Topic: Syncing Timer1 and Timer2 (Read 724 times) previous topic - next topic
HiTekRMD
Hey guys, I'm using all three timers on the arduino and I've successfully synced timer0 and timer1.  I basically 'eyeballed' the syncing by dimming two l.e.d. lights and checking to make sure they were dimming at the same rate.  like i said, timer0 and timer1 are synced.  Now I'm trying to sync timer2 to the other two timers and i'm not getting the results i want.  I know that timer2 uses milliseconds as opposed to microseconds, like the first 2.  I've tried dividing by a 1000 to convert millis to micros but its not working.  Does anyone know how to get timer 2 counting in microseconds instead of milliseconds?
thanks yall
udoklein
The datasheet contains everything you might want to learn about timers:
http://www.atmel.com/dyn/resources/prod_documents/doc2545.pdf
Have a look at  16.1.1 and 17.11.9 "GTCCR"
So I would try
// stop prescalers
GTCCR = 1 << TSM;
GTCCR = 1 << TSM | 1 << PSRASY | 1 << PSRSYNC;
ensure here that all timers have matching prescalers and settings
// go
GTCCR = 0;
