I can't get a
stepper motor to rotate a load that it should have enough torque to rotate. The load is a 3' x 3' x 2" table, with the stepper motor centered underneath. I have a
51204 thrust bearing between the motor and the table to reduce friction as much as possible. The table can be turned with a light touch, and when set in motion it continues to glide for some time before coming to a stop. I had a simple flange bushing machined which connects the motor shaft to the table. The motor shaft is secured using a set screw.
I'm using a 5V 1A DC power supply. I used the code and circuit from the
MotorKnob example on the arduino website. I got a Texas Instruments SN754410NE dual H-bridge as instructed, since my motor is bi-polar. I modified the circuit to make it actually work (added one wire connecting the two +5V outside rails of the breadboard) and i successfully got the motor spinning ok by itself, and with the flange bushing attached. Everything seemed ok.
However, when i assemble the table, it does not behave as expected. I've fiddled with the setSpeed function: at 10RPM or less almost nothing happens, at 30-40 RPM it starts turning very slightly, then stops moving, then when the motor stops it sort of repositions itself and jiggles the table. Above 60RPM very little motion occurs. I've tried adding more steps (the motor is 1.8 degree, so 200 steps), but that has little effect either. I also tried setting it to step one at a time, with a delay between single steps, but this sometimes worked and sometimes did not. the motor gets the load moving, but then the load keeps moving, sometimes forward, sometimes as if the motor is trying to keep position. When it's time for the next step, often the load is already spinning, which i wonder if is causing it to miss steps. This stepper motor can theoretically output 490mNm, Which should be more than enough to turn this table (estimated weight of 30lbs), but so far I haven't been able to make it work with the standard stepper.h library. I'm aiming to eventually be able to turn ~500lbs on the table, and my math suggested that this motor should produce enough torque to rotate that weight 180 degrees in ~30 seconds (including allowing for friction of bearing). Any suggestions/hints/comments?
Stepper Motor: Trinamic Motion Control GmbH QSH4218-51-10-049
http://www.digikey.ca/product-detail/en/QSH4218-51-10-049/1460-1076-ND/4843427Circuit:
https://www.arduino.cc/en/uploads/Tutorial/bipolarKnob_schlg.pngCode: have used various. The motor runs fine with no load, i just can't get it to behave as expected when attached to the table. I've been using code from these two examples, with tweaks to the variables:
https://www.arduino.cc/en/Tutorial/MotorKnobhttps://www.arduino.cc/en/Tutorial/StepperOneStepAtATimeI was reading up about how if the voltage profile for the stepper is not properly aligned for the particular motor, it may turn weakly (or not at all) from <>here<>. Could that be what is happening here?
I have a sneaking suspicion that i'm going to have to modify (or re-write) the stepper.h library to try and make this work. On that note, I'm wondering if it could be something related to the speed setting. Although this is a shot in the dark, I really don't know where to start modifying the library code. Any suggestions/hints/tips?
I've got an A4988 driver board now, I'll try using it tomorrow, but i have a feeling my problems are in timing the motor control.
And lastly, if you had to design a system to rotate a table like this, would you go with a stepper motor? the rotation only has to be 90 degrees once every 24 hrs.
Thanks in advance!
