-13.75%
jaholmes
(Low-priority / Feature request)
Not sure if this has been entertained before and dismissed for some reason, but:  It would be cool if the library API explicitly supported sequential access.  E.g. readNextByte() or similar.  It seems that most (all?) of these devices auto-increment addresses following accesses, meaning that they're optimized for sequential access.  Meanwhile, the library steers you toward random access, which is kind of worst-case scenario.  Supporting random access is fine, of course, but supporting and documenting the access pattern that the hardware is actually designed for seems important too.  Otherwise, people who need to stream bytes from memory are going to do things like readByte(addr++) and be severely punished for it when the library does 4x as many transfers as necessary.
walterpre
Hi Marzogh,
I've problems with reading and writing to SST26VF064B from Microchip.
I'm using a SAMD21 sparkfun mini breakout.
If I run the sketch "FlashDiagnostics" the chip is recognized and I get the following output:
SPIMemory Library version: 3.2.1
JEDEC ID: 0xBE5237
Man ID: 0xBE
Memory ID: 0x52
Capacity: 0
Max Pages: 0
                     Testing library code
         Function      Test result              Runtime
         Power Down         FAIL         Not all chips support power down. Check your datasheet.
         Power Up         PASS                  0 us
         Erase Chip         PASS                  0 us
         Erase 72KB         FAIL
         Erase 64KB         FAIL
         Erase 32KB         FAIL
         Erase 4KB         FAIL
         Data type      I/O Result         Write time         Read time
         Byte            FAIL                  0 us
         Char            FAIL                  0 us
         Word            FAIL                  0 us
         Short            FAIL                  0 us
         ULong            FAIL                  0 us
         Long            FAIL                  0 us
         Float            FAIL                  0 us
         Struct            FAIL                  0 us
         Byte Array         FAIL   0,       FAIL   1,       FAIL   2,       FAIL   3,       FAIL   4,       FAIL   5,       FAIL   6,       FAIL   7,       FAIL   8,       FAIL   9,       FAIL   10,       FAIL   11,       FAIL   13,       FAIL   14,       FAIL   15,       FAIL   16,       FAIL   17,       FAIL   18,       FAIL   19,       FAIL   20,       FAIL   21,       FAIL   22,       FAIL   23,       FAIL   24,       FAIL   25,       FAIL   26,       FAIL   27,       FAIL   28,       FAIL   29,       FAIL   30,       FAIL   31,       FAIL   32,       FAIL   33,       FAIL   34,       FAIL   35,       FAIL   36,       FAIL   37,       FAIL   38,       FAIL   39,       FAIL   40,       FAIL   41,       FAIL   42,       FAIL   43,       FAIL   44,       FAIL   45,       FAIL   46,       FAIL   47,       FAIL   48,       FAIL   49,       FAIL   50,       FAIL   51,       FAIL   52,       FAIL   53,       FAIL   54,       FAIL   55,       FAIL   56,       FAIL   57,       FAIL   58,       FAIL   59,       FAIL   60,       FAIL   61,       FAIL   62,       FAIL   63,       FAIL   64,       FAIL   65,       FAIL   66,       FAIL   67,       FAIL   68,       FAIL   69,       FAIL   70,       FAIL   71,       FAIL   72,       FAIL   73,       FAIL   74,       FAIL   75,       FAIL   76,       FAIL   77,       FAIL   78,       FAIL   79,       FAIL   80,       FAIL   81,       FAIL   82,       FAIL   83,       FAIL   84,       FAIL   85,       FAIL   86,       FAIL   87,       FAIL   88,       FAIL   89,       FAIL   90,       FAIL   91,       FAIL   92,       FAIL   93,       FAIL   94,       FAIL   95,       FAIL   96,       FAIL   97,       FAIL   98,       FAIL   99,       FAIL   100,       FAIL   101,       FAIL   102,       FAIL   103,       FAIL   104,       FAIL   105,       FAIL   106,       FAIL   107,       FAIL   108,       FAIL   109,       FAIL   110,       FAIL   111,       FAIL   112,       FAIL   113,       FAIL   114,       FAIL   115,       FAIL   116,       FAIL   117,       FAIL   118,       FAIL   119,       FAIL   120,       FAIL   121,       FAIL   122,       FAIL   123,       FAIL   124,       FAIL   125,       FAIL   126,       FAIL   127,       FAIL   128,       FAIL   129,       FAIL   130,       FAIL   131,       FAIL   132,       FAIL   133,       FAIL   134,       FAIL   135,       FAIL   136,       FAIL   137,       FAIL   138,       FAIL   139,       FAIL   140,       FAIL   141,       FAIL   142,       FAIL   143,       FAIL   144,       FAIL   145,       FAIL   146,       FAIL   147,       FAIL   148,       FAIL   149,       FAIL   150,       FAIL   151,       FAIL   152,       FAIL   153,       FAIL   154,       FAIL   155,       FAIL   156,       FAIL   157,       FAIL   158,       FAIL   159,       FAIL   160,       FAIL   161,       FAIL   162,       FAIL   163,       FAIL   164,       FAIL   165,       FAIL   166,       FAIL   167,       FAIL   168,       FAIL   169,       FAIL   170,       FAIL   171,       FAIL   172,       FAIL   173,       FAIL   174,       FAIL   175,       FAIL   176,       FAIL   177,       FAIL   178,       FAIL   179,       FAIL   180,       FAIL   181,       FAIL   182,       FAIL   183,       FAIL   184,       FAIL   185,       FAIL   186,       FAIL   187,       FAIL   188,       FAIL   189,       FAIL   190,       FAIL   191,       FAIL   192,       FAIL   193,       FAIL   194,       FAIL   195,       FAIL   196,       FAIL   197,       FAIL   198,       FAIL   199,       FAIL   200,       FAIL   201,       FAIL   202,       FAIL   203,       FAIL   204,       FAIL   205,       FAIL   206,       FAIL   207,       FAIL   208,       FAIL   209,       FAIL   210,       FAIL   211,       FAIL   212,       FAIL   213,       FAIL   214,       FAIL   215,       FAIL   216,       FAIL   217,       FAIL   218,       FAIL   219,       FAIL   220,       FAIL   221,       FAIL   222,       FAIL   223,       FAIL   224,       FAIL   225,       FAIL   226,       FAIL   227,       FAIL   228,       FAIL   229,       FAIL   230,       FAIL   231,       FAIL   232,       FAIL   233,       FAIL   234,       FAIL   235,       FAIL   236,       FAIL   237,       FAIL   238,       FAIL   239,       FAIL   240,       FAIL   241,       FAIL   242,       FAIL   243,       FAIL   244,       FAIL   245,       FAIL   246,       FAIL   247,       FAIL   248,       FAIL   249,       FAIL   250,       FAIL   251,       FAIL   252,       FAIL   253,       FAIL   254,       FAIL   255,       PASS                  0 us
         String            FAIL                  0 us
Could you give me a hint, what to do/test?
BigEyeTuna
Getting a similar result with the Adafruit feather SAMD and a 16MB Microchip SST26. Seems like it can erase and read, but not write. Any suggestions?
I also swapped to another 16MB Microchip SST26 with the same result.
Code: [Select]
Initialising..........
JEDEC ID: 0xBF2641
Man ID: 0xBF
Memory ID: 0x26
Capacity: 16777216
Max Pages: 4294967295
Power Up   PASS      0 us
Erase 72KB   PASS      0 us
Erase 64KB   PASS      0 us
Erase 32KB   PASS      0 us
Erase 4KB   PASS      0 us
Byte   FAIL      0 us
Char   FAIL      0 us
Word   FAIL      0 us
Short   FAIL      0 us
ULong   FAIL      0 us
Long   FAIL      0 us
Float   FAIL      0 us
Struct   FAIL      0 us
Byte Array   FAIL 0,   FAIL 1,   FAIL 2,   FAIL 3,   FAIL 4,   FAIL 5,   FAIL 6,   FAIL 7,   FAIL 8,   FAIL 9,   FAIL 10,   FAIL 11,   FAIL 12,   FAIL 13,   FAIL 14,   FAIL 15,   FAIL 16,   FAIL 17,   FAIL 18,   FAIL 19,   FAIL 20,   FAIL 21,   FAIL 22,   FAIL 23,   FAIL 24,   FAIL 25,   FAIL 26,   FAIL 27,   FAIL 28,   FAIL 29,   FAIL 30,   FAIL 31,   FAIL 32,   FAIL 33,   FAIL 34,   FAIL 35,   FAIL 36,   FAIL 37,   FAIL 38,   FAIL 39,   FAIL 40,   FAIL 41,   FAIL 42,   FAIL 43,   FAIL 44,   FAIL 45,   FAIL 46,   FAIL 47,   FAIL 48,   FAIL 49,   FAIL 50,   FAIL 51,   FAIL 52,   FAIL 53,   FAIL 54,   FAIL 55,   FAIL 56,   FAIL 57,   FAIL 58,   FAIL 59,   FAIL 60,   FAIL 61,   FAIL 62,   FAIL 63,   FAIL 64,   FAIL 65,   FAIL 66,   FAIL 67,   FAIL 68,   FAIL 69,   FAIL 70,   FAIL 71,   FAIL 72,   FAIL 73,   FAIL 74,   FAIL 75,   FAIL 76,   FAIL 77,   FAIL 78,   FAIL 79,   FAIL 80,   FAIL 81,   FAIL 82,   FAIL 83,   FAIL 84,   FAIL 85,   FAIL 86,   FAIL 87,   FAIL 88,   FAIL 89,   FAIL 90,   FAIL 91,   FAIL 92,   FAIL 93,   FAIL 94,   FAIL 95,   FAIL 96,   FAIL 97,   FAIL 98,   FAIL 99,   FAIL 100,   FAIL 101,   FAIL 102,   FAIL 103,   FAIL 104,   FAIL 105,   FAIL 106,   FAIL 107,   FAIL 108,   FAIL 109,   FAIL 110,   FAIL 111,   FAIL 112,   FAIL 113,   FAIL 114,   FAIL 115,   FAIL 116,   FAIL 117,   FAIL 118,   FAIL 119,   FAIL 120,   FAIL 121,   FAIL 122,   FAIL 123,   FAIL 124,   FAIL 125,   FAIL 126,   FAIL 127,   FAIL 128,   FAIL 129,   FAIL 130,   FAIL 131,   FAIL 132,   FAIL 133,   FAIL 134,   FAIL 135,   FAIL 136,   FAIL 137,   FAIL 138,   FAIL 139,   FAIL 140,   FAIL 141,   FAIL 142,   FAIL 143,   FAIL 144,   FAIL 145,   FAIL 146,   FAIL 147,   FAIL 148,   FAIL 149,   FAIL 150,   FAIL 151,   FAIL 152,   FAIL 153,   FAIL 154,   FAIL 155,   FAIL 156,   FAIL 157,   FAIL 158,   FAIL 159,   FAIL 160,   FAIL 161,   FAIL 162,   FAIL 163,   FAIL 164,   FAIL 165,   FAIL 166,   FAIL 167,   FAIL 168,   FAIL 169,   FAIL 170,   FAIL 171,   FAIL 172,   FAIL 173,   FAIL 174,   FAIL 175,   FAIL 176,   FAIL 177,   FAIL 178,   FAIL 179,   FAIL 180,   FAIL 181,   FAIL 182,   FAIL 183,   FAIL 184,   FAIL 185,   FAIL 186,   FAIL 187,   FAIL 188,   FAIL 189,   FAIL 190,   FAIL 191,   FAIL 192,   FAIL 193,   FAIL 194,   FAIL 195,   FAIL 196,   FAIL 197,   FAIL 198,   FAIL 199,   FAIL 200,   FAIL 201,   FAIL 202,   FAIL 203,   FAIL 204,   FAIL 205,   FAIL 206,   FAIL 207,   FAIL 208,   FAIL 209,   FAIL 210,   FAIL 211,   FAIL 212,   FAIL 213,   FAIL 214,   FAIL 215,   FAIL 216,   FAIL 217,   FAIL 218,   FAIL 219,   FAIL 220,   FAIL 221,   FAIL 222,   FAIL 223,   FAIL 224,   FAIL 225,   FAIL 226,   FAIL 227,   FAIL 228,   FAIL 229,   FAIL 230,   FAIL 231,   FAIL 232,   FAIL 233,   FAIL 234,   FAIL 235,   FAIL 236,   FAIL 237,   FAIL 238,   FAIL 239,   FAIL 240,   FAIL 241,   FAIL 242,   FAIL 243,   FAIL 244,   FAIL 245,   FAIL 246,   FAIL 247,   FAIL 248,   FAIL 249,   FAIL 250,   FAIL 251,   FAIL 252,   FAIL 253,   FAIL 254,   PASS      0 us
String   FAIL      0 us
siva_iot
Im using this library for ESP8266 nodemcu with winbond external flash w25q32f but im frequently faced WDT reset. what should i do..? please help me
Marzogh
Hi guys,
My apologies for the long delay in replying. I was away for health reasons and am slowly transitioning back into normality.
@walterpre & @BigEyetuna The problem with the SST26 series is top priority and I will try and get this sorted within a week and keep you posted here.
@siva_iot I find that WDT reset usually happens when your code does not allow the ESP8266 to carry out essential background functions. make sure you have enough delay() statements at the right places in your code. the delay() function in the ESP8266 is different to the normal one used for ATmega or ARM boards and lets background processes run while waiting for user code to execute.
@jaholmes The simplest way would be to use the built in readByteArray()/writeByteArray() or readCharArray()/writeCharArray() functions. They let you define the size of the block of data you want read/written - sequentially - and are very fast.
Marzogh
@walterpre & @BigEyetuna This issue has been addressed with the code in the development branch on GitHub. I will roll these changes into the next release of the library
Srmojo
hello @Marzogh.
Im having some issues with the SPImemory library, specifically it doesn't work.
Hardware:
Adafruit Feather adalogger
W25Q64JV
Wiring:
1cs    ----> pin11
2DO   ----> MISO
3WP   ----> VCC 3.3v
4GND  ----> GND
5DI     ----> MOSI
6CLK   ----> SCK
7HOLD ----> VCC 3.3v
8VCC   ----> VCC 3.3v
FlashDiagnostics line 40 has been changed to:
     SPIFlash flash(11);
I have some very basic code which works fine to manually handle reading and writing to the flash chip so I know it is not a hardware or wiring issue, but I would like to implement your library since it seems to work so well for others. I have tried version 3.2.1 and 3.2.0 to no avail.
Obviosuly it thinks the chip is not powered on so all of the other tests will fail.
getAddressex only returns the serial.print lines with blank spaces (0s?)where values should be.
Any help is appreciated.
The output is below
Code: [Select]
Chip Diagnostics initiated.
Unable to identify chip. Are you sure this chip is supported?
Chip details:
If this does not help resolve/clarify this issue, please raise an issue at http://www.github.com/Marzogh/SPIMemory/issues with the details of what your were doing when this error occurred
JEDEC ID: 0x8FFF8F
Man ID: 0x8F
Memory ID: 0xFF
Capacity: 0
Max Pages: 0
 Power Down   PASS      66 us
 Power Up   FAIL
 Erase Chip The Flash chip is currently powered down.
   FAIL
 Erase 72KB The Flash chip is currently powered down.
   FAIL
 Erase 64KB The Flash chip is currently powered down.
   FAIL
 Erase 32KB The Flash chip is currently powered down.
   FAIL
 Erase 4KB The Flash chip is currently powered down.
