Author Topic: Compréhension de programme.  (Read 949 times)
Bonsoir à tous,
Voila un programme que j'ai trouvé sur ce forum il y à quelque mois, ce programme était réalisé par un certain "luj" si mes souvenirs son bon. Ce programme je l'utilisais sans cesse sans même me demander comment il fonctionne. J'ai donc décidé de l'analyser mais quelques questions renstent en suspent.
Ce programme permet de lire des chaines de caractères envoyés par port série:
// numerical value to be decoded after specific commands
int value = 0;
// where we currently are in the sequence construction or decoding
int indice = 0;
// the sequence of characters where is stored what the user wants
char commande[40]; // reduce the length to save memory (if necessary)
  // Start a new reception, reinit the browser index of the array
  indice = 0;
  // Fill-in the sequence of chars with all received characters
  while (Serial.available())
    commande[indice++] = Serial.read();
  // End the array with a specific character (E=End)
  // (means that you can't choose 'E' as a user meaning command
  commande[indice] = 'E';
  // Don't continue the loop if no command (adapt to your own code)
  if (indice == 0) return;
  // DEBUG Display that a new sequence has been found
  //Serial.print("> Received command, length=");
  //Serial.println(indice);
  // Start parsing the sequence array
  indice = 0;
  while (commande[indice] != 'E')
    // Reinit the numerical value
    value = 0;
    switch (commande[indice])
    case 'S':
      Serial.println("> Start command.");
      break;
    case 'G':
      // Continue to the next char (could contain the numerical value
      indice++;
      while (commande[indice] >= 48 && commande[indice] <= 57)
        value = value * 10 + (commande[indice]-48);
        // next digit
        indice++;
      // Back if no more digit to be added to numerical value
      indice--;
      Serial.print("> servo gauche : ");
      Serial.println(value,DEC);
      break;
    case 'D':
      indice++;
        // next digit
        indice++;
      indice--;
      Serial.print("> servo droit : ");
      break;
    default:
      //Serial.print("> unrecognized command : ");
      //Serial.println(commande[indice]);
      break;
    indice++;
Mes questions sont :
-Pourquoi initialiser "char commande[40]" et non pas à 0?
-Pourquoi   "while (Serial.available()) " et non pas   "while (Serial.available() > 0") ?
- Et pourquoi  "while (commande[indice] >= 48)" et non pas 40, 41, 42 ou 43...?
Mes questions vous sembleront peut être bêtes et inutiles mais je désire vraiment comprendre ce programme.
Par avance merci pour l'aide que vous m'apporterai !!  smiley
                                                       Maxime
Sophia-Antipolis (06)
Rejoignez le club !
C'est la taille maximale. Il est toujours nécessaire de donner une taille à un tableau, sinon il n'y a pas de mémoire disponible pour y mettre des valeurs
Cela revient au même. Le cas "false" correspond à une valeur de 0, et "true" à toutes les autres. Il est plus juste d'écrire la seconde forme, c'était un oubli de ma part.
48 est la valeur numérique du caractère ASCII '0'
en espérant que cela répondra à tes questions.
Merci pour tes réponses c'est exactement ce que je voulais savoir!
donc l'initialisation à 40 signifie qu'il est possible d'envoyer combien de caractères/chiffres?
encore une chose, lorsque j'envoie une valeur, comme par exemple pour ce programme "SG90", il entre bien dans la bougle "G" mais prend parfois la valeur 0. Est-ce que cela peut-être du à la taille du tableau?
Rejoignez le club !
40.
Non.
Trés bien! Merci encore pour tes réponse!
France
There is an Arduino for that
Je crois qu'il y a un problème de principe dans le switch. Lorsque tu trouve un G tu cherches le caractère suivant, mais rien ne t'assure qu'il est déjà arrivé. Il ne faut pas perdre de vu qu'une liaison série c'est lent par rapport à la vitesse d'exécution du processeur.
Il faut faire une machine à état qui tienne compte du fait que les caractères sont lus à la volée et par conséquent si tu attend un argument pour l'une des commandes il faut s'assurer que le caractère est bien arrivé avant de l'interpréter. Sinon tu lis des anciennes données qui se trouvent dans le buffer de réception.
« Last Edit: June 19, 2009, 11:39:25 am by fdufnews » Logged
Rejoignez le club !
Le switch ne fait pas de lecture de la liaison série, il traite une commande reçue et accumulée dans un tableau. Ce qu'il faut donc ajouter pour prendre en compte la judicieuse remarque de fdufnews, c'est une vérification de la chaine reçue, juste avant la fermeture avec le caractère 'E'.
