Topic: combined LCD 16x2 with icomsat v1.1 gsm module = failed (Read 230 times) previous topic - next topic
didit456
Excuse me guys.
I am currently working on my final project now. Basically i use some sensors and upload it with gsm module. I attach an LCD 16x2 in order to view the data from outside.
so this is the problem.
The gsm module was not working each time i use the function lcd.xxxxx
So this is my code
Code: [Select]
#include <GPRSClient.h>
#include <Xively.h>
#include <SoftwareSerial.h>
#include <LiquidCrystal.h>
#define PIN_TX 2
#define PIN_RX 3
#define GSM_ON 9
#define GSM_RESET 10
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
// Your Xively key to let you upload data
char xivelyKey[] = "1111111111111111111111111111111111111111111111111111";
// Define the string for our datastream ID
char sensorId_0[] = "firstreed";
char sensorId_1[] = "secondistancesensor";
XivelyDatastream datastreams[] = {
  XivelyDatastream(sensorId_0, strlen(sensorId_0), DATASTREAM_FLOAT),
  XivelyDatastream(sensorId_1, strlen(sensorId_1), DATASTREAM_FLOAT),
// Finally, wrap the datastreams into a feed
XivelyFeed feed(11111111, datastreams, 2 /* number of datastreams */);
char apn[] = "internet";
char user[] = "";
char pass[] = "";
GPRSClient gprs(PIN_TX, PIN_RX, 2400, apn, user, pass);
XivelyClient xivelyclient(gprs);
int nilailama, dapetinnilai, nilaibaru;
  nyalainModulGSM();
  //delay(10000);
  Serial.println("mulai");
  gprs.init();
  while (false == gprs.join()) {
    Serial.println("gagal");
    delay(2000);
  // successful DHCP
  Serial.print("IP =");
  Serial.println(gprs.getIPAddress());
  lcd.clear();
  //reed
  const int switchPin = 5;
  //dibawah ini ultrasonik
  const int trigPin = 6;
  const int echoPin = 7;
  long duration, inches, cm;
        //inisiasi ultrasonik
        pinMode(trigPin, OUTPUT);
        digitalWrite(trigPin, LOW);
        delayMicroseconds(2);
        digitalWrite(trigPin, HIGH);
        delayMicroseconds(1000);
        pinMode(echoPin, INPUT);
        duration = pulseIn(echoPin, HIGH);
        //konversi waktu ke jarak
        //inches = microsecondsToInches(duration);
        //cm = duration/29/2;
        int ultrasonicValue = duration/29/2;
              //Rumus Reed . Ngitung banyaknya PERUBAHAN STATUS dari 0 sampai 1 , dikalikan 0.2 . Selama 280detik
              int sensorValue0 = digitalRead(switchPin);
              datastreams[0].setFloat(sensorValue0);
              Serial.print("Sensor reed ");//menjumlahkan apa yang dibaca reed disini
              Serial.println(datastreams[0].getFloat());//disini kan dikirim
              Serial.println("Unggah data reed ke server");
              //lcd.clear();
              int ret0 = xivelyclient.put(feed, xivelyKey);
              if(true == ret0){
                Serial.println("update success!");
                //lcd.print(sensorValue0);
                //lcd.print(" done");
              }else{
                Serial.println("update failed!");
                //lcd.print("gagal");
              delay(2000);
              //lcd.clear();
      //Rumus Ultrasonik
      int sensorValue1 = ultrasonicValue;
      nilaibaru = sensorValue1;
      if(nilaibaru != nilailama){
        datastreams[1].setFloat(nilaibaru);
        Serial.print("Sensor jarak ");
        Serial.println(datastreams[1].getFloat());
        Serial.println("Unggah data jarak ke server");
        int ret1 = xivelyclient.put(feed, xivelyKey);
        if(true == ret1){
          //lcd.print(nilaibaru);
          }else{
      nilailama = nilaibaru;
void nyalainModulGSM()
  //pinMode(9, OUTPUT);
  pinMode(9, OUTPUT);
  digitalWrite(9,LOW);
  delay(20000);
  digitalWrite(9,HIGH);
  delay(10000);
  delay(5000);
Right after i upload the code, i always open the serial monitor.
So as you can see i put the lcd.clear() right on the first row of loop();
And yes as i have told you the data can't be uploaded successfully.
The same thing happened if i add some lcd.clear() after serial.begin(9600).
It ended up with no IP and no GPRS connection.
it kind of like the connection were lost right after it read some lcd.xxxxx .
it happened with every lcd.xxxxxxx syntax. So do lcd.begin , or anything.
Below i attach a picture with lcd.clear() right before
and as you can see the third data wasn't succeeded.
I consider using i2c thing but it costs me extra money to buy.
Basically i just want this lcd to show the data without cut the connection off.
So could you guys please help me with this?
Thank you, am sorry for my bad english.
dannable
Quote
#define PIN_TX 2
#define PIN_RX 3
I've only had a superficial glance at the code, but this looks like you are using pins D2 & D3 for two purposes?
Beginners guide to using the Seeedstudio SIM900 GPRS/GSM Shield
didit456
yes, problem found.
thank you mate