   FAIL
 Byte   FAIL 0 us 4.251 s
 Char   FAIL 0 us 4.292 s
 Word   FAIL 0 us 4.333 s
 Short   FAIL 0 us 4.374 s
 ULong   FAIL 0 us 4.415 s
 Long   FAIL 0 us 4.456 s
 Float   FAIL 0 us 4.497 s
 Struct   FAIL 0 us 4.539 s
 Byte Array   FAIL 0,   FAIL 1,   FAIL 2,   FAIL 3,   FAIL 4,   FAIL 5,   FAIL 6,   FAIL 7,   FAIL 8,   FAIL 9,   FAIL 10,   FAIL 11,   FAIL 12,   FAIL 13,   FAIL 14,   FAIL 15,   FAIL 16,   FAIL 17,   FAIL 18,   FAIL 19,   FAIL 20,   FAIL 21,   FAIL 22,   FAIL 23,   FAIL 24,   FAIL 25,   FAIL 26,   FAIL 27,   FAIL 28,   FAIL 29,   FAIL 30,   FAIL 31,   FAIL 32,   FAIL 33,   FAIL 34,   FAIL 35,   FAIL 36,   FAIL 37,   FAIL 38,   FAIL 39,   FAIL 40,   FAIL 41,   FAIL 42,   FAIL 43,   FAIL 44,   FAIL 45,   FAIL 46,   FAIL 47,   FAIL 48,   FAIL 49,   FAIL 50,   FAIL 51,   FAIL 52,   FAIL 53,   FAIL 54,   FAIL 55,   FAIL 56,   FAIL 57,   FAIL 58,   FAIL 59,   FAIL 60,   FAIL 61,   FAIL 62,   FAIL 63,   FAIL 64,   FAIL 65,   FAIL 66,   FAIL 67,   FAIL 68,   FAIL 69,   FAIL 70,   FAIL 71,   FAIL 72,   FAIL 73,   FAIL 74,   FAIL 75,   FAIL 76,   FAIL 77,   FAIL 78,   FAIL 79,   FAIL 80,   FAIL 81,   FAIL 82,   FAIL 83,   FAIL 84,   FAIL 85,   FAIL 86,   FAIL 87,   FAIL 88,   FAIL 89,   FAIL 90,   FAIL 91,   FAIL 92,   FAIL 93,   FAIL 94,   FAIL 95,   FAIL 96,   FAIL 97,   FAIL 98,   FAIL 99,   FAIL 100,   FAIL 101,   FAIL 102,   FAIL 103,   FAIL 104,   FAIL 105,   FAIL 106,   FAIL 107,   FAIL 108,   FAIL 109,   FAIL 110,   FAIL 111,   FAIL 112,   FAIL 113,   FAIL 114,   FAIL 115,   FAIL 116,   FAIL 117,   FAIL 118,   FAIL 119,   FAIL 120,   FAIL 121,   FAIL 122,   FAIL 123,   FAIL 124,   FAIL 125,   FAIL 126,   FAIL 127,   FAIL 128,   FAIL 129,   FAIL 130,   FAIL 131,   FAIL 132,   FAIL 133,   FAIL 134,   FAIL 135,   FAIL 136,   FAIL 137,   FAIL 138,   FAIL 139,   FAIL 140,   FAIL 141,   FAIL 142,   FAIL 143,   FAIL 144,   FAIL 145,   FAIL 146,   FAIL 147,   FAIL 148,   FAIL 149,   FAIL 150,   FAIL 151,   FAIL 152,   FAIL 153,   FAIL 154,   FAIL 155,   FAIL 156,   FAIL 157,   FAIL 158,   FAIL 159,   FAIL 160,   FAIL 161,   FAIL 162,   FAIL 163,   FAIL 164,   FAIL 165,   FAIL 166,   FAIL 167,   FAIL 168,   FAIL 169,   FAIL 170,   FAIL 171,   FAIL 172,   FAIL 173,   FAIL 174,   FAIL 175,   FAIL 176,   FAIL 177,   FAIL 178,   FAIL 179,   FAIL 180,   FAIL 181,   FAIL 182,   FAIL 183,   FAIL 184,   FAIL 185,   FAIL 186,   FAIL 187,   FAIL 188,   FAIL 189,   FAIL 190,   FAIL 191,   FAIL 192,   FAIL 193,   FAIL 194,   FAIL 195,   FAIL 196,   FAIL 197,   FAIL 198,   FAIL 199,   FAIL 200,   FAIL 201,   FAIL 202,   FAIL 203,   FAIL 204,   FAIL 205,   FAIL 206,   FAIL 207,   FAIL 208,   FAIL 209,   FAIL 210,   