Topic: Hm-10 ble device not working (Read 41415 times) previous topic - next topic
piyushsud
I am trying to change the baud rate on my hm10 bluetooth low energy module using AT commands from the serial monitor. I have tried connecting a usb cable from the computer to my arduino uno and uploading many different programs, none of them work. Can someone please tell me exactly how to change the baud rate to 115200 and give me the correct code? The default baud rate of the hm10 module is 9600.
leogar07
The sketch I use to communicate with my HM-10 is
Code: [Select]
#include <SoftwareSerial.h>
SoftwareSerial BTSerial(11, 10); //RX|TX
void setup(){
  BTSerial.begin(9600); // default baud rate
  while(!Serial); //if it is an Arduino Micro
  Serial.println("AT commands: ");
void loop(){
  //read from the HM-10 and print in the Serial
  if(BTSerial.available())
    Serial.write(BTSerial.read());
  //read from the Serial and print to the HM-10
  if(Serial.available())
    BTSerial.write(Serial.read());
With this sketch you should get to send the AT commands, I think you also have to take out the carriage return and linde feed options in the Serial Terminal.
Send "AT", sometimes the first one does not work, send it again. You should recieve "OK" as a response.
To change the baud rate to 115200 send "AT+BAUD4" and the response should be "Set:OK4"
I recommend reading it's datasheet
http://www.seeedstudio.com/wiki/images/c/cd/Bluetooth4_en.pdf
Cheers
piyushsud
I tried uploading this sketch to my arduino at 9600 baud, no line ending. However, this did not work. I think the sketch is right, but my bluetooth device might be faulty.
piyushsud
Your bluetooth module works right? Can you tell me which bluetooth module you have(specifically because I want to buy the exact same one)?
4ntoine
You can wire TX0/RX0 with Uno f.e. and it works. Checkout Apploader iOS app that allows to use HM-10 for uploading over BLE. You can find schematics at the link too
systems110
I tried this sketch too but all it returns is AT Commands:
Where is the problem, please guide
ratep2001
Are you sure that you are using an HM-10 and not a copy like Bolutek CC-41A? I have also bought some BLE modules marketed as HM-10 on the ebay, but they turned out to be CC-41A.
Although both modules look very similar, CC-41A requires that AT commands are terminated by LF+CR and there are differences in the command set. I am not sure if there are any other differences in the hardware, but I experienced that I cannot turn CC-41A into iBeacon mode or at least I cannot see it on my iPhone iBeacon scanner app after running the HM-10 iBeacon initialization sequence.
I have written few posts on different forums and hope somebody will come with some more information on how this problem can be solved. If you have any experience with CC-41A please share...
dmjlambert
Just curious, how did you figure out you had CC-41A?
cysign
Damn....I bought y couple of HM-10 on ebay....or better say CC41-A.
