Bonjour a tous,
j'ai voulu reproduire le montage de jasonbabcock (.com/computing/breadboard/pantable1/index.html) mais sur Arduino...
L'article montre stepperMotor monté sur un I/O board via ULN2004A
materiel à disposition:
> Arduino Duemilanove
>ULN2004AG
> PM55l-048-HPG9
> PM35L-048L-HPD4
> transformater 220V -> 24V 830mA 20VA
> transformater 220V -> 12V 300mA 3.6VA
> breadboard et quelques fils
Le seul résultat obtenu est la montée de température de l'ULN...
Quelqu'un aurait t'il un support?
Simple Stepper motor test, call manualy each pin
Following the page:
jasonbabcock. dot com/computing/breadboard/pantable1/index.html
This appears to fail...
the only thing is the ULN is going hotter and hotter...
arduino? ULN2003A PM55L Mineba
. ______
5 -------- 1 -| |- 16 -------- orange
4 -------- 2 -| |- 15 -------- yellow
3 -------- 3 -| |- 14 -------- tan
2 -------- 4 -| |- 13 -------- black
----------- 5 -| |- 12
----------- 6 -| |- 11
----------- 7 -| |- 10
ground ---- 8 -|____|- 9 --------
. |___
. |___|--red 1 / red 2
. + 12 V __|
pm55l mineba "datashit"
| | _|_ | |
A3 B3 A2 B2 A1 B1
clockWise
1> A1 B3
2> A1 B1
3> A3 B1
4> A3 B3
counterCllockWise
1>
4>
3>
2>
1>
Array
a1 Black | A3 brown | B1 Orange | B3Yellow | A2 B2 Red
1 - | | | - | + |
2 - | | - | | + |
3 | - | - | | + |
4 | - | | - | + |
other sequence to test
1> 1010
2> 0110
3> 0101
4> 1001
Stepper Motor Controller
language: Wiring/Arduino
This program drives a unipolar or bipolar stepper motor.
The motor is attached to digital pins 8 and 9 of the Arduino.
The motor moves 100 steps in one direction, then 100 in the other.
// define the pins that the motor is attached to. You can use
// any digital I/O pins.
int MotorPin1= 5;
int MotorPin2= 4;
int MotorPin3= 3;
int MotorPin4= 2;
int delayTime=50;
digitalWrite(MotorPin1,HIGH);
digitalWrite(MotorPin2,LOW);
digitalWrite(MotorPin3,HIGH);
digitalWrite(MotorPin4,LOW);
delay(delayTime);
digitalWrite(MotorPin1,LOW);
digitalWrite(MotorPin2,HIGH);
delay(delayTime);
digitalWrite(MotorPin3,LOW);
digitalWrite(MotorPin4,HIGH);
delay(delayTime);
delay(delayTime);
Le code et le pictogrammes s'affichent mieux dans arduino desolé
si quelqu'un pourrait me donner un coup de main
Par avance, Merci
