Topic: Arduino bundle for TextMate (Read 13515 times) previous topic - next topic
mellis
The automatic prototype generation works with a simple regular expression to try to detect function definitions, and then just ignores setup() and loop().  It doesn't work all that well (it gets confused if your return type is multiple words like "unsigned int" or is on a different line than the rest of your function header).  Still, it's been okay for most things.
In fact, here it is: ^(\w+)\s+(\w+)\s*\(([^)]*)\)\s*{
westfw
#16
Aug 30, 2007, 02:19 am Last Edit: Aug 30, 2007, 02:22 am by westfw Reason: 1
There is cproto (http://cproto.sourceforge.net/) which will generate prototypes for you.
I guess you COULD create a makefile that would do all that the arduino program does.  You'd have rules like:
Code: [Select]
%.cpph: &.cpp
  cproto %.cpp >%.cpph
%.elf: %.cpp %.cpph
   $(GCC) -I$(ARDUINOINC)/prefix.h -I%.cpph %.cpp ...
(that's probably WAY wrong.  I HATE makefiles.  make is a lovely example of a 1970s program that should have been replaced long ago instead of patching it to handle modern circumstances.   A good percentage of Arduinos goodness probably comes from letting the user never have to deal with makefiles!)
ozel
#17
Aug 30, 2007, 12:22 pm Last Edit: Aug 30, 2007, 12:22 pm by ozel Reason: 1
@westfw
Well i'm not after a substitution of the current java compile with a makefile. I just like to keep an alternative, when not working with the IDE.
It's not that I like makefiles, but for microcontroller programming is still not too hard to use it - IMHO.
Although I frequently forget important makefile knowledge... :-)
Speaking of it, i think there is a dependency erro in my makefile. Did anybody try it?
Cproto is interesting, thanks! Maybe mellis will use it in the IDE?
But as long as it's not a standard install on unix systems I wouldn't want to use it in a makefile.
On the other hand I think using a makefile, even if it's only in the background of an IDE, is a better standard than doing some custom java-based compile process in the IDE, like it's now. Esp. for maintainance between different IDE versions a certain compile standard could be better...
Of coruse, I agree that the Ardunio goodness comes with the current software and IDE!
But I think it's also good, that the Ardunio IDE doesn't allow too much simplification of C code.
I think the current state of preprocessing is a perfect compromise.
I hope it won't walk away any further from standard avr-gcc C code. Incorporating an alternative  language than C, though, would be again a different question. E.g. ruby arduino developement: http://rad.rubyforge.org/
mellis
#18
Aug 30, 2007, 03:35 pm Last Edit: Aug 30, 2007, 03:36 pm by mellis Reason: 1
Using Makefiles as a backend from the IDE sounds good, but it was a nightmare in practice (we did it in the original versions of Arduino).  Especially on Windows, it was impossible to get working consistently - some machines seemed to want / as the path separator, some wanted \ and some wanted \\.  We had to maintain multiple slightly different makefile version.
It was also difficult for people to make changes to the build process, because they'd get thrown by the common Makefile problem (like using spaces instead of tabs, etc.)  Now, with the preferences file, there aren't many things you can change, but they are relatively easy.  We could just pass all the variables on to the makefiles, but at this point there are some decisions being made that we be a pain to replicate in makefiles.
I kind of like the idea that the IDE does it's own thing, but we also provide a Makefile for people who want one.
It would be good to have a better way to generate function prototypes, but it's also a hassle to include another program, and so far, the current method seems to be "good enough".
Of course, these are all interesting ideas, and I appreciate the discussion.
ozel
I fully understand this. Maybe cmake is worth a try... Though cmake would add many more MBs.
I forgot one thing that's really great about using a makefile now:
You can have your preferences saved with the projects.
E.g. on some boards you prefer to use the bootloader while with others you're setup requires an AVRISP MKII - in any case you just set it once. Esp. ATmega8 vs. ATmega168 switching becomes obsolete! I guess some catch this problem often nowadays when having diecimila and older boards around at the same time. Also you can have different clock speeds and baudrates without changing preferences everytime you switch projects etc...
Yes, this is rather advanced stuff, but it's nice beeing still able to do it with a makefile - just as you said, david. I agree, as long as prototype creation works most of the time, better don't touch it...
westfw
Quote
I guess it doesn't start to really fall apart till you get a couple thousand source files!  :) :( :'(
Still, I think I'd prefer a way to invoke Arduino as a command like utility to build a sketch, instead of creating two ways to build the sketch.  I don't know how hard this is in a multi-os java app.  EAGLE (the PCB editor) does it in the linux and macos versions, but needs a separate exe for windows...
bigengineer
#21
Sep 08, 2007, 10:11 am Last Edit: Sep 08, 2007, 10:14 am by bigengineer Reason: 1
xSmurf, could you upload the textmate bundle somewhere? I am still  in the evalutation period of textmate but it seems asa very good editor to me. Finally leaving vim behind me. (outside a terminal that is)
I just started using the arduino programmer as described on tinker.it. I expected that this programmer with textmate will make programming a lot easier.
bigengineer
#22
Sep 08, 2007, 01:51 pm Last Edit: Sep 08, 2007, 01:53 pm by bigengineer Reason: 1
I tried to compile LCD4bitexample (from the playground) with the makefile from Oliver. But there are some errors:
applet/LCD4BitExample.cpp:4:21: error: LCD4Bit.h: No such file or directory
applet/LCD4BitExample.cpp:7: error: 'LCD4Bit' does not name a type
applet/LCD4BitExample.cpp: In function 'void setup()':
applet/LCD4BitExample.cpp:16: error: 'lcd' was not declared in this scope
applet/LCD4BitExample.cpp: In function 'void loop()':
applet/LCD4BitExample.cpp:28: error: 'lcd' was not declared in this scope
make: *** [applet/LCD4BitExample.elf] Error 1
It seems that LCD4Bit.h can not be found. What do I have to change so it will be found? I expect that all additional libraries will not be found.
ozel
For a quick "hack" you need to add LCD4Bit.cpp to the CXXSRC variable in the makefile.
Then in the .pde it must read #include "LCD4Bit.h" (no < >) to reference the lib as a local file. The last step is to put the LCD4Bit.h/.cpp in the same directory as the makefile and the .pde. Then it compiles -  at least in my case. ;)
I'm still searching for a nice setup, to include the arduino libs nicely in the makefile. Can anybody help?
When it's more polished I'll hopefully find time to do a Playground entry.
bigengineer
Quote
I see, but this is going to a mess after a while. If I change something in the LCD4Bit.cpp, where do I change it? I assume this has to be local, in the directory where the pde is? If you start a new program with the modified library you  have to  copy the library files to the new program directory.
ozel
You are right, but this is no limitation of makefiles. It's only a question of proper usage. We need to use the -I switches for includes right but I forgot how it's done...
regarding your improved upload process: keep in mind you can allways change preferences.txt if you wan't to change the upload programmer. So there's no need to skip the Arduino IDE only to use a different programmer.
bigengineer
Slowly it is all coming back, -I, I can recall that, from a very long time ago.
I added an arduinolibs parameter, so, that is a bit easier to add, for instance:
CXXSRC = $(ARDUINO)/HardwareSerial.cpp $(ARDUINO)/WRandom.cpp $(ARDUINOLIBS)/LCD4Bit/LCD4Bit.cpp
And I made a symbolic link to LCD4Bit.h in the sketch directory. After that I changed the avrdude config to work with my programmer. Now it works perfectly. So, command-R and command-U work, this is very nice for lots of uploads, it works very quick.
ozel
Yeah, it's really quick. I'm happy someone else also finds it usefull!
If you add -I$(ARDUINOLIBS)/LCD4Bit to CXXINCS it should recognize the lib w/o a symbolic link. But I think you need to write again in #include <LCD4Bit.h> (with <>).
There must be a nice way to include all libraries from "/lib/target/librariers" without explicitly menitioning them. Similar like in the line that starts with "@for i in $(OBJ)". This is real makefile science...
westfw
The current "command line" instructions mention installing "real" avr-gcc.  If you've already installed arduino to get the libraries and source modules needed, you already have a copy of avr-gcc that's certainly complete enough to compile arduino sketches, and the makefile can make that invisible to the users.  I have (in the makefile from the wiki):
Code: [Select]
# Program settings
CC =  /Downloads/arduino-0008/tools/avr/bin/avr-gcc
CXX = /Downloads/arduino-0008/tools/avr/bin/avr-g++
OBJCOPY = /Downloads/arduino-0008/tools/avr/bin/avr-objcopy
OBJDUMP = /Downloads/arduino-0008/tools/avr/bin/avr-objdump
SIZE = /Downloads/arduino-0008/tools/avr/bin/avr-size
NM = /Downloads/arduino-0008/tools/avr/bin/avr-nm
AVRDUDE = /Downloads/arduino-0008/tools/avr/bin/avrdude
ozel
shure, the makfile that comes in arduino-0009/lib/tragets/arduino also uses local avr-gcc.
This is why I changed it in my makefile  (see rapidshare link http://rapidshare.com/files/51829818/Arduino_Makfile_Textmate_Bundle.zip.html) to reference the $(AVR_TOOLS_PATH) dir inside an arduino installation.