If you enter AT+VERSION you'll get something like:
+VERSION=Firmware V3.0.6,Bluetooth V4.0 LE
If you tra AT+HELP you'll get:
* Command             Description                    *
* AT                  Check if the command terminal work normally  *
* AT+RESET            Software reboot               *
* AT+VERSION          Get firmware, bluetooth, HCI and LMP version *
* AT+HELP             List all the commands                 *
* AT+NAME             Get/Set local device name                    *
* AT+PIN              Get/Set pin code for pairing                 *
* AT+PASS             Get/Set pin code for pairing                 *
* AT+BAUD             Get/Set baud rate                         *
* AT+LADDR            Get local bluetooth address         *
* AT+ADDR             Get local bluetooth address         *
* AT+DEFAULT          Restore factory default            *
* AT+RENEW            Restore factory default            *
* AT+STATE            Get current state               *
* AT+PWRM             Get/Set power on mode(low power)          *
* AT+POWE             Get/Set RF transmit power          *
* AT+SLEEP            Sleep mode                          *
* AT+ROLE             Get/Set current role.                      *
* AT+PARI             Get/Set UART parity bit.                     *
* AT+STOP             Get/Set UART stop bit.                       *
* AT+START            System start working.            *
* AT+IMME             System wait for command when power on.      *
* AT+IBEA             Switch iBeacon mode.                      *
* AT+IBE0             Set iBeacon UUID 0.                          *
* AT+IBE1             Set iBeacon UUID 1.                          *
* AT+IBE2             Set iBeacon UUID 2.                          *
* AT+IBE3             Set iBeacon UUID 3.                          *
* AT+MARJ             Set iBeacon MARJ .                          *
* AT+MINO             Set iBeacon MINO .                          *
* AT+MEA              Set iBeacon MEA .                          *
* AT+NOTI             Notify connection event .                    *
* AT+UUID             Get/Set system SERVER_UUID .                  *
* AT+CHAR             Get/Set system CHAR_UUID .                  *
* Note: (M) = The command support slave mode only.          *
* For more information, please visit http://www.bolutek.com        *
* Copyright@2013 www.bolutek.com. All rights reserved.         *
Bolutek sells CC41-A, not HM-10.
And on an CC41-a 'at+help' will work the same way as 'AT+HELP', while HM-10 should be casesensitive.
Is there a chance to use the HM-10 firmware anyway?
edugimeno
Several hints that will tell you it's a CC41-A clone:
-It's missing a crystal in the top left corner (placing the Bluetooth antenna on top facing you)
See http://wiki.makespacemadrid.org/images/7/72/HM-10-fake.jpg
-It needs CR+LF terminated commands to reply. Original HM-10 will reply to any unterminated AT commands
-Doesn't support usual commands like AT+ADTY3  or AT+DELO2 needed for best performance as a beacon. When you issue an unsupported command you don't get any reply at all in a clone
-First commands you try, like AT+VERR? or AT+VERS? following usual guides don't return anything.
Im telling you as I fell for one of this. I found an article on how to flash them (using an arduino in between) with the original HM-10 firmware thou
Thank you
dmjlambert
#10
Jan 21, 2016, 05:39 am Last Edit: Jan 21, 2016, 05:40 am by dmjlambert
Can you give a link to the article that shows how to flash them please?
edugimeno
No luck... I tried to follow the directions myself to flash them but after downloading the .ino and the windows .exe, next step was to download the firmware (according to the author, the firmware in the original board website was not usable as it was missing the boot loader and something else) but the guy who had the special firmware in his website had removed it as he had abandoned the project. I've spent hours looking for another mirror or site hosting the same file with no luck...sorry
egarcha
Hi leogar07. Your sketch worked perfectly after I realised that I had a less than original copy and that I had to add the CR+LF. My question is, do you, or anybody else for that matter, know why I can't do the same with the Arduino UART? Instead of using a software serial port, I would like to use the hardware UART that comes with the UNO (Rx and Tx) but I canĀ“t seem to get it to work
Thanks in advance
Hexor
I also try to burn firmware on a copy of HM-10 (based on a CC2541), I have found how to flash the CC2541 using Arduino but don't find the original firmware of the HM10 :/
Can you post the link to the article where it explain that the original firmware is not good ?
Thanks,
arcon19
#14
Apr 06, 2016, 01:57 am Last Edit: Apr 06, 2016, 02:25 am by arcon19
Hello,
I am trying to setup my HM-11 module using the code above. I have the AT command responding with an OK however whenever I try to get anything else working I don't get a response or I just receive null values. I tried sending AT+DEFAULT and AT+RESET to just restart the entire module back to factory settings, however there is still no proper response other than the nulls. I also tried resetting the baud rate to what I hoped was the default, however again there is no proper response. I tried ever baud setting within Realterm and nothing happens.
I was able to set up the device earlier viewing the MAC address and setting the mode to Master, however since then I'm out of luck regarding responses.
Thanks,
