Author Topic: Aide  (Read 407 times)
qui peut m'aidé a comprendre ce program
c'est pour faire une telecomande LANC pour camescope sony
je je sait pas coment le modifier pour envoyer les comande au camescope
merci d'avance
#define rxPin 2         // Receive Status from LANC Device (unimplemented)
#define txPin 3            // Send Commands to LANC DEVICE (works)
#define ledPin 13      // LEB for activity status flickering
#define bitMicroSeconds 104
byte ledPinState = 1;
  Serial.begin(57600); // 9600, 14400, 38400, 57600, 115200
 // define pin modes for tx, rx, led pins:
  pinMode(rxPin, INPUT);
  pinMode(txPin, OUTPUT);
  pinMode(ledPin, OUTPUT);
  // Blink LED 13 Just to Say 'Hello'
  digitalWrite(13,HIGH);
  digitalWrite(13,LOW);
int block = 0;
int state = 0;
int in = 0;
  int inBytes = Serial.available();
  if (inBytes == 0) return;
  if (inBytes  >= 128)  {
      Serial.print(0,BYTE);
      //      Serial.flush();
      return;
  in = Serial.read();
  if (in == 99) return;
 /* switch (state) {
  case  0 :
    state = OkState(in);
    return;
  case 99: // ASCII 'c' for control
    SendCode(40,in); // 40 == 0x28 "Special command to videocamer"
    SendCode(40,in);
    toggleLed();
    Serial.print(in,BYTE);
    state = 0;
    return;
  default:
    state = 0;
    return;
    //READ
 //Serial.print("S: ");
 frameStartBitWait();
 for(int byteNum = 0; byteNum < 8; byteNum++) {
 byte in = readByte(rxPin,104);
 lowWait(rxPin);
 Serial.print(in,DEC);
 if (byteNum!=7)
 Serial.print(".");
 Serial.println(";");
void SendCode(int type,int code) {
  writeByte(rxPin,type,bitMicroSeconds);    // Video Cam Control
  lowWait(rxPin);
  writeByte(rxPin,code,bitMicroSeconds);  // Tele/Wide
void lowWait(int pin) {
  byte in = digitalRead(pin);
  while (in) {
void frameStartBitWait() {
  // finds thge start of a telegram/frame
  unsigned long usec = pulseIn(rxPin,HIGH);
  while (usec < 5864) { // 6230 experimentally with a RTV900
    /* DEBUG
     Serial.print(usec);
     Serial.println(" microseconds");
  /* DEBUG
   Serial.print("frame start after ");
   Serial.print(usec);
byte readByte(int pin,unsigned long uSec /* bit width*/ ) {
  byte result = 0;
  delayMicroseconds(uSec * 1.5); // skips the Start Bit and Land in the midlle of the first byte
  for (int i = 0; i < 8; i++) {
    if (digitalRead(pin) == LOW) { // == *LOW* because bits inverted in LANC
      result++;
    result <<= 1;
    delayMicroseconds(uSec);
  delayMicroseconds(0.5*uSec);
  return result; // return happens at end of last (8ths) bit
void writeByte(int pin, byte value, unsigned uSec /* bit width */) {
  delayMicroseconds(uSec); // wait for stop bit
  pinMode(pin,OUTPUT);
    boolean bit = value & 0x1;
    digitalWrite(pin,!bit); // NOT (!) pin because all data is inverted in LANC
    value >>= 1;
  pinMode(pin,INPUT); // return happends at end of last (8th) bit
void toggleLed() {
  // set the LED pin using the pinState variable:
  digitalWrite(ledPin, ledPinState);
  // if pinState = 0, set it to 1, and vice versa:
  ledPinState = !ledPinState;
up
Sophia-Antipolis (06)
Rejoignez le club !
Ah oui j'avais oublié smiley je regarde.
Ben c'est simple, il suffit de te connecter via une liaison série à l'Arduino, et d'envoyer un octet correspondant à une commande, et il se charge de l'envoyer via le LANC.
Bon... à mon avis il faut reprendre du début : qu'est ce que tu veux faire et qu'est ce qui te gêne dans ce code ?
« Last Edit: March 06, 2009, 09:17:50 am by julien@pobot.org » Logged
j'envoie les octets via le serial monitor
mais rien
exemple 27 ou 29 ect
27       rec start (DV)
29       rec stop (DV)
c'est exayer d'envoyer les octed en Hex , idem rien
au demarge la led pin 13 s'alume bien
puis quand j'envoie un octet la petite led rx clinote
la conection de l'arduino ver la camera est 100% bonne, je vais la reverifier pour la dixieme foi au cas ou
j'aie testé les autre soft basique d'arduino ex:des led cela marche bien
je doit me tromper quelque part peut etre les octet a envoyer
voici le fichier read me
What is it:
A MaxMSP(or Pd, or Any Serial App) to LANC Camera via Arduino Controller
Ok this a little rough, but works fine.
Steps:
1. Make a Lanc Cable & Connect Up the Ardunio
This is an "open connector" which i fully understand. Have a look below. Anyway get a 2.5" Stereo Connector from you local electronics store.
This is a Ring, Tip, Sleeve connector.
- Connect the Sleeve to GND of the Arduino Board
- Connect the Tip to the Digital PIN #3 on the Arduino Board
3. Build and Upload Ardunio Firmware
This is in Lanc_Ardunio.pde (Tested with Ardunio 10)
4. Run Max Patch
My patch only zooms at the moment but any "Special Command to Videocamera" (Ox28) can be sent.
Just send the following from your patch/serial programm
HEX CODE      MEANING
00        variable speed zoom Tele: slowest speed
02       variable speed zoom Tele: faster than 00
04       variable speed zoom Tele: faster than 02
06       variable speed zoom Tele: faster than 04
08       variable speed zoom Tele: faster than 06
0A       variable speed zoom Tele: faster than 08
0C       variable speed zoom Tele: faster than 0A
0E       variable speed zoom Tele: fastest speed
10       variable speed zoom Wide: slowest speed
12       variable speed zoom Wide: faster than 10
14       variable speed zoom Wide: faster than 12
16       variable speed zoom Wide: faster than 14
18       variable speed zoom Wide: faster than 16
1A       variable speed zoom Wide: faster than 18
1C       variable speed zoom Wide: faster than 1A
Rejoignez le club !
pour l'instant il n'arrive qu'à zoomer donc apparemment pas la peine d'essayer d'enregistrer, ce n'est pas au point.
est-ce que le câble est bon ?
Mon cable est bon
mais je n'arrive meme pas à zoomé de toute façon
je vaie refaire des test pour voir
merci pour tes reponses
