Hello all,
This is my first post, I am loving the Arduino!
I Just wrote my first two programs based on the Blink example. I know they probably already exist in about a thousand different iterations but I'm as excited as Tom Cruise with a new pair of platform shoes
 LED_Sequence
 Turns on LEDs in a linear sequence
 Based on Blink by Scott Fitzgerald
 This code is in the public domain
 Modified Dec 1 2015
//Inputs we will be using
const int LED1 = 12;
const int LED2 = 10;
const int LED3 = 8;
const int LED4 = 6;
// the setup function runs once when you press reset or power the board
 // initialize digital pins 12, 10, 8, 6 as outputs.
 pinMode(LED1, OUTPUT);
 pinMode(LED2, OUTPUT);
 pinMode(LED3, OUTPUT);
 pinMode(LED4, OUTPUT);
// the loop function runs over and over again
// until Keith Richards sheds his mortal coil
 digitalWrite(LED1, HIGH); // turn the LED on (HIGH is the voltage level)
 delay(150);        // keep on for specified time | delay(n)
 digitalWrite(LED1, LOW);  // turn the LED off by making the voltage LOW
 digitalWrite(LED2, HIGH); // and so on
 delay(150);        // and so on
 digitalWrite(LED2, LOW);  // and so on
 digitalWrite(LED3, HIGH); // and so on
 digitalWrite(LED3, LOW);  // and so on
 digitalWrite(LED4, HIGH); // and so on
 digitalWrite(LED4, LOW);  // and so on
 LED_Sequence2
 Turns on LEDs in a back and forth sequence
 Modified Dec 1 2015
const int LED3 = 8;
const int LED4 = 6;
 digitalWrite(LED3, HIGH); // and now back the other way
