Topic: Database Library (Read 6746 times) previous topic - next topic
grandpa
If your address pointer ever got larger than 256, you'd experience issues.  I made some additional changes to the library and posted them here:
http://www.arduino.cc/playground/Code/ExtendedDatabaseLibrary
I've successfully added 1300+, 45 byte records and retrieved them with no issues using the Extended Database Library and a 512 kilobyte AT24C1024 eeprom.
retrolefty
Anyone have a source and price for the AT24C1024 in DIP package? A quick check on goggle only showed datasheets.
Lefty
grandpa
I got mine at digikey for about $4 each.
http://search.digikey.com/scripts/DkSearch/dksus.dll?KeyWords=24c1024
duttydea
I have just got EDB_24XX512 Example working with my  24AA1025.
The problem i'm having is storing Text in the database field.
example:
Id = 1
Date = 24/03/2010
Time = 16:00
Value = 1023
I ether get the first letter of the string or a "0".
I have tried changing
Code: [Select]
struct LogEvent {
 int id;
 int Date;
 int Time;
 int Value;
to
Code: [Select]
struct LogEvent {
 int id;
 char Date;
 char Time;
 char Value;
What am I doing wrong?
Thanks in Advance
Coding Badly
Post the entire Sketch.
duttydea
I have posted the original code with a basic tweak:
Changed the temp from "int" t0 "char"
Code: [Select]
EDB_24XX512.pde
Extended Database Library + 24XX512 EEPROM Demo Sketch
The Extended Database library project page is here:
The E24C1024 library project page is here:
http://www.arduino.cc/playground/Code/I2CEEPROM24C1024
#include "WProgram.h"
#include <EDB.h>
#include <E24C1024.h>
// Use the 24XX512 EEPROM as storage
#include <Wire.h>
#include <E24C1024.h> // Should be compatible with 24XX512 series in this instance
// From the 24XX512 datasheet:
// The Chip Select bits A2, A1 and A0 can be used to expand the
// contiguous address space for up to 4 Mbit by adding up to eight
// 24XX512 devices on the same bus.
// So, each device must be have their address pins wired as listed below to
// create a single, contiguous address space across one or more devices.
// Example - 1 device:
// Device connections: A0->GND, A1->GND, A2->GND
// Uncomment only the #define TABLE_SIZE 65536 line below.
// Example - 3 devices:
// Device 1 connections: A0->GND, A1->GND, A2->GND
// Device 2 connections: A0->GND, A1->+5V, A2->GND
// Device 3 connections: A0->+5V, A1->+5V, A2->GND
// Uncomment only the #define TABLE_SIZE 196608 line below.
// Uncomment the ONE line appropriate for your platform.
//#define TABLE_SIZE 65536 // 1 device: A0->GND, A1->GND, A2->GND
//#define TABLE_SIZE 131072 // 2 devices: A0->+5V, A1->1, A2->GND
//#define TABLE_SIZE 196608 // 3 devices: A0->GND, A1->+5V, A2->GND
//#define TABLE_SIZE 262144 // 4 devices: A0->+5V, A1->+5V, A2->GND
//#define TABLE_SIZE 327680 // 5 devices: A0->GND, A1->GND, A2->+5V
//#define TABLE_SIZE 393216 // 6 devices: A0->+5V, A1->GND, A2->+5V
//#define TABLE_SIZE 458752 // 7 devices: A0->GND, A1->+5V, A2->+5V
//#define TABLE_SIZE 524288 // 8 devices: A0->+5V, A1->+5V, A2->+5V
// default to the smallest - 1 device
#ifndef TABLE_SIZE
#endif
// The number of demo records that should be created.  This should be less
// than (TABLE_SIZE - sizeof(EDB_Header)) / sizeof(LogEvent).  If it is higher,
// operations will return EDB_OUT_OF_RANGE for all records outside the usable range.
#define RECORDS_TO_CREATE 20
// Arbitrary record definition for this table.
// This should be modified to reflect your record needs.
struct LogEvent {
 int id;
 char temperature;
logEvent;
// Create an EDB object with the appropriate write and read handlers
EDB db(&E24C1024::write, &E24C1024::read);
// Run the demo
 Serial.println("Extended Database Library + 24XX512 EEPROM Demo");
 randomSeed(analogRead(0));
 // create a table with starting address 0
 Serial.print("Creating table...");
// db.create(0, TABLE_SIZE, (unsigned int)sizeof(logEvent));
 db.open(0);
 Serial.println("DONE");
 recordLimit();
 countRecords();
 //createRecords(10);
 countRecords();
 selectAll();
 //countRecords();
 deleteAll();
 countRecords();
void recordLimit()
 Serial.print("Record Limit: ");
 Serial.println(db.limit());
void deleteAll()
 Serial.print("Truncating table...");
 db.clear();
void countRecords()
 Serial.print("Record Count: ");
 Serial.println(db.count());
void createRecords(int num_recs)
 Serial.print("Creating Records...");
 for (int recno = 1; recno <= num_recs; recno++)
   logEvent.id = recno;
   logEvent.temperature = '16:00'; //random(1, 125);
   EDB_Status result = db.appendRec(EDB_REC logEvent);
   if (result != EDB_OK) printError(result);
void selectAll()
 for (int recno = 1; recno <= db.count(); recno++)
   EDB_Status result = db.readRec(recno, EDB_REC logEvent);
   if (result == EDB_OK)
     Serial.print("Recno: "); Serial.print(recno);
     Serial.print(" ID: "); Serial.print(logEvent.id);
     Serial.print(" Temp: "); Serial.println(logEvent.temperature);
   else printError(result);
void printError(EDB_Status err)
 Serial.print("ERROR: ");
 switch (err)
   case EDB_OUT_OF_RANGE:
     Serial.println("Recno out of range");
   case EDB_TABLE_FULL:
     Serial.println("Table full");
   case EDB_OK:
     Serial.println("OK");
   default:
     Serial.println("Unknown Error");
Coding Badly
#21
Mar 24, 2010, 11:13 pm Last Edit: Mar 24, 2010, 11:15 pm by bcook Reason: 1
Got it.
You should start by building an understanding of how strings are stored and manipulated in Arduino (in C).  Declaring a variable "char" provides storage for a single character (or a signed single byte integer).  To store a "string" you have to declare a variable as an array of char.  There is a set of functions for manipulating strings (arrays of char).
This looks helpful...
http://www.arduino.cc/en/Reference/String
duttydea
i have tried every possible datatype:
array, string & int.
no matter how i store the data before saving it to the eeprom i et the same result.
only the first character  is saved.
off to work!! will try again tonight
duttydea
I figured it out:
Database Structure:
Code: [Select]
struct LogEvent {
 int id;
 char name[9]; // allow u to store a 9 Character string
logEvent;
Database Read out:
Code: [Select]
     Serial.print(" Temp: "); Serial.print(logEvent.name[0]); Serial.print(logEvent.name[1]);  Serial.print(logEvent.name[2]);
     Serial.print(logEvent.name[3]); Serial.print(logEvent.name[4]);  Serial.print(logEvent.name[5]);Serial.print(logEvent.name[6]);
    Serial.print(logEvent.name[7]);
     Serial.print(logEvent.name[8]);
thanks for the help!!!!!
PaulS
Serial.print(LogEvent.name); will print the entire array (assuming that it is properly NULL terminated). You don't need to print it one letter at a time.
What happens if there are fewer than 9 (valid) characters in the array?