FAIL 211,   FAIL 212,   FAIL 213,   FAIL 214,   FAIL 215,   FAIL 216,   FAIL 217,   FAIL 218,   FAIL 219,   FAIL 220,   FAIL 221,   FAIL 222,   FAIL 223,   FAIL 224,   FAIL 225,   FAIL 226,   FAIL 227,   FAIL 228,   FAIL 229,   FAIL 230,   FAIL 231,   FAIL 232,   FAIL 233,   FAIL 234,   FAIL 235,   FAIL 236,   FAIL 237,   FAIL 238,   FAIL 239,   FAIL 240,   FAIL 241,   FAIL 242,   FAIL 243,   FAIL 244,   FAIL 245,   FAIL 246,   FAIL 247,   FAIL 248,   FAIL 249,   FAIL 250,   FAIL 251,   FAIL 252,   FAIL 253,   FAIL 254,   FAIL 255,   PASS 0 us 4.581 s
 String   FAIL 0 us 4.719 s
timoteo_mendes
Hello Srmojo,
Did you had any luck with your board?
I do have one also and would like to implement the library.
Thanks.
Tim
jacky4566
OK ive am at my wits end and come to the masters for help.
I have a Teensy LC and trying to communicate with a SST26VF064B Flash chip.
Using only raw SPI commands I can communicate with the chip. Get ID and read the status regs. But I cant write! Whey do they make it so damn hard to write!
Marzogh perhaps you can lend some insight into my SST26 chip.
Starting factory fresh with SPIMemory Library this is the result of the test code:
Code: [Select]
No Chip size defined by user. Automated identification initiated.
Chip identified. This chip is fully supported by the library.
JEDEC ID: 0xBF2643
Man ID: 0xBF
Memory ID: 0x26
Capacity: 8388608
Max Pages: 0
Unique ID: 04294967040, 0xFFFFFFFFFFFFFF00
Power Down This function is not supported by the flash memory hardware.
Power Up    PASS       44 us
Erase Chip    PASS       60 us
Erase 72KB    PASS       176 us
Erase 64KB    PASS       68 us
Erase 32KB    PASS       76 us
Erase 4KB    PASS       76 us
Byte    FAIL 0 us 40 us
Char    FAIL 0 us 40 us
Word    FAIL 0 us 44 us
Short    FAIL 0 us 40 us
ULong    FAIL 0 us 44 us
Long    FAIL 0 us 48 us
Float    FAIL 0 us 48 us
Write Function has failed errorcheck.
Struct    FAIL 0 us 112 us
Byte Array    FAIL 0,    FAIL 1,    FAIL 2,    FAIL 3,    FAIL 4,    FAIL 5,    FAIL 6,    FAIL 7,    FAIL 8,    FAIL 9,    FAIL 10,    FAIL 11,    FAIL 12,    FAIL 13,    FAIL 14,    FAIL 15,    FAIL 16,    FAIL 17,    FAIL 18,    FAIL 19,    FAIL 20,    FAIL 21,    FAIL 22,    FAIL 23,    FAIL 24,    FAIL 25,    FAIL 26,    FAIL 27,    FAIL 28,    FAIL 29,    FAIL 30,    FAIL 31,    FAIL 32,    FAIL 33,    FAIL 34,    FAIL 35,    FAIL 36,    FAIL 37,    FAIL 38,    FAIL 39,    FAIL 40,    FAIL 41,    FAIL 42,    FAIL 43,    FAIL 44,    FAIL 45,    FAIL 46,    FAIL 47,    FAIL 48,    FAIL 49,    FAIL 50,    FAIL 51,    FAIL 52,    FAIL 53,    FAIL 54,    FAIL 55,    FAIL 56,    FAIL 57,    FAIL 58,    FAIL 59,    FAIL 60,    