Topic: Library for DS1307 Real Time Clock (Read 73602 times) previous topic - next topic
Tuckie
does anyone know how to change the sqw output on the ds1307 to a 1hz rate (and make sure its enabled)?  I'm trying to use it as an interrupt for my code, as opposed to making it query the chip each time.
xSmurf
#31
Apr 08, 2008, 05:10 am Last Edit: Apr 08, 2008, 05:11 am by xSmurf Reason: 1
If you only need a reliable source of 1 seconds delays, why not use millis()? Although you will have to check in loop() or modify the interrupt's code (you'll have to search this forum for more on that) to toggle a boolean value every timerCounter%1000 == 0, you'll then know if you've come across a new second when the variable isn't what it last was. This, however implies that nothing that could happen meanwhile would take more than a second. Otherwise you could add a counter to that conditional statement, make sure you don't overlfow the variable though (see the variable types documentation if you're not familiar with this)!
Tuckie
#32
Apr 08, 2008, 05:35 am Last Edit: Apr 08, 2008, 05:48 am by Tuckie Reason: 1
I would rather use the interrupt method as millis has been shown to be unreliable in some instances, and if I have that pin I might as well use it.  Since the pin is open drain, for testing I wired up the negative end of an led to it, then the led to a resistor, and that resistor to 5v+.  All that happens is the led lights up, as opposed to alternating on and off.
So far, my last attempt at setting it looks like this:
#include <Wire.h>
#define DS1307_CTRL_ID B11010000
 delay(300);
 Wire.beginTransmission(DS1307_CTRL_ID);
 Wire.send(0x07);
 Wire.send(B10010011);
 Wire.endTransmission();
edit: I got it working! I just stopped and started the clock around the wire code.  The easiest way I found to do this was simply including ds1307.cpp and doing RTC.stop(); and RTC.start();
Tuckie
#33
Apr 08, 2008, 06:37 am Last Edit: Apr 08, 2008, 06:45 am by Tuckie Reason: 1
for those interested, when I was polling each clock cycle, it was able to run though about 850 times each second.  now that I use the interrupt, its around 151,157 times a second.  I'm sure its even higher if I remove my serial debugging routines.
BroHogan
I've been using this function . . .
Code: [Select]
void Set_Square_Wave(int rate){  // set the square wave output on pin 7 of the DS1307 chip
 rate = rate + 144;                         // add 0x90 (dec 144) to rate
 Wire.beginTransmission(0x68);              // write the control register
 Wire.send(0x07);                           // register address 07H)
 Wire.send(rate);                           // 90H=1Hz, 91H=4kHz, 92H=8kHz, 93H=32kHz
I pass it: "0=1Hz 1=4k 2=8k 3=32k"
"Data is not information, information is not knowledge, knowledge is not understanding, understanding is not wisdom."
~ Clifford Stoll
tferrell
Is anyone else getting weird output like this?
0 0 30 0 4 4 2006
0 0 30 0 4 4 2006
0 0 30 0 4 4 2006
0 0 30 0 4 4 2006
0 0 30 0 4 4 2006
0 0 30 0 4 4 2006
0 0 30 0 4 4 2006
0 0 30 0 4 4 2006
It seems like the clock isn't incrementing at all. It'll just loop that number over and over, even though I physically disconnect the pins.
Any ideas?
tehboii
Whoooo ! You freezed time !
* big respect *
(Sorry sorry, but I just killed my last AC>DC converter, so I've got nothing to do until shops open ^^)
arduinonano
Quote
0 0 30 0 4 4 2006
0 0 30 0 4 4 2006
0 0 30 0 4 4 2006
0 0 30 0 4 4 2006
0 0 30 0 4 4 2006
0 0 30 0 4 4 2006
0 0 30 0 4 4 2006
0 0 30 0 4 4 2006
Any ideas?
Did you ever get this resolved?  I'm experiencing similar problems.
Rafael Quines
Hi. Congratulations Matt.
Can you help me?!? I have the same problem that user arduinonano.
But the difference is my ds1307 increments, only later of 5 or 6 seconds..
I don't now what I need to do...
rafaelquines@gmail.com
http://arduinors.net
http://rafaelquines.com
morrijr
Would it be possible to add support for the other RTCs in the DS13xx series do you think?  I've just got a DS1305 wired up and would like to help make the library (more) comprehensive...  (Note that I've yet to get it to work!)
As far as I can tell, the differences between the 1307 and 1305 are
* the 1307 has a square wave output - the 1305 doesn't
* the 1307 can't use a rechargeable power source; battery backup only - the 1305 can have either
* the 1307 only has a two wire interface (SDA and SCLK) - the 1305 is a three wire interface (SDI, SDO and SCLK) but SDI and SDO can be connected
* the 1307 has no alarms - the 1305 has two
* the 1307 has no power failure out - the 1305 has
* the 1307 has 56 bytes of battery backed RAM - the 1305 has 96 bytes
So, what do folks think?  Will it bloat the library too much?
Thanks for your consideration.
John.
kg4wsv
For simplicity and code space reason, I don't see why we shouldn't just have one library for each.  It may not be super-elegant, but it is pretty simple.
Besides, the 1305 sounds is an SPI.  That's very different than I2C on the peripheral interface side, even if the application interface is similar.
I'd also like to note a small bug in the original DS1307.cpp code.  There's a test for the day of the month that checks for <31, should check for <=31.  It gave me fits while trying to set the clock on July 31.  :)
-j
GekoCH
#41
Aug 08, 2008, 09:45 am Last Edit: Aug 08, 2008, 09:55 am by GekoCH Reason: 1
Hello
Ok I'm a completely noob to I2C. I would like to run just a clock on the Arduino.
So I got he DS1307 but how to wire this thing?
SCL to analog input 5.
SDA to analog input 4.
VBat and GND to the Battery.
And what else? Now i get stuck....
Could you pls help me and I  hope you don't get crazy about this "stupid" question...
Andy
kg4wsv
Connect Vcc to +5, and connect a 32768kHz crystal at X1 and X2.  Ignore SQWOUT.
That Vbat to ground is very important - Vbat must be connected to ground or a battery or the clock doesn't tick.  Of course, if you don't have a battery, your clock forgets what time it is whenever it loses power.
Then use the code from the first few posts in this thread and you're ticking away.
-j
GekoCH
Hmm ok so I checked the Crystal but I got two. Do both work?
https://www.distrelec.com/distrelec/datasheets.nsf/WebAttachments/1F9E989B5F6E3D15C12573FC0030C2CB/$File/AURIS_Uhrenquarz_Datasheet_EN.pdf
Andy
kg4wsv
That datasheet is for the same xtal, just in two different packages.
But yeah, that's the correct frequency.
-j
