Loading...
Pages: [1]   Go Down
Author Topic: Aide pour comprendre tuto  (Read 663 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
Salut,
j'aimerai réaliser ce tuto http://arduino.cc/en/Tutorial/Dimmer  avec ma Arduino Duemilanove mais je ne comprends pas ou il faut marquer ce texte:
Code:
Processing Code
Run the following sketch in Processing. It will send bytes out the serial port to the Arduino to dim the LED.
 /* Processing code for this example */
  // Dimmer - sends bytes over a serial port
  // by David A. Mellis
  // This example code is in the public domain.
  import processing.serial.*;
  Serial port;
  size(256, 150);
  println("Available serial ports:");
  println(Serial.list());
  // Uses the first port in this list (number 0).  Change this to
  // select the port corresponding to your Arduino board.  The last
  // parameter (e.g. 9600) is the speed of the communication.  It
  // has to correspond to the value passed to Serial.begin() in your
  // Arduino sketch.
  port = new Serial(this, Serial.list()[0], 9600);
  // If you know the name of the port used by the Arduino board, you
  // can specify it directly like this.
  //port = new Serial(this, "COM1", 9600);
  void draw() {
  // draw a gradient from black to white
  for (int i = 0; i < 256; i++) {
  stroke(i);
  line(i, 0, i, 150);
  // write the current X-position of the mouse to the serial port as
  // a single byte
  port.write(mouseX);
Et est ce que ce projet est réalisable avec ma carte ? Ou faut'il ajouter des extensions?
Merci d'avance
Logged
Geneva
Offline Offline
Faraday Member
Yoplait... le pt'it suisse
View Profile
WWW
Ce code est fait sous Processing.
Comme Arduino, mais tu fais tourner ça sur ton ordi via l'IDE Processing qui recompile le tout en Java.
Logged
MacBook intel core 2 duo  os X snow Leopard 10.6
eMac PPc G4  os X Leopard 10.5
powerbook G4 os X Leopard 10.5
imac PPC G3 os X Panther 10.3.9
Arduino Diecimila
Arduino Mega
Arduino Standalone
Arduino 1307.04
0
Offline Offline
Newbie
Arduino rocks
View Profile
Ah ok, merci beaucoup smiley
PS: au passage est ce que tu as un site pour apprendre à se débrouiller avec une Arduino Duemilanove (en francais si possible :-[ )stp
Logged
Geneva
Offline Offline
Faraday Member
View Profile
WWW
http://www.mon-club-elec.fr/pmwiki_mon_club_elec/pmwiki.php?n=MAIN.ARDUINO
Logged
Arduino Diecimila
Arduino Mega
Arduino Standalone
Arduino 1307.04
0
Offline Offline
Newbie
Arduino rocks
View Profile
Ah ah, super merci beaucoup smiley
Logged
Geneva
Offline Offline
Faraday Member
View Profile
WWW
De rien et bon début  smiley-wink
Logged
Arduino Diecimila
Arduino Mega
Arduino Standalone
Arduino 1307.04
Pages: [1]   Go Up
Print
Jump to:
