Arduino Forum
Products
Create
Editor
(Moderator:
smellai
Welcome to the Arduino Web Editor
Print
Pages:
1
[2]
3
Topic: Welcome to the Arduino Web Editor
(Read 10856 times)
previous topic
next topic
ballscrewbob
Global Moderator
? < This is a question. Try to answer
Faraday Member
[add]
Re: Welcome to the Arduino Web Editor
#15
Mar 08, 2017, 02:53 am
@ ernstc
As it stands my understanding is that it is meant for all.
And by that i include the many newcomers to "Arduino" who would probably quit if they had to start and learn VS etc.
For those much more advanced they already have better tools than either CREATE or the desktop IDE and in most cases can run them without much problem.
Its not a case of "How advanced can they make it" its how easy can they make it for transition from the regular IDE and still keep it simple.
As you yourself say it fits that bill just fine although there are more bits seeming to get added each week whether it be a tweak or and addition.
AM sure the dev team will take your thoughts onboard but there is quite the list of things to be done to it yet already.
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
ghubaidahassani
Newbie
[add]
#16
Mar 09, 2017, 11:34 pm
waoo it so cool i lov this.
i'm a have a problem with plugin. i have downloaded it and installed it but it still can't be founded.
ballscrewbob
Global Moderator
Faraday Member
[add]
#17
Mar 09, 2017, 11:47 pm
But did you follow the
superb guide HERE
There may also be some help in
this post too
If you still have problems Start a new thread with as much detail as you can as mentioned in the second link.
steve8428
Full Member
[add]
#18
Jul 15, 2017, 05:29 am
This is a great add on to the Arduino environment. this makes programming on the move much easier and can now keep all my sketches in one place. I love that you have added the facility to expand and collapse the code with the arrows to the side. This makes it much easier to work on big projects. Thank you
guardineer
Newbie
[add]
#19
Aug 26, 2018, 09:12 pm
The download for my Android tablet "Arduino Create...linux..." will not open on my Android tablet.
Is it not compatible?
ballscrewbob
Global Moderator
Faraday Member
[add]
#20
Aug 26, 2018, 09:15 pm
Last Edit
: Aug 26, 2018, 09:16 pm by ballscrewbob
@guardineer
It is available for Windows, MAC, Linux and CHROMEBOOK but not for regular android.
If yours is a regular android tablet then Create will not currently work on that platform.
omertkod
Newbie
[add]
#21
Aug 29, 2018, 04:12 pm
arduino mega 2560 çalışmıyo
ballscrewbob
Global Moderator
Faraday Member
[add]
#22
Aug 29, 2018, 04:16 pm
Last Edit
: Aug 29, 2018, 04:17 pm by ballscrewbob
@omertkod
They do but you have to be specific about the FLAVOUR.
Look for the "
CHANGE
" option in the board drop down menu.
Then look for the grey down arrow in the flavour box and change it to suit your type of MEGA.
Also try to avoid USB 3.0 ports as they are known to have some issues with Arduino boards.
victorchan
Newbie
[add]
#23
Sep 04, 2018, 01:07 pm
I could not install successfully.
I have a board "Arduino uno" and my computer is window 10. so, I do not understand well, where is my problem..
thanks
Rogelio
ballscrewbob
Global Moderator
Faraday Member
[add]
#24
Sep 04, 2018, 01:17 pm
@Rogelio
How did it fail ?
Details of what went wrong increase you chances of a fix.
Akashwaghmare210
Newbie
[add]
#25
Sep 15, 2018, 12:31 pm
My arduino uno is continually stay on and displays uploading error
ballscrewbob
Global Moderator
Faraday Member
[add]
#26
Sep 15, 2018, 01:40 pm
@Akashwaghmare210
Please read the posts at the top of this section and add DETAILS.
Nobody can help you without those.
FrankSchmidt
Newbie
[add]
#27
Oct 11, 2018, 11:49 pm
Please reply with link where I can post new question on Web Editor. I am not getting a port choice .
ballscrewbob
Global Moderator
Faraday Member
[add]
#28
Oct 12, 2018, 12:05 am
Last Edit
: Oct 12, 2018, 12:09 am by ballscrewbob
Hi again Frank.
Click the small DOWN triangle in the BOARD box.
Select CHANGE and from there you should be able to match the board AND the COM port.
Depending on the board you choose you may also see FLAVOUR.
Quite often CLONES may require 328P (Old Bootloader) and some may just be 328P.
pert
Brattain Member
[add]
https://github.com/per1234?tab=repositories
#29
Oct 12, 2018, 12:41 am
Quote from: FrankSchmidt on Oct 11, 2018, 11:49 pm
You already have created two threads for that issue, and now you're hijacking this thread too:
http://forum.arduino.cc/index.php?topic=572981
http://forum.arduino.cc/index.php?topic=573030
Print
Pages:
1
[2]
3
Loading...
