Topic: help processing (Read 697 times) previous topic - next topic
morrigan
Nov 23, 2009, 07:06 pm Last Edit: Nov 23, 2009, 09:51 pm by morrigan Reason: 1
good morning,
i have to realize an interactive vertical projection with the shapes of people walking in the space, and i have to add at shapes a different number.
The cam-video has a stop-image of 7 sec every 5 sec (so it will be likea stop-motion effect).
I never worked in Processing before but i tried to do a couple of patches. I don't know if they will be usefull.
I need about the multitracking.. I saw OpenCV on internet but i'm not able to create the libraries. I tried to do this but it was not possible and i don't know why...(i've a Mac). I'm thinking to start from the multiblob code to make the shapes.
i wish about some help please......the deadline is the 3th of january.
thank u so much!!!
//number+tracking+framerate(1)//
PFont fontA;
float radius = 50.0;
int X, Y;
int nX, nY;
int delay = 16;
int num = 60;
float mx[] = new float[num];
float my[] = new float[num];
import processing.video.*;
Capture video;
 size(640, 480); // Change size to 320 x 240 if too slow at 640 x 480
 video = new Capture(this, width, height, 30);
 smooth();
 fontA = loadFont("Courier-48.vlw");
  textFont(fontA, 30);
  strokeWeight( 10 );
 frameRate( 15 );
 X = width / 2;
 Y = width / 2;
 nX = X;
 nY = Y;
video.frameRate(1);
void draw() {
 if (video.available()) {
   video.read();
   image(video, 0, 0, width, height); // Draw the webcam video onto the screen
   int brightestX = 0; // X-coordinate of the brightest video pixel
   int brightestY = 0; // Y-coordinate of the brightest video pixel
   int fontAX = 0;
   int fontAY = 0;
   float brightestValue = 250; // Brightness of the brightest video pixel
   video.loadPixels();
   int index = 0;
   for (int y = 0; y < video.height; y++) {
     for (int x = 0; x < video.width; x++) {
       int pixelValue = video.pixels[index];
       float pixelBrightness = brightness(pixelValue);
             if (pixelBrightness > brightestValue) {
         brightestValue = pixelBrightness;
         brightestY = y;
         brightestX = x;
         nX = x;
         nY = y;
          for(int i=1; i<num; i++) {
   mx[i-1] = mx;
   my[i-1] = my;
  mx[num-1] = x;
 my[num-1] = y;
 for(int i=0; i<num; i++) {
   ellipse(mx, my, i/0.8, i/0.8);
   //text( Y, X, radius, radius );
       index++;
    radius = radius + sin( frameCount / 4 );
     X+=(nX-X)/delay;
 Y+=(nY-Y)/delay;
  stroke(255);
//silhouette//
Capture video;
class Form {
   int[][] v = new int[0][3];
   int y;
   color c;
   Form(int x,int y) {
       this.y = y;
       addRow(x,y);
       this.c = lerpColor(#ff0000,#0000ff,1);
   void addRow(int x, int y) {
       int[] v_n = new int[3];
       v_n[0] = x;
       v_n[1] = x;
       v_n[2] = y;
       v = (int[][]) append(v, v_n);
   void draw(int nr) {
       line(v[0][0],v[0][2],v[0][1],v[0][2]);
       for (int i=0;i<v.length-1;i++){
           stroke(c,35);
           strokeWeight(4);
           line(v
  • ,v[2],v[i+1][0],v[i+1][2]);
               line(v[1],v[2],v[i+1][1],v[i+1][2]);
           line(v[v.length-1][0],v[v.length-1][2],v[v.length-1][1],v[v.length-1][2]);
       String toString() {
           String a = "------------START---------\n";
               a+="["+v
    • +"|"+v[1]+"|"+v[2]+"]\n";
             a +="------------END-----------\n";
             return a;
      Form[] f =  new Form[0];
       size(640, 480);
       video = new Capture(this, width, height, 10);
       noStroke();
       smooth();
       ellipseMode(CENTER);
      void draw() {
         //background(255);
             f = new Form[0];
             video.read();
             video.loadPixels();
             int index = 0;
             int raster = 4;
             for (int y = 0; y < video.height; y+=raster) {
               for (int x = 0; x < video.width; x+=raster) {
                 int pixelValue = video.pixels[y*video.width+x];
                 boolean intresting = brightness(pixelValue)<80;
                 if (intresting) {
                     boolean old_spot = false;
                     for (int i=0; i<f.length && !old_spot ; i++){
                         Form fi = f;
                         int row = fi.v.length-1;
                         int dx = x-fi.v[row][1];
                         int dy = y-fi.v[row][2];
                         if (dx<=2*raster && dy<=2*raster) {
                             old_spot = true;
                             if (fi.v[row][2]<y) {
                                 fi.addRow(x,y);
                             else {
                                 fi.v[row][1] = x;
                     if (!old_spot) {
                         Form new_form = new Form(x,y);
                         f = (Form[]) append(f,new_form);
         for (int i=0; i<f.length; i++) {
             f.draw(i);
      void keyPressed() {
             print(f);
CaptainObvious
Please use the "code" button when posting code :D it looks like a '#' on the toolbar.
But as for processing goes, you will have much better luck I'm sure, over in the Processing forums.. these forums are dedicated to Arduino. :D
http://processing.org/discourse/yabb2/YaBB.pl
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
