Topic: Arduino and C# GUI (Read 638 times) previous topic - next topic
terance
Hi to everyone!
I have 5 botooms(1st bottom-move forward,2nd-move back,3d-turn right,4th-turn left,5th-stop moving)
When user presses e.x. 1st bottom ,then robot is moving forwad , when user presses 2nd robot is moving back and so on ... when stopbottom is pressed - robot stops
I'm interesting in developing application ,which implements this logic. I've wrote simple code , but I think it doest work properly.
Code: [Select]
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Windows.Forms;
namespace ArduinoProject
   public partial class myForm : Form
       public int cycleNumber;
       void sendCommands(string commandName)
           myTextBox.Text += commandName;
       private void selectSycle()
           //for (; ; )
               switch (cycleNumber)
                   default:
                   case 1:
                       sendCommands("moving forward");
                   case 2:
                       sendCommands("turn left");
                   case 3:
                       sendCommands("turn right");
                   case 4:
                       sendCommands("move back");
       public myForm()
           InitializeComponent();
       private void moveForward_Click(object sender, EventArgs e)
           cycleNumber=1;
           selectSycle();
       private void turnLeft_Click(object sender, EventArgs e)
           cycleNumber=2;
           selectSycle();
       private void turnRight_Click(object sender, EventArgs e)
           cycleNumber=3;
           selectSycle();
       private void moveBack_Click(object sender, EventArgs e)
           cycleNumber=4;
           selectSycle();
       private void Pause_Click(object sender, EventArgs e)
any ideas how to improve it?
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