FAIL 61,    FAIL 62,    FAIL 63,    FAIL 64,    FAIL 65,    FAIL 66,    FAIL 67,    FAIL 68,    FAIL 69,    FAIL 70,    FAIL 71,    FAIL 72,    FAIL 73,    FAIL 74,    FAIL 75,    FAIL 76,    FAIL 77,    FAIL 78,    FAIL 79,    FAIL 80,    FAIL 81,    FAIL 82,    FAIL 83,    FAIL 84,    FAIL 85,    FAIL 86,    FAIL 87,    FAIL 88,    FAIL 89,    FAIL 90,    FAIL 91,    FAIL 92,    FAIL 93,    FAIL 94,    FAIL 95,    FAIL 96,    FAIL 97,    FAIL 98,    FAIL 99,    FAIL 100,    FAIL 101,    FAIL 102,    FAIL 103,    FAIL 104,    FAIL 105,    FAIL 106,    FAIL 107,    FAIL 108,    FAIL 109,    FAIL 110,    FAIL 111,    FAIL 112,    FAIL 113,    FAIL 114,    FAIL 115,    FAIL 116,    FAIL 117,    FAIL 118,    FAIL 119,    FAIL 120,    FAIL 121,    FAIL 122,    FAIL 123,    FAIL 124,    FAIL 125,    FAIL 126,    FAIL 127,    FAIL 128,    FAIL 129,    FAIL 130,    FAIL 131,    FAIL 132,    FAIL 133,    FAIL 134,    FAIL 135,    FAIL 136,    FAIL 137,    FAIL 138,    FAIL 139,    FAIL 140,    FAIL 141,    FAIL 142,    FAIL 143,    FAIL 144,    FAIL 145,    FAIL 146,    FAIL 147,    FAIL 148,    FAIL 149,    FAIL 150,    FAIL 151,    FAIL 152,    FAIL 153,    FAIL 154,    FAIL 155,    FAIL 156,    FAIL 157,    FAIL 158,    FAIL 159,    FAIL 160,    FAIL 161,    FAIL 162,    FAIL 163,    FAIL 164,    FAIL 165,    FAIL 166,    FAIL 167,    FAIL 168,    FAIL 169,    FAIL 170,    FAIL 171,    FAIL 172,    FAIL 173,    FAIL 174,    FAIL 175,    FAIL 176,    FAIL 177,    FAIL 178,    FAIL 179,    FAIL 180,    FAIL 181,    FAIL 182,    FAIL 183,    FAIL 184,    FAIL 185,    FAIL 186,    FAIL 187,    FAIL 188,    FAIL 189,    FAIL 190,    FAIL 191,    FAIL 192,    FAIL 193,    FAIL 194,    FAIL 195,    FAIL 196,    FAIL 197,    FAIL 198,    FAIL 199,    FAIL 200,    FAIL 201,    FAIL 202,    FAIL 203,    FAIL 204,    FAIL 205,    FAIL 206,    FAIL 207,    FAIL 208,    FAIL 209,    FAIL 210,    FAIL 211,    FAIL 212,    FAIL 213,    FAIL 214,    FAIL 215,    FAIL 216,    FAIL 217,    FAIL 218,    FAIL 219,    FAIL 220,    FAIL 221,    FAIL 222,    FAIL 223,    FAIL 224,    FAIL 225,    FAIL 226,    FAIL 227,    FAIL 228,    FAIL 229,    FAIL 230,    FAIL 231,    FAIL 232,    FAIL 233,    FAIL 234,    FAIL 235,    FAIL 236,    FAIL 237,    FAIL 238,    FAIL 239,    FAIL 240,    FAIL 241,    FAIL 242,    FAIL 243,    FAIL 244,    FAIL 245,    FAIL 246,    FAIL 247,    FAIL 248,    FAIL 249,    FAIL 250,    FAIL 251,    FAIL 252,    FAIL 253,    FAIL 254,    PASS 0 us 512 us
String    FAIL 0 us 84 us
I have disable the WP and HOLD pins with the IOC Register but still not getting anywhere. What is next to investigate?
Thank you!
