Topic: audio input and output (Read 2139 times) previous topic - next topic
tr909
[I realize that a micro-controller is not meant for audio processing]
I've wrote a simple program to do an analogRead and then pass that value to analogWrite. I expected to get a lo-fi version of input. I also tried to first divide the analogRead value by 4 to keep in in the range of values that analogWrite can output.
Neither gives me what I expect.
I get a lot of noise and a constant tone through-out.
Should this be working?
MikMo
#1
Nov 12, 2007, 05:00 pm Last Edit: Nov 12, 2007, 05:08 pm by MikMo Reason: 1
I dont think this will work.
if the tone you hear is around 500Hz it is most likely the PWM frequency.
How fast are you reading / writing the analog pins ? If i'm not wrong,  it would have to be several 1000 times a second to achieve something that would remotely resemble the input, and then there is the whole issue with scaling the values (divide by 4).  Add to that the fact that the analog out is PWM.
paulb
You can actually sample fast enough to get audio in (although 1k or RAM is going to fill up in .25 seconds at 4k sampling rate), with PROGMEM you might get 1 or 2 seconds of sound.
As mentioned analogWrite is going to be useless for output though and you'll have to do some AVR coding to make this work.
David F at uchobby was working on this. You might email him and see if he has any code he could share.
PaulB
leKuk
hey tr909,
if you don't need recording seacrh the forum for "resistor ladder". if got satisfying 4-bit audio thruput using 4 arduino pins hooked to 4 digital pins. i amplify the mic input with a single transistor. I tried doing audio recording but paul is totally right: 1k is nothing.
i didn't get very far doing any kind of "real-time" manipulation, but  something should be possible.
kuk
mellis
And the PROGMEM is read-only, I think, although I've not tried writing to it.  You probably want external storage, e.g. using the dataflash library (though I haven't tried it, so I don't know if it would work well in this application).  You can also get chips that do audio recording and playback, and I'm sure there are lots that do signal manipulation.
