Topic: Aide Arduino Menu LCD MenuBackend (Read 4535 times) previous topic - next topic
infobarquee
j'ai pris ton fichier corrigé "MenuBackend.h" pour le replacer et toujours le même problème
tu as fait quoi exactement?
faut virer ton .h dans la lib, prendre celui que j'ai mis et ca doit rouler après avoir redémarré l'ide.
AUCUNE AIDE PAR MP
infobarquee
que je teste avec la 0.23 la 1.7 aucune erreur de compile chez moi
AUCUNE AIDE PAR MP
infobarquee
je viens d'installer la 1.6.7 et erreur, donc bug de cette version
je vais essayer de trouver pourquoi
en attendant installe une version avant
AUCUNE AIDE PAR MP
adonis17
#18
Feb 03, 2016, 11:54 am Last Edit: Feb 03, 2016, 12:17 pm by adonis17
J'avais la mauvaise version (v1) du MenuBackend.h
La version 1.4 :
Code: [Select]
|| @file MenuBackend.h
|| @version 1.4
|| @author Alexander Brevig
|| @contact alexanderbrevig@gmail.com
|| @contribution Adrian Brzezinski adrb@wp.pl, http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?action=viewprofile;username=vzhang
|| @description
|| | Provide an easy way of making menus
|| @license
|| | This library is free software; you can redistribute it and/or
|| | modify it under the terms of the GNU Lesser General Public
|| | License as published by the Free Software Foundation; version
|| | 2.1 of the License.
|| | This library is distributed in the hope that it will be useful,
|| | but WITHOUT ANY WARRANTY; without even the implied warranty of
|| | MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
|| | Lesser General Public License for more details.
|| | You should have received a copy of the GNU Lesser General Public
|| | License along with this library; if not, write to the Free Software
|| | Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
#ifndef MenuBackend_h
#define MenuBackend_h
A menu item will be a container for an item that is a part of a menu
Each such item has a logical position in the hierarchy as well as a text and maybe a mnemonic shortkey
class MenuItem {
public:
MenuItem(const char* itemName, char shortKey='\0' ) : name(itemName), shortkey(shortKey) {
before = right = after = left = 0;
//void use(){} //update some internal data / statistics
inline const char* getName() const { return name; }
inline const char getShortkey() const { return shortkey; }
inline const bool hasShortkey() const { return (shortkey!='\0'); }
inline void setBack(MenuItem *b) { back = b; }
inline MenuItem* getBack() const { return back; }
inline MenuItem* getBefore() const { return before; }
inline MenuItem* getRight() const { return right; }
inline MenuItem* getAfter() const { return after; }
inline MenuItem* getLeft() const { return left; }
MenuItem *moveBack() { return back; }
MenuItem *moveUp() {
if (before) { before->back = this; }
return before;
MenuItem *moveDown() {
if (after) { after->back = this; }
return after;
MenuItem *moveLeft() {
if (left) { left->back = this; }
return left;
MenuItem *moveRight() {
if (right) { right->back = this; }
return right;
//default vertical menu
MenuItem &add(MenuItem &mi) { return addAfter(mi); }
MenuItem &addBefore(MenuItem &mi) {
mi.after = this;
before = &mi;
if ( !mi.back ) mi.back = back;
return mi;
MenuItem &addRight(MenuItem &mi) {
mi.left = this;
right = &mi;
return mi;
MenuItem &addAfter(MenuItem &mi) {
mi.before = this;
after = &mi;
return mi;
MenuItem &addLeft(MenuItem &mi) {
mi.right = this;
left = &mi;
return mi;
protected:
const char* name;
const char shortkey;
MenuItem *before;
MenuItem *right;
MenuItem *after;
MenuItem *left;
MenuItem *back;
//no dependant inclusion of string or cstring
bool menuTestStrings(const char *a, const char *b) {
