Loading...
Pages: [1]   Go Down
Author Topic: Pin 11 in this code to generate exact 1kHz pwm?  (Read 1713 times)
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
I found this code in a post - it does generate exactly 1kHz pwm - could somebody point out how to change it for pin 11 - sorry am noob on registers.
Code:
  // configure hardware timer2 to generate a fast PWM on OC2B (Arduino digital pin 3)
  // set pin high on overflow, clear on compare match with OCR2B
  TCCR2A = 0x23;
  TCCR2B = 0x0C;  // select timer2 clock as 16 MHz I/O clock / 64 = 250 kHz
  OCR2A = 249;  // top/overflow value is 249 => produces a 1000 Hz PWM
  pinMode(3, OUTPUT);  // enable the PWM output (you now have a PWM signal on digital pin 3)
  OCR2B = 125;  // set the PWM to 50% duty cycle
float floatr = 1;
  for (int j = 0; j < 1000; j++)
      floatr++;
  OCR2B = 50;  // set the PWM to 20% duty cycle
      floatr++;
  pinMode(3, INPUT);  // turn off the PWM
  //do some stuff;
  pinMode(3, OUTPUT);  // turn the PWM back on
Logged
Pages: [1]   Go Up
Print
Jump to:
