I have the screen somewhat working using the LiquidCrystal_I2C Library. It is connected to a Arduino Mega 2560 and the SDA and SCL pins are connected to the SDA and SCL on the Mega. However when I use the following code
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27,20,4); // set the LCD address to 0x27 for a 20 chars and 4 line display
lcd.init(); // initialize the lcd
// Print a message to the LCD.
lcd.backlight();
lcd.print("Hello, world!");
lcd.print("Hello");
It only prints out the first character of the phrase. I have tried a different phrase and it does the same thing. Prints "H"
Is the problem with the Library.
Any help appreciated Thanks
#include <Wire.h>
lcd.backlight();
lcd.print("Hello");
Sorry I have same problem it seems that the LCD.print only wright one "X" to get one more I have to set the lcd.setCursor(3,0); to next one
It may be the IED have read that some other have it to work in a other IED
I tried leaving the loop empty but it does not help. Having the lcd.print("Hello"); in the setup just prints H out once on the screen, instead of continuous. If I spell out each letter by itself per command I can get it to display the word I want but that is a waste of time. Also the lines are messed up in the loop it fills one line then skips a line fills that, then returns to the line it skipped. Does any one what is wrong?
Unfortunately there's nothing wrong with this behavior. It's a 'feature' of the LCD controller. For the full story follow the LCD Addressing link at http://web.alfredstate.edu/weimandn.
Now back to this:
Which library are you referring to? There are lots of them, all with the same name.
floresta:
I suggest you try the 'New LiquidCrystal Library' by Francisco Malpartida. You can get it here.
It's just a pity that the bloody-mindedness of the Arduino team is here exhibited in not including this most important library in the ever-bloated distribution of the IDE, preferring to include four versions of the useless one!
Guys,
This sounds like it is possible that it is an issue not related to a library misconfiguration.
The posters are saying that the EXACT same code and sketch works with 1.6.5 and doesn't work with 1.6.6
the symptom being that only the first character shows up on the LCD with 1.6.6
If this is the case, then it is possible that there could be an I2C issue in 1.6.6
common_ground, you are saying that you have modified a library to make it work with 1.6.6 ?
What was the modification?
--- bill
NEVERMIND.
I see the problem.
While it is technically an issue in the lcd library, it is caused by a change in the IDE Print class code.
Team arduino.cc has decided to change the write() function to allow asynchronous i/o.
The way that they have done this is VERY bad and has MANY issues with print() functions.
I'll go jump on them and try to explain why they simply can not do the code this way.
i.e. you can't break print() functions. Those must be synchronous and not return until all their i/o is completed unless you have a class option to enable/disable it (which they don’t').
common_ground:
New IDE 1.6.6 Print function is different from previous versions , explained here : LCD write() functon changes
Just small modification, but solve big problem.
I saw that and while this specific issue was caused by some broken code in an LCD library,
there is a larger issue related to partial i/o in the Print class print() functions that needs to be dealt with.
I posted lengthy post in that thread about it.
--- bill
Ok guys thanks for all the feedback using an older edition of the Arduino IDE solved the displaying 1st letter problem however it did not solve the jumping lines problem. Common_Ground's Library is awesome however it also has not solved the line jumping problem. Does anyone know how to fix this last problem? Really appreciate all the advice. As a I said above the display fills the first line skips and fills the third goes back to the second and then fills the fourth. Thanks
Read the link in Don's post about how memory is mapped to the LCD screen.
It is not a s/w bug. That is the way the hardware works.
You can't fill the screen using linear memory addresses.
You have to use the cursor positioning calls to set the cursor to the beginning of each line.
When you do that, the library s/w will do the correct conversion to get the proper memory address for the line you want.
tom15:
... it also has not solved the line jumping problem. Does anyone know how to fix this last problem?
So in short, it's not a problem at all!
This (variety of) display is simply not suited to displaying freehand text such as I type here for the discussion board. There is simply no need for line wrap - to say nothing of word wrap - or indeed (vertical) scrolling. Nor is horizontal scrolling particularly appropriate either though there are some facilities for this.
All you will need to do with this display, is to have a piece of information displayed in a given position on the screen. The fact that you need to carefully plan on where that piece of information goes, what size it is, how it might interact with other information, even how it might interact with information previously written in the same place (which happens when you print a smaller number over a previous larger version) is just part of the process. "Line Feed" is meaningless on such a display - if you even attempt to send such codes, you get only a character from the PCG RAM.
lcd.setCursor(); is your friend.
(We need a proper tutorial on this to point to, don't we?)
#include <Wire.h>
lcd.backlight();
lcd.print("Hello");
I have been having the same problem. A character prints in place of what would be the 2nd character in the string that appears to look like 3 stacked lines (like some "menu" icons.)
I opened and read the LCD (ect) .H file. and found the calls that can be made. I tried inserting lcd.clear, lcd.blink, lcd.home, etc. and all seem to work.
I can move the cursor around on the display but cannot. Println seems to cause the line to move to the next down. But nothing about this makes any sense. I got this display from Amazon as a replacement for the first one I got from them that behaved exactly the same. I am new to Arduino but have lots of prior BASIC experience am not frighten by technology. Finding a solution to this is not a life or death matter. I am just tenacious when confronted by something that doesn't work right.
Any hints for a solution would be appreciated
Mike
mike_flood,
You have a broken lcd library. It is not returning the proper return value from write() so the print() code that calls it thinks that there was an error and throws away all the remaining output after the first character.
To fix it, update your library library, or use a different library.