while (*a) { if (*a != *b) { return false; } b++; a++; }
return true;
bool operator==(MenuItem &lhs, char* test) {
return menuTestStrings(lhs.getName(),test);
bool operator==(const MenuItem &lhs, char* test) {
bool operator==(MenuItem &lhs, MenuItem &rhs) {
return menuTestStrings(lhs.getName(),rhs.getName());
bool operator==(const MenuItem &lhs, MenuItem &rhs) {
struct MenuChangeEvent {
const MenuItem &from;
const MenuItem &to;
struct MenuUseEvent {
const MenuItem &item;
typedef void (*cb_change)(MenuChangeEvent);
typedef void (*cb_use)(MenuUseEvent);
class MenuBackend {
public:
MenuBackend(cb_use menuUse, cb_change menuChange = 0) : root("MenuRoot") {
current = &root;
cb_menuChange = menuChange;
cb_menuUse = menuUse;
MenuItem &getRoot() {
return root;
MenuItem &getCurrent() {
return *current;
void moveBack() {
setCurrent(current->getBack());
void moveUp() {
setCurrent(current->moveUp());
void moveDown() {
setCurrent(current->moveDown());
void moveLeft() {
setCurrent(current->moveLeft());
void moveRight() {
setCurrent(current->moveRight());
void use(char shortkey)
recursiveSearch(shortkey,&root);
use();
void use() {
//current->use();
if (cb_menuUse) {
MenuUseEvent mue = { *current };
cb_menuUse(mue);
private:
void setCurrent( MenuItem *next ) {
if (next) {
if (cb_menuChange) {
MenuChangeEvent mce = { *current, *next };
(*cb_menuChange)(mce);
current = next;
void foundShortkeyItem(MenuItem *mi) {
mi->setBack(current);
current = mi;
char canSearch(const char shortkey, MenuItem *m) {
if (m==0) { return 0; }
else  {
if (m->getShortkey()==shortkey) {
foundShortkeyItem(m);
return 1;
return -1;
void rSAfter(const char shortkey, MenuItem *m) {
if (canSearch(shortkey,m)!=1) {
rSAfter(shortkey, m->getAfter());
rSRight(shortkey, m->getRight());
rSLeft(shortkey, m->getLeft());
void rSRight(const char shortkey, MenuItem *m) {
rSBefore(shortkey, m->getBefore());
void rSLeft(const char shortkey, MenuItem *m) {
void rSBefore(const char shortkey, MenuItem *m) {
void recursiveSearch(const char shortkey, MenuItem *m) {
MenuItem root;
MenuItem *current;
cb_change cb_menuChange;
cb_use cb_menuUse;
#endif
Je vais test avec la version 1.7 du ide
adonis17
#19
Feb 03, 2016, 01:52 pm Last Edit: Feb 03, 2016, 02:05 pm by adonis17
Merci tout fonctionne!  :)
j'ai juste une dernière question, mon écran lcd est un écran lcd I2C, le schéma de branchement des boutons est adapter pour un lcd normal, je sais pas comment adapter  :smiley-confuse:
le schéma de branchement des boutons :
http://zupimages.net/viewer.php?id=16/05/lc6p.png
kamill
Bonjour,
Les boutons n'ont rien à voir avec l'écran.
Tu peux utiliser le même cablage, bien que personnellement je câblerai les boutons entre la masse et l'entrée en utilisant le pullup interne.
adonis17
benmx
#22
Nov 17, 2016, 10:47 pm Last Edit: Nov 17, 2016, 11:20 pm by benmx
Bonjour,
j'ai le même problème que adonis17, j'ai bien cherché toute la journée et je cale.
J'ai essayé la version 1.4, en rajoutant le code dans le .h
idem pour la V1.0.
En reinstallant IDE/librairie , derniere version et version 1.6.11.
bref, j'ai ces erreurs :
Code: [Select]
Arduino : 1.6.11 (Windows 7), Carte : "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
sketch_nov17a:37: error: 'menuUsed' was not declared in this scope
 MenuBackend menu = MenuBackend(menuUsed,menuChanged);
sketch_nov17a:37: error: 'menuChanged' was not declared in this scope
exit status 1
Je viens de voir qu'il existait arduino.org (j'avais l'habitude de arduino.cc), avec la version 1.7 +
J'ai essayé, et ça n'a pas marché du premier coup avec le nom aléatoire du croquis. J'ai juste enregistrer sous "test" et ça a marché.
bref, merci pour ce post !
