Topic: <Conceptinetics.h> (Read 1 time) previous topic - next topic
bahman89
Hi to all
I can't download <Conceptinetics.h> header. I received "server error" for several time.
Could you please help me?
If anybody have it, Please send to my E-mail address as below:
bahmansotoudeh@yahoo.com
Thanks,Bahman
jurs
That's strange. The file is contained in the ZIP archive of Conceptinetics.zip (2013-06-24).
This is the file extracted from that ZIP archive date stamp 2013-06-24:
Code: [Select]
  Conceptinetics.h - DMX library for Arduino
  Copyright (c) 2013 W.A. van der Meeren <danny@illogic.nl>.  All right reserved.
  This library is free software; you can redistribute it and/or
  modify it under the terms of the GNU Lesser General Public
  License as published by the Free Software Foundation; either
  version 3 of the License, or (at your option) any later version.
  This library is distributed in the hope that it will be useful,
  but WITHOUT ANY WARRANTY; without even the implied warranty of
  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
  Lesser General Public License for more details.
  You should have received a copy of the GNU Lesser General Public
  License along with this library; if not, write to the Free Software
  Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
  This code has been tested using the following hardware:
  - Arduino UNO R3 using a CTC-DRA-13-1 ISOLATED DMX-RDM SHIELD
  - Arduino MEGA2560 R3 using a CTC-DRA-13-1 ISOLATED DMX-RDM SHIELD
#ifndef CONCEPTINETICS_H_
#define CONCEPTINETICS_H_
#include <Arduino.h>
#include <inttypes.h>
#define DMX_MAX_FRAMESIZE       513     // Startbyte + 512 Slots
#define DMX_MIN_FRAMESIZE       2       // Startbyte + 1 Slot
#define DMX_MAX_FRAMECHANNELS   512     // Maxmim number of channer per frame
#define DMX_STARTCODE_SIZE      1       // Size of startcode in bytes
#define DMX_START_CODE          0x0     // Start code for a DMX frame
#define RDM_START_CODE          0xcc    // Start code for a RDM frame
// Uncomment to enable interbyte gaps
// #define DMX_IBG     10      // Interbyte gap
// Speed your Arduino is running on in Hz.
#define F_OSC 16000000UL
// DMX Baudrate, this should be 25000
#define DMX_BAUD_RATE 250000
// The baudrate used to automaticly generate a break within
// your ISR.. make it lower to generate longer breaks
#define DMX_BREAK_RATE 99900
namespace dmx
    typedef enum dmxState
dmxIdle,
dmxBreak,
        dmxManualBreak,
dmxStartByte,
        dmxFrameDetected,
dmxRecordData,
dmxData
class DMX_FrameBuffer
    public:
        // Constructor buffersize = 1-513
        DMX_FrameBuffer     ( uint16_t buffer_size );
        DMX_FrameBuffer     ( DMX_FrameBuffer &buffer );
        ~DMX_FrameBuffer    ( void );
        uint16_t getBufferSize ( void );
        uint8_t getSlotValue ( uint16_t index );
        void    setSlotValue ( uint16_t index, uint8_t value );
        void    setSlotRange ( uint16_t start, uint16_t end, uint8_t value );
        void    clear ( void );
        uint8_t &operator[] ( uint16_t index );
    private:
        uint8_t     *m_refcount;
        uint16_t    m_bufferSize;
        uint8_t     *m_buffer;
class DMX_Master
    public:
        // Run the DMX master from a pre allocated frame buffer which
        // you have fully under your own control
        DMX_Master ( DMX_FrameBuffer &buffer, int readEnablePin  );
        // Run the DMX master by giving a predefined maximum number of
        // channels to support
        DMX_Master ( uint16_t maxChannel, int readEnablePin );
        ~DMX_Master ( void );
        void enable  ( void );              // Start transmitting
        void disable ( void );              // Stop transmitting
        // Get reference to the internal framebuffer
        DMX_FrameBuffer &getBuffer ( void );
        // Update channel values
        void setChannelValue ( uint16_t channel, uint8_t value );
        void setChannelRange ( uint16_t start, uint16_t end, uint8_t value );
    public:
        // Manual control over the break period
        void setAutoBreakMode ( void );     // Generated from ISR
        void setManualBreakMode ( void );   // Generate manually
        uint8_t autoBreakEnabled ( void );
        // We are waiting for a manual break to be generated
        uint8_t waitingBreak ( void );
        // Generate break and start transmission of frame
        void breakAndContinue ( uint8_t breakLength_us = 100 );
    protected:
        void setStartCode ( uint8_t value );
    private:
        DMX_FrameBuffer m_frameBuffer;
        int             m_re_pin;
        uint8_t         m_autoBreak;
class DMX_Slave
    public:
        DMX_Slave ( DMX_FrameBuffer &buffer, int readEnablePin = -1 );
        DMX_Slave ( uint16_t nrChannels, int readEnablePin = -1 );
        ~DMX_Slave ( void );
        void enable     ( void );           // Enable receiver
        void disable    ( void );           // Disable receiver
        uint8_t  getChannelValue ( uint16_t channel );
        uint16_t getStartAddress ( void );
        void     setStartAddress ( uint16_t );
        // Register on receive complete callback in case
        // of time critical applications
        void onReceiveComplete ( void (*func)(void) );
    protected:
        // Startcode is default set to record dmx frames but
        // can be used using this function.
        // This is intended for future use
        void setStartCode ( uint8_t value = DMX_START_CODE );
    public:
        static void (*event_onFrameReceived)(void);
    private:
        int             m_re_pin;
        uint16_t        m_startAddress;     // Slave start address
#endif /* CONCEPTINETICS_H_ */
I downloaded the ZIP archive from http://sourceforge.net/projects/dmxlibraryforar/files/
