Topic: air recovery - (DHT-22 variables) (Read 1 time) previous topic - next topic
Antrac1t
Hello,
i started work on module for my home air recovery where i will have some DHT-22 sensors (for air damper). Main code is fine, problem is with variables, i want sent some variable to arduino and this variable should keep it until he will receive another update. For this i created this code (working fine) but when i will send some data from external program (VB.net) then arduino take it only one time :/
Arduino
Code: [Select]
// Example testing sketch for various DHT humidity/temperature sensors
// Written by ladyada, public domain
#include "DHT.h"
#define DHT1PIN 2
#define DHT2PIN 7
#define DHT3PIN 53
#define DHT4PIN 22
#define DHT1TYPE DHT22
#define DHT2TYPE DHT22
#define DHT3TYPE DHT22
#define DHT4TYPE DHT22
DHT dht1(DHT1PIN, DHT1TYPE);
DHT dht2(DHT2PIN, DHT2TYPE);
DHT dht3(DHT3PIN, DHT3TYPE);
DHT dht4(DHT4PIN, DHT4TYPE);
int modul1 = 0;
  Serial.println("AAA");
  dht1.begin();
  dht2.begin();
  dht3.begin();
  dht4.begin();
void loop(){
    delay(2000);
//definovani teploty a vlhkosti pro 4 senzory
 float t1 = dht1.readTemperature();
 float h1 = dht1.readHumidity();
 float t2 = dht2.readTemperature();
 float h2 = dht2.readHumidity();
 float t3 = dht3.readTemperature();
 float h3 = dht3.readHumidity();
 float t4 = dht4.readTemperature();
 float h4 = dht4.readHumidity();
 float temp;
Serial.println("------------------------------------------------------------------------------------------------");
red = Serial.read();
if ( modul1 = 1){
if (isnan(t1) || isnan(h1))
        Serial.println("K pripojeni cidlu 1 nebylo navazano");
      } else
        float hic1 = dht1.computeHeatIndex(t1, h1);
        Serial.print("Cidlo1 - Vlhkost vzduchu: ");
        Serial.print(h1);
        Serial.print(" %\t");
        Serial.print("Teplota: ");
        Serial.print(t1);
        Serial.println(" C");
 else{
  Serial.println("Cidlo uzavreno");
if (isnan(t2) || isnan(h2)) {
Serial.println("K pripojeni cidlu 2 nebylo navazano");
  float hic2 = dht2.computeHeatIndex(t2, h2);
  Serial.print("Cidlo2 - Vlhkost vzduchu: ");
  //kalibrace vlhkosti + 2.7
  Serial.print(h2+2.7);
  // kalibrace teploty -0.5
  Serial.print(t2-0.5);
  Serial.println(" C ");
if (isnan(t3) || isnan(h3)) {
Serial.println("K pripojeni cidlu 3 nebylo navazano");
  float hic3 = dht3.computeHeatIndex(t3, h3);
  Serial.print("Cidlo3 - Vlhkost vzduchu: ");
  Serial.print(h3);
  Serial.print(t3);
if (isnan(t4) || isnan(h4)) {
  float hic4 = dht4.computeHeatIndex(t4, h4);
  Serial.print("Cidlo4 - Vlhkost vzduchu: ");
  Serial.print(h4);
  Serial.print(t4);
Serial.flush(); // clear serial port
part of code for send data (VB.NET)
Code: [Select]
SerialPort.Open()
SerialPort.Write("0")
SerialPort.Close()
thx
AWOL
Code: [Select]
if ( modul1 = 1){
Why bother with a conditional?
"Pete, it's a fool (who) looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
Antrac1t
ok i can do it by CASE, but i want turn on/off each sensor, but still i want see output each 2seconds, for this i first try it by if :/ ...
AWOL
Antrac1t
ok i am stupid idiot
red = Serial.read();  ->  modul1 = Serial.read();
anyway, no change :/ ...
AWOL
#5
Dec 24, 2015, 11:36 pm Last Edit: Dec 24, 2015, 11:36 pm by AWOL
No, seriously, have another look at reply #1.
Just the quoted code - forget my comment.
Antrac1t
#6
Dec 24, 2015, 11:41 pm Last Edit: Dec 24, 2015, 11:46 pm by Antrac1t
if ( modul1 == 1)
better? but still this will not save variable for each new loop
AWOL
Antrac1t
and now figure out problem with stored variable ... each impulse from VB.net is only for one loop ... i tried modul1= Serial.parseInt(); with same result - update only for one loop
AWOL
Antrac1t
AWOL
Antrac1t
So in arduino, there is no chance to keep variable? Save it in rom?
AWOL
#13
Dec 25, 2015, 03:03 pm Last Edit: Dec 25, 2015, 03:07 pm by AWOL
You can store variables in RAM.
You can save variable values in EEPROM, but you can't use EEPROM directly as variable storage.
