Loading...
Pages: [1]   Go Down
Author Topic: Problems with attachInterrupt while in C  (Read 460 times)
Reykjavik, Iceland
Offline Offline
Newbie
Arduino rocks as much as me.
View Profile
WWW
Hi.
I have been playing with the Arduino board I got for xmas and I hit a little problem while using attachInterrupt in C.
If I rewrite the code in the Arduino IDE then attachInterrupt works so it's not a wiring problem. For various reasons I have been playing in old fashion C and want this to work there. smiley
Is there some trick to this? Is there something really really obvious I am missing?
You can check out my code here: http://github.com/JonGretar/my-arduino-code/tree/master/C/ledarray-v2.c
« Last Edit: December 28, 2008, 04:47:26 pm by JonGretar » Logged
Austin, TX USA
Offline Offline
God Member
Arduino rocks
View Profile
Hi Jon,
It might be easier to diagnose if you would explain what your "little problem" is.  Compiler error?  Malfunction?  Unexpected behavior?
Mikal
Logged
Reykjavik, Iceland
Offline Offline
Newbie
View Profile
WWW
Hehe... sorry.. My bad.
The interrupt function never runs in the C code. Thus it never changes change_state to HIGH on trigger.
Everything compiles and uploads fine. The loop runs fine. Running got_interrupt() manually works. Just does nothing when I activate the interrupt trigger.
Logged
Austin, TX USA
Offline Offline
God Member
Arduino rocks
View Profile
If you rename the file to .cpp and compile it exactly as-is with the C++ compiler, does it still not work?
Logged
Reykjavik, Iceland
Offline Offline
Newbie
View Profile
WWW
Same thing. Program upload. Runs fine.. Just no interrupts. I have the new Duemilanove if that matters.
Code:
=> [avr-gcc] ledarray-v2.elf
avr-gcc -mmcu=atmega168 -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -I. -gstabs -DF_CPU=16000000 -Os -Wall -Wstrict-prototypes -std=gnu99 -I/Applications/Electronics/arduino-0012/hardware/cores/arduino -o ledarray-v2.elf ledarray-v2.c  -L. core.a -lm
 => [avr-objcopy] ledarray-v2.hex
avr-objcopy -O ihex -R .eeprom ledarray-v2.elf ledarray-v2.hex
 => [avrdude] ledarray-v2.hex
avrdude -p atmega168 -P /dev/tty.usbserial-A60061eR -C /Applications/Electronics/arduino-0012/hardware/tools/avr/etc/avrdude.conf -c stk500v1 -b 19200 -F -u -U flash:w:ledarray-v2.hex
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.05s
avrdude: Device signature = 0x000000
avrdude: Yikes!  Invalid device signature.
avrdude: Expected signature for ATMEGA168 is 1E 94 06
avrdude: NOTE: FLASH memory has been specified, an erase cycle will be performed
         To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "ledarray-v2.hex"
avrdude: input file ledarray-v2.hex auto detected as Intel Hex
avrdude: writing flash (3164 bytes):
Writing | ################################################## | 100% 2.59s
avrdude: 3164 bytes of flash written
avrdude: verifying flash memory against ledarray-v2.hex:
avrdude: load data flash data from input file ledarray-v2.hex:
avrdude: input file ledarray-v2.hex contains 3164 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 2.38s
avrdude: verifying ...
avrdude: 3164 bytes of flash verified
avrdude done.  Thank you.
Logged
Seattle, WA
Offline Offline
Jr. Member
Arduino rocks my socks
View Profile
WWW
If you're playing around in straight up C, you should ditch attachInterrupt and write your own interrupt handlers in  the avr-libc syntax.
Logged
Reykjavik, Iceland
Offline Offline
Newbie
View Profile
WWW
Okz. Thanks. I'll dig into the interrupts manually.
Just so I know. Is there some reason for this? attachInterrupt seems to be a C function.
Logged
Austin, TX USA
Offline Offline
God Member
Arduino rocks
View Profile
Jon, it occurred to me last night as I was going to sleep that attachInterrupt probably has some dependency on the Arduino initialization sequence.  Try simply adding
Code:
init();
to the top of your main() function.
Mikal
Logged
Reykjavik, Iceland
Offline Offline
Newbie
View Profile
WWW
Ahh... That did the trick. smiley
Thanks. Didn't know about init();
Logged
Pages: [1]   Go Up
Print
Jump to:
