Topic: AJAX ESP8266 + ARDUINO (Read 6532 times) previous topic - next topic
elik745i
Oct 15, 2015, 12:59 pm Last Edit: Oct 15, 2015, 01:00 pm by elik745i
Could some one help me to modify sketch to work through AJAX requests, no over updating page each time by sending GET requests, quite annoing...
Code: [Select]
#include <SoftwareSerial.h>
#include <ESP8266pro.h>
#include <ESP8266proServer.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#define DEBUG true
const int  RX=10;
const int  TX=11;
const int  ts=9;     //temp sensor DS18B20
const int  il=13;    //indicator led
const int  ms=12;    //master switch relay
  #define ONE_WIRE_BUS ts
  OneWire oneWire(ONE_WIRE_BUS);
  DallasTemperature sensors(&oneWire);
const int   TN = 1400;                  //tone
float t;            //temperature
unsigned long previousMillis = 0;         //check sensors
const long interval = 60000;               //Sampling interval time mSec
const long COM_BAUD = 38400;                       //ESP UART baudrate
const String mode = "1";                           //1 - Client, 2 - Access Point, 3 - Both
const String ssid = "sazz Wireless Network";       //Network SSID
const String password = "Samir2012A";              //Network Password
const String ipaddress = "192.168.0.201";          //Desired IP address
const String subnetworkmask = "255.255.255.0";
const String gateway = "192.168.0.1";
SoftwareSerial esp8266(RX, TX); // RX, TX
ESP8266pro wifi(esp8266, Serial);
ESP8266proServer server(wifi, onClientRequest);
String requestPaths[ESP_MAX_CONNECTIONS];
    pinMode(ts, INPUT);
    esp8266.begin(COM_BAUD);
    Serial.begin(COM_BAUD);    //for debug
  sendData("AT+RST\r\n",3400,DEBUG); // reset module
  sendData("AT+GMR\r\n",2000,DEBUG); // Sofware version
  sendData("AT+CWMODE="+mode+"\r\n",1000,DEBUG); // configure as access point
  sendData("AT+CWJAP=\""+ssid+"\",\""+password+"\"\r\n",10000,DEBUG); // connect to AP
  sendData("AT+CIPSTA_DEF=\""+ipaddress+"\",\""+gateway+"\",\""+subnetworkmask+"\"\r\n",1000,DEBUG); // set ip address
  sendData("AT+CIPMUX=1\r\n",1000,DEBUG); // configure for multiple connections
  //sendData("AT+CIPSERVER=1,80\r\n",1000,DEBUG); // turn on server on port 80
  // Start server on port 80
  server.start(80);
  Serial.println("=================================");
  Serial.println("Server started: http://" + ipaddress);
  sensors.begin();  //for dallas temp sensor
  checkSensors();   //check all available sensors and save values to RAM
  digitalWrite(il,HIGH);
  digitalWrite(il,LOW);
    void loop() {        // Process incoming requests
                          server.processRequests();
                          if(currentMillis - previousMillis >= interval)
                          checkSensors();
        void onClientRequest(ESP8266proConnection* connection,
        char* buffer, int length, boolean completed) {
          Serial.print(buffer);
          if (strncmp(buffer, "GET ", 4) == 0)   {
            // We found GET HTTP request
            char* p = strstr(buffer + 4, " ");
            *p = '\0'; // erase string after path
            requestPaths[connection->getId()] = (String)((char*)buffer + 4);   }
            if (completed)   {     String path = requestPaths[connection->getId()];
            if (path == "/")
              connection->send(F(
                "HTTP/1.0 200 OK\r\n\r\n"
                "<head>"
                "<meta http-equiv='refresh' content='300'>"
                "<title>ESP8266 + ARDUINO</title>"
                "</head>"
                "<body>"
                "<div id=\"changedDiv\" style=\" width: 250px;  height: 250px; border-radius: 14px; box-shadow: rgb(0, 0, 0) 0px 0px 20px; opacity: 1;"
                "<div style=\"padding-right:20px; padding-left:20px; padding-top:20px; padding-bottom:20px;\">"
                "<h1 align=\"center\">ESP8266 + ARDUINO</h1><br>"));
              connection->send(F(
                      "<h2> Temp = "
                      connection->send(String(t));
            if(digitalRead(ms)==LOW){
              connection->send(F(
                        "<br><br><input type=\"button\" onclick=\"window.location.href='/led2'\" value=\"Switch is OFF\" />"
            }else{
               connection->send(F(
                        "<br><br><input type=\"button\" onclick=\"window.location.href='/led3'\" value=\"Switch is ON\" />"
              connection->send(F(
                        "</div>"
                        "</div>"
                        "</body>"
                        "</html>"
            else if (path.startsWith("/led"))
                           if (path.substring(4) == "0"){
                            masterswitchOn();
                            Serial.println("Turning masterswitch ON");
                            connection->send(F(
                            "<html>"
                            "<meta http-equiv='refresh' content='1; url=/' />"
                            "</html>"
                            if (path.substring(4) == "1")
                              masterswitchOff();
                              Serial.println("Turning masterswitch OFF");
                              connection->send(F(
                            "<html>"
                            "</html>"
              else     {
                            connection->send(F("HTTP/1.0 404 Not Found\r\n\r\n"));
                            connection->send(F("<h1>4 0 4</h1>"));
                            connection->send(F("Yes, this is true. :("));
                             connection->close();
void checkSensors(){
                      sensors.requestTemperatures();     // Send the command to get temperatures
                      t = sensors.getTempCByIndex(0);
                      Serial.print("Temperature = ");
                      Serial.print(t);
                      Serial.println(" Celsius");
void masterswitchOn(){
                      digitalWrite(ms,HIGH);
void masterswitchOff(){
                      digitalWrite(ms,LOW);
String sendData(String command, const int timeout, boolean debug)
    String response = "";
    esp8266.print(command); // send the read character to the esp8266
    long int time = millis();
    while( (time+timeout) > millis())
      while(esp8266.available())
        // The esp has data so display its output to the serial window
        char c = esp8266.read(); // read the next character.
        response+=c;
    if(debug)
      Serial.print(response);
    return response;
libraries here
Wake up NEO...
Robin2
Do you know how to make AJAX work on a PC (rather than an Arduino)?
If not I suggest you learn the technique on your PC and then you will know what needs to happen on the Arduino. There is no shortage of online info about how to do it on a PC.
This is not really an Arduino Forum problem.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
elik745i
Finally I MADE IT!!!
Enjoy, and through your ethernet modules into garbage bin!
Code: [Select]
#define DEBUG true
const int  RX=10;
const int  TX=11;
const String ssid = "yourwifissid";       //Network SSID
const String password = "yourwifipassword";              //Network Password
const String apipaddress = "192.168.4.1";          //Desired IP address
const String cipaddress = "192.168.0.201";          //Desired IP address
    pinMode(7, INPUT);        // switch is attached to Arduino pin 7
    pinMode(8, INPUT);        // switch is attached to Arduino pin 8
    pinMode(ts, INPUT);
    pinMode(ms, OUTPUT);
    pinMode(il, OUTPUT);
  sendData("AT+CIPSTA_DEF=\""+cipaddress+"\",\""+gateway+"\",\""+subnetworkmask+"\"\r\n",1000,DEBUG); // set ip address
  server.start(80);
  if(mode=="1"){
  Serial.println("Server started: http://" + cipaddress);
  if(mode=="2"){
  Serial.println("Server started: http://" + apipaddress);
  if(mode=="3"){
  Serial.println("Server started:");
  Serial.println("Access Point: http://" + apipaddress);
  Serial.println("Client: http://" + cipaddress);
                 delay(100);
       //if (path == "/")
       if (path.startsWith("/ajax_switch&nocache="))
              Serial.println("AJAX request received");
                if (digitalRead(7)) {
                connection->send(F("<p>Switch 7 state: ON</p>"));
                else {
                connection->send(F("<p>Switch 7 state: OFF</p>"));
               if (digitalRead(8)) {
                connection->send(F("<p>Switch 8 state: ON</p>"));
              else {
                connection->send(F("<p>Switch 8 state: OFF</p>"));
              // read analog pin A2
               int analog_val = analogRead(2);
               connection->send(F("<p>Analog A2: "));
               connection->send(String(analog_val));
               connection->send(F("</p>"));
       else if (path == "/"){
             connection->send(F(
                "HTTP/1.1 200 OK\r\n\r\n"
                "<!DOCTYPE html>\r\n"
                "<html>\r\n"
                "<head>\r\n"
                "<title>Arduino Web Page</title>\r\n"
                "<script>\r\n"
                "function GetSwitchAnalogData() {\r\n"
                "nocache = \"&nocache=\" + Math.random() * 1000000;\r\n"
                "var request = new XMLHttpRequest();\r\n"
                "request.onreadystatechange = function() {\r\n"
                "if (this.readyState == 4) {\r\n"
                "if (this.status == 200) {\r\n"
                "if (this.responseText != null) {\r\n"
                "document.getElementById(\"sw_an_data\").innerHTML = this.responseText;\r\n"
                "}}}}\r\n"
                "request.open(\"GET\", \"ajax_switch\" + nocache, true);\r\n"
                "request.send(null);\r\n"
                "setTimeout('GetSwitchAnalogData()', 1000);\r\n"
                "}\r\n"
                "</script>\r\n"
                "</head>\r\n"
                "<body onload=\"GetSwitchAnalogData()\">\r\n"
                "<h1>Arduino AJAX Input</h1>\r\n"
                "<div id=\"sw_an_data\">\r\n"
                "</div>\r\n"
                "</body>\r\n"
                "</html>\r\n"));
           delay(10);
                      Serial.print(t);
        response+=c;
    if(debug)
    return response;
Wake up NEO...
niq_ro
#3
Oct 29, 2015, 07:37 am Last Edit: Nov 03, 2015, 06:33 pm by niq_ro
I try with Arduino Mega on Serial2 and put "refresh" at 5 seconds and is ok ... :)
PS: put "refresh" at 15 seconds and with 3 clients are ok: https://youtu.be/c8St6GkD2cM
is not better to reinvent the wheel, but to improve it's less work and better results
