Author Topic: SoftwareSerial causes error in library  (Read 679 times)
I'm in the process of writing my first library, I need to use software serial but i keep getting an error when ever I do, what is it I'm doing wrong.
The library is for the motor controller from web4robot
any ways heres the code followed by the error, hope some one can help.
Motor.cpp
#include "WProgram.h"
#include "Motor.h"
#include "SoftwareSerial.h"
Motor::Motor(int rx,int tx)
  mySerial =  SoftwareSerial(rx,tx);
  pinMode(rx, OUTPUT);
  pinMode(tx, OUTPUT);
  mySerial.begin(9600);
void Motor::motor1Stop(){motorComand(1,1,0x00);}
void Motor::motor2Stop(){motorComand(2,1,0x00);}
void Motor::motor1Forwards(char mSpeed){motorComand(1,1,mSpeed);}
void Motor::motor1Backwards(char mSpeed){motorComand(1,2,mSpeed);}
void Motor::motor2Forwards(char mSpeed){motorComand(2,1,mSpeed);}
void Motor::motor2Backwards(char mSpeed){motorComand(2,2,mSpeed);}
void Motor::motorComand(int motor, int mDirection, char mSpeed){
  char buff[5];
  buff[0]=254; // Start byte
  buff[1]=77; // Device ID
  buff[2]=0x03; // Comand (03 = Motor Speed)
  if(motor <= 1){
    if(mDirection <= 1){
      buff[3]=0x00; // Motor and Direction (00 = Motor 1 Forwards, 01 = Motor 1 Bacwards, 02 = Motor 2 Forwards, 03 = Motor 2 Bacwards,
    else{
      buff[3]=0x01; // Motor and Direction (00 = Motor 1 Forwards, 01 = Motor 1 Bacwards, 02 = Motor 2 Forwards, 03 = Motor 2 Bacwards,
  else{
      buff[3]=0x02; // Motor and Direction (00 = Motor 1 Forwards, 01 = Motor 1 Bacwards, 02 = Motor 2 Forwards, 03 = Motor 2 Bacwards,
    else{
      buff[3]=0x03; // Motor and Direction (00 = Motor 1 Forwards, 01 = Motor 1 Bacwards, 02 = Motor 2 Forwards, 03 = Motor 2 Bacwards,
  buff[4]=mSpeed; // Speed
 for(int i=0;i<5;i++){mySerial.print(buff[i],BYTE);}
Motor.h
#ifndef Motor_h
#define Motor_h
class Motor
  public:
    Motor(int rx,int tx);
    void motor1Stop();
      void motor2Stop();
      void motor1Forwards(char mSpeed);
      void motor1Backwards(char mSpeed);
      void motor2Forwards(char mSpeed);
      void motor2Backwards(char mSpeed);
  private:
    void motorComand(int motor, int mDirection, char mSpeed);
      SoftwareSerial mySerial;
#endif
Error
Motor.cpp: In constructor 'Motor::Motor(int, int)':
Motor.cpp:11: error: no matching function for call to 'SoftwareSerial::SoftwareSerial()'
hardware\libraries\SoftwareSerial/SoftwareSerial.h:34: note: candidates are: SoftwareSerial::SoftwareSerial(uint8_t, uint8_t)
hardware\libraries\SoftwareSerial/SoftwareSerial.h:26: note:                 SoftwareSerial::SoftwareSerial(const SoftwareSerial&)
Norway@Oslo
loveArduino(true);
Try this:
Motor.cpp
Motor::Motor(int rx,int tx) : mySerial(SoftwareSerial(rx,tx)
Thank you so much, that gave no errors on start up.
Out of interest though why is it that this is required, I'm used to programming in java and have never come across this syntax before.
However when I tried to use my library I get this error.
hardware\libraries\Motor/Motor.h:5:28: error: SoftwareSerial.h: No such file or directory
This seems strange as SoftwareSerial does exist and is working in other sketches.
« Last Edit: July 17, 2009, 05:52:04 pm by wiccan2 » Logged
Norway@Oslo
loveArduino(true);
This is required because the constructor tries to contruct every member of the class in RAM as it is constructed.
When you write something inside the { }, the object is already initialized in memory.
This causes a problem when trying to construct an object that needs some parameters passed as arguments to the constructor.
It will complain that there is no constructor available with no parameters. (As I said, it tries to construct the software serial object at ... well ... construction.)
In C++ you need to have a way of passing arguments to member variables as they are constructed. Not afterwards. The : is just the syntax on how to accomplish that.
class Stupid {
public:
  Stupid( int x );
class Example {
public:
  Example();
private:
  Stupid stupid; //object is not initialized, just declared
Example::Example() : stupid(9000) {
  //the stupid object has been constructed in memory with parameter 9000 accounted for
Sorry for a poor explanation.
[edit]
You need to have both these on the top of your sketch:'
#include <SoftwareSerial.h>
#include <Motor.h>
smiley[/edit]
« Last Edit: July 17, 2009, 05:59:48 pm by AlphaBeta » Logged
Thanks for the explanation, but i'm still getting this error when i try to compile my sketch
Norway@Oslo
loveArduino(true);
[glow]#include "SoftwareSerial/SoftwareSerial.h"[/glow] maybe?
[edit]That is, in your .h file.[/edit]
« Last Edit: July 17, 2009, 06:16:32 pm by AlphaBeta » Logged
Thanks for all your help, I cant really remember how I fixed that last one, all I can remember is it was something trivial, missing semicolon or something.
Any ways the library is finished now and is available at my website for download: http://www.wiccan-two.co.cc/arduino/dmc1-library
Thank you for all your help with this.
