Topic: Upload/download of EEPROM (Read 1 time) previous topic - next topic
I would like the IDE to support upload and download of the EEPROM contents..
It could be done by
) installation of a utility sketch
) extending boot-loader functionality
Otherwise, I **think** the process of getting EEPROM data out of Arduino is OS specific and awkward.
Anticipated uses:
>Storing configuration in EEPROM -  and a maintenance utility for config.
>Retrieval of data logged in EEPROM.
I think the simplest IDE interface would be read/write named files?
I think that would be a great idea.
... extending boot-loader functionality
The current bootloader supports both reading from and writing to EEPROM through the STK500 protocol. Avrdude has an interactive mode that does a half-decent (DOS like) interface for reading/writing eeprom (screen or file) which is quite useful if needed.
The Arduino IDE will aslo produce an EEPROM image when you compile a sketch with EEPROM tagged data. Upload of this image however is manual.
So the tools are there if you learn to use them, but it most certainly would not hurt with an IDE integrated viewer/upload/download extension (e.g. graphical).
i am of to play with what is there now :)
thanks for the pointers
I have had a frustrating play with the Arduino GUI,
I found EEMEM mentioned in the forum as being supported in v13 and I am using v18 so I had high hopes, but no joy when I tried it.
The compiler sees EEMEM as an identifier, not a memory modifier like 'static'.
There is no mention on arduino.cc of EEMEM outside the forums and a playground request that it be fixed :(.
Found doc for PROGMEM and tried that (including avr/pgmspace.h as specified) and have the same issue.
Search the arduino-018 installation for EEMEM/ mentioned only in readme.txt.
Search for PROGEM, mentioned in HTML and bootloaders, tone.cpp, pins_arduio.[c,h] and Tone.cpp.
I guess something is broken:(
I suspect compiler issue/ but this version is ok [based on google search]
avr-gcc --version
avr-gcc (GCC) 4.3.2
What have I missed ?
Of to play with avrdude for a bit.
Confirm your email address
Thank you for subscribing!
via Egeo 16
Torino, 10131
