Loading...
Pages: [1]   Go Down
Author Topic: float to string function  (Read 13636 times)
0 Members and 2 Guests are viewing this topic.
0
Offline Offline
Newbie
Arduino rocks
View Profile
WWW
Hi.
If anyone has use for a float to string conversion function that runs standalone, I uploaded one to the playground here
http://www.arduino.cc/playground/Main/FloatToString
save that file to a floatToString.h in your project directory and go to town.  (On my mac, I have to restart Arduino before I can import the file in a pde).  There is example/test code in the comments field at the bottom of the file.
With this function, I have it require a char * buffer be passed in that it writes to.
If I wanted to create a new string inside that function, and return that instead, I assume that woud require malloc?
Anyways, I figured passing in a buffer from the location of your choice would be preferable anyway.
Hope it comes in handy, and please let me know if you find any bugs!
thanks,
Tim
Logged
0
Offline Offline
Full Member
View Profile
This is a useful function, but there appears to be a bug of not terminating the string properly when the output is "0".
Try running this code:
Code:
int K;
float M;
byte stepSize = 2;
char test[20];
  Serial.println("Starting");
  for (K = 10; K >= -10; K--){
    M = K/10.0;
    Serial.print(floatToString(test,M,0,7,true));
    Serial.print(' ');
    Serial.print(floatToString(test,M,1,7,true));
    Serial.print(' ');
    Serial.println(K, DEC);
    delay(100);
This is the correct output:
Code:
Starting
     1     1.0 10
     1     0.9 9
     1     0.8 8
     1     0.7 7
     1     0.6 6
     1     0.5 5
     0     0.4 4
     0     0.3 3
     0     0.2 2
     0     0.1 1
     0     0.0 0
    -0    -0.1 -1
    -0    -0.2 -2
    -0    -0.3 -3
    -0    -0.4 -4
    -1    -0.5 -5
    -1    -0.6 -6
    -1    -0.7 -7
 This is what you get instead
Code:
Starting
     1     1.0 10
     1     0.9 9
     1     0.8 8
     1     0.7 7
     1     0.6 6
     1     0.5 5
     05     0.4 4
     04     0.3 3
     03     0.2 2
     02     0.1 1
     01     0.0 0
    -00    -0.1 -1
    -01    -0.2 -2
    -02    -0.3 -3
    -03    -0.4 -4
    -1    -0.5 -5
    -1    -0.6 -6
    -1    -0.7 -7
« Last Edit: January 05, 2009, 02:45:56 pm by zitron » Logged
London
Offline Offline
Faraday Member
Have fun!
View Profile
Its worth noting that Don Kinzer published a routine for creating strings from floating point values here: http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1207226548/11#11
Don's code is smaller although it does not have the minwidth and rightjustify arguments.
I have seen this before and am curious, I notice that your code uses [glow]and[/glow] instead of [glow]&&[/glow] . [glow]not[/glow] instead of [glow]![/glow] , I was wondering why this syntax is used?
« Last Edit: January 05, 2009, 03:26:47 pm by mem » Logged
0
Offline Offline
Full Member
View Profile
Quote
I notice that your code uses and instead of && . not instead of ! , I was wondering why this syntax is used?
Heh I see you've highlighted the keywords, I had to read that sentence three times to correctly parse it  ;D. I didn't even know you could use the keywords [glow]and[/glow] and [glow]not[/glow] in C!
mem I think your code is probably better, but I really need the right justify function for my OSD, since it makes changing numbers much easier to read. I think I'll try to combine both codes to get what I want...
Cheers,
-Z-
Logged
Austin, TX USA
Offline Offline
God Member
Arduino rocks
View Profile
Mem,
Those "and" and "or" keywords come from iso646.h, which is automatically included, ostensibly to help people with "international" or "non-QWERTY" keyboards.  To me it seems more problematic than useful.  See http://en.wikipedia.org/wiki/Iso646.h.
Mikal
« Last Edit: January 05, 2009, 05:54:27 pm by mikalhart » Logged
0
Offline Offline
Full Member
View Profile
I've looked around the forum, but couldn't find a FloatToStr function that actually worked with out any bugs.
  • Tim's code has some problem displaying zero.
  • Mem's code does not have proper rounding, does not allow setting text minimum width.
  • Don's code also has some issues displaying zero and negative values
So I've combined mem's code with Tim's code, and a little bit from Don. This hopefully should work as a compact sprintf() replacement that has no bugs (famous last words  smiley-grin). Maybe it can be more efficient, but I think it's pretty good.
Code:
char * floatToString(char * outstr, double val, byte precision, byte widthp){
  char temp[16];
  byte i;
  // compute the rounding factor and fractional multiplier
  double roundingFactor = 0.5;
  unsigned long mult = 1;
  for (i = 0; i < precision; i++)
    roundingFactor /= 10.0;
    mult *= 10;
  temp[0]='\0';
  outstr[0]='\0';
  if(val < 0.0){
    strcpy(outstr,"-\0");
    val = -val;
  val += roundingFactor;
  strcat(outstr, itoa(int(val),temp,10));  //prints the int part
  if( precision > 0) {
    strcat(outstr, ".\0"); // print the decimal point
    unsigned long frac;
    byte padding = precision -1;
    while(precision--)
      mult *=10;
    if(val >= 0)
      frac = (val - int(val)) * mult;
      frac = (int(val)- val ) * mult;
    unsigned long frac1 = frac;
    while(frac1 /= 10)
      padding--;
    while(padding--)
      strcat(outstr,"0\0");
    strcat(outstr,itoa(frac,temp,10));
  // generate space padding
  if ((widthp != 0)&&(widthp >= strlen(outstr))){
    byte J=0;
    J = widthp - strlen(outstr);
    for (i=0; i< J; i++) {
      temp[i] = ' ';
    temp[i++] = '\0';
    strcat(temp,outstr);
    strcpy(outstr,temp);
  return outstr;
Logged
0
Offline Offline
Full Member
View Profile
Usage:
floatToString(buffer string, float value, precision, minimum text width)
set minimum text width to 0 for no right justify.
Example:
Code:
#include <string.h>
int K;
float M;
byte stepSize = 2;
char test[20];
  Serial.begin(19200);
  for (K = 1000; K >= -1000; K--){
    M = K/100.0;
    Serial.print(floatToString(test, M, 0, 3));
    Serial.print(' ');
    Serial.print(floatToString(test, M, 1, 5));
    Serial.print(' ');
    Serial.print(floatToString(test, M, 2, 6));
    Serial.print(' ');
    Serial.print(floatToString(test, M, 3, 7));
    Serial.print(' ');
    delay(10);
Prints:
Code:
  0   0.1   0.07   0.070 7
  0   0.1   0.06   0.060 6
  0   0.1   0.05   0.050 5
  0   0.0   0.04   0.040 4
  0   0.0   0.03   0.030 3
  0   0.0   0.02   0.020 2
  0   0.0   0.01   0.010 1
  0   0.0   0.00   0.000 0
 -0  -0.0  -0.01  -0.010 -1
 -0  -0.0  -0.02  -0.020 -2
Logged
0
Offline Offline
Newbie
View Profile
hello zitron,
I'm having rounding problems with your function. I did try to write my own ftoa function, but also have the same rounding issues as with your function. Check out this:
  Serial.println(floatToString(str, 32766.6613, 2, smiley-cool);
  Serial.println(floatToString(str, 32766.6613, 4, smiley-cool);
  Serial.println(floatToString(str, 1.6613, 4, smiley-cool);
  Serial.println(floatToString(str, -32766.1234, 2, smiley-cool);
  Serial.println(floatToString(str, -32766.1234, 4, smiley-cool);
These are the results of your function:
32766.66       // CORRECT
32766.6621   // WRONG
  1.6613        // CORRECT
-32766.12     // CORRECT
-32766.1230  // WRONG
Errors are small and probably won't make much difference, but still annoys me for not knowing the cause.
Any ideas?
Logged
Connecticut, US
Offline Offline
Edison Member
Whatduino
View Profile
WWW
Did you read the replies to your previous post yesterday?
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1207226548/22
Logged
0
Offline Offline
Full Member
View Profile
Hi gui,
Thanks for pointing out the mistake. I found out that there is a problem in the my function. Because the function itoa is used to convert numbers, and it is a integer (16bit) function, so there is a problem when you specify precision > 4 digits, the function therefore only works for values less than xxxx.xxxx.
I have modified it so that it uses ltoa instead, which uses long integers, so that should be plenty of digits. I'm also pretty much rewritten the function, so now it should be smaller and more efficient.
Code:
  char temp[16]; //increase this if you need more digits than 15
  byte i;
  temp[0]='\0';
  outstr[0]='\0';
  if(val < 0.0){
    strcpy(outstr,"-\0");  //print "-" sign
    val *= -1;
  if( precision == 0) {
    strcat(outstr, ltoa(round(val),temp,10));  //prints the int part
  else {
    unsigned long frac, mult = 1;
    byte padding = precision-1;
    while (precision--)
      mult *= 10;
    val += 0.5/(float)mult;      // compute rounding factor
    strcat(outstr, ltoa(floor(val),temp,10));  //prints the integer part without rounding
    frac = (val - floor(val)) * mult;
    while(frac1 /= 10)
      padding--;
    while(padding--)
      strcat(outstr,"0\0");    // print padding zeros
    strcat(outstr,ltoa(frac,temp,10));  // print fraction part
  // generate width space padding
    byte J=0;
      temp[i] = ' ';
    temp[i++] = '\0';
  return outstr;
Logged
Orygun
Offline Offline
Full Member
Don't let the smoke out!
View Profile
Would this be valid documentation for use of this function to add to the top of floatToString.h ?
Please correct where needed.
Code:
 *  floatToString.h
 *  Usage: floatToString(buffer string, float value, precision, minimum text width)
 *  Example:
 *  char test[20];    // string buffer
 *  float M;          // float variable to be converted
 *                 // precision -> number of decimal places
 *                 // min text width -> character output width, 0 = no right justify
 *  Serial.print(floatToString(test, M, 3, 7)); // call for conversion function
Logged
0
Offline Offline
Full Member
View Profile
capt.tagon
Good hint making understanding that stuff easier for a beginner!
Logged
0
Offline Offline
God Member
View Profile
why not just use avr-gcc's dtostre and dtostrf?
http://www.nongnu.org/avr-libc/user-manual/group__avr__stdlib.html#g6c140bdd3b9bd740a1490137317caa44
Logged
I'm an electrical engineering student. I designed the USnooBie (V-USB dev kit) which is sold at Seeed Studio
0
Offline Offline
Full Member
View Profile
Crap frank.  :smiley Didn't know it existed!
Seriously, just use:
#include<stdlib.h>
dtostrf(FLOAT,WIDTH,PRECSISION,BUFFER);
It's 20% smaller than my floatToString(), and probably faster as well.
Logged
Pages: [1]   Go Up
Print
Jump to:
