Topic: # and ♭ display options (Read 803 times) previous topic - next topic
peterbradley
Hello!
I'm working on musical board game that runs on an arduino and a couple of shift register chains.
I use daisy chained 7 segment LEDS to shift out players' scores as the games goes on.  I would like to add a component that displays the chord and key in play at a given time.
A 16 segment display seems suitable for the letter component (A-G), but I'm not sure how I can display the sharp and flat symbols.  Do you have any suggestions?
I'm not married to LED display if there is a better alternative, practically and aesthetically.
Paul__B
Before I suggest, cite the actual "starburst" display you propose to use and its segment denotations.
peterbradley
#2
Jan 16, 2016, 02:30 am Last Edit: Jan 16, 2016, 02:40 am by peterbradley
I haven't bought any 16 segment displays yet.  Probably something like this:
http://www.seeedstudio.com/depot/08-Inch-16-Segment-LED-Green-Common-Anode-p-2004.html
Common anode 10x13mm if possible.  I'll control it with two shift registers and shift out integer equivalents of the binary that lines up with its segment denotations.
PaulRB
#3
Jan 16, 2016, 09:10 am Last Edit: Jan 16, 2016, 09:32 am by PaulRB
Hi, how do you display "#" with those 16-seg displays? Won't that note symbol look just like a "b"?
have you considered lcd displays? 16x2 character are the most common and cheapest. Each character is made up of a 5x7 grid of dots, and I'm pretty sure you can define your own characters if you can't find suitable ones built-in.
If you want to stick with led, perhaps some combination of 7-seg and 5x7 led matrix driven by max7219 chips?
A single max7219 could drive a 5x7 plus 3 7-seg displays. Max7219 can be daisy-chained so that multiple chips can be driven with 3 Arduino pins.
Paul
Paul__B
#4
Jan 16, 2016, 09:48 am Last Edit: Jan 16, 2016, 09:49 am by Paul__B
I haven't bought any 16 segment displays yet.  Probably something like this.
Well, I imagine that "#" could be JBG1G2CMD1D2 and "♭" could be FEG1N (or possibly FEG1MD1).
Funny - why did that not appear in your post the first time around?
