Topic: erro  (Read 5945 times) previous topic - next topic
qwertyasdfgh
podem ajudar-me a perceber qual é o erro e porque
o erro que da é este " pro:10: error: 'FD00FF' was not declared in this scope
pro:11: error: 'FD807F' was not declared in this scope
pro:12: error: 'FD40BF' was not declared in this scope
pro:13: error: 'FD20DF' was not declared in this scope
pro:14: error: 'FDA05F' was not declared in this scope
pro:15: error: 'FD609F' was not declared in this scope
pro:16: error: 'FD10EF' was not declared in this scope
pro:17: error: 'FD906F' was not declared in this scope
pro:18: error: 'FD50AF' was not declared in this scope
pro:19: error: 'FDB04F' was not declared in this scope
pro:20: error: 'FD708F' was not declared in this scope
pro:21: error: 'FD30CF' was not declared in this scope
pro:22: error: 'FD08F7' was not declared in this scope
pro:23: error: 'FD8877' was not declared in this scope
pro:24: error: 'FD48B7' was not declared in this scope
pro:25: error: 'FD28D7' was not declared in this scope
pro:26: error: 'FDA857' was not declared in this scope
pro:27: error: 'FD6897' was not declared in this scope
pro:28: error: 'FD18EF' was not declared in this scope
pro:29: error: 'FD9867' was not declared in this scope
pro:30: error: 'FD58A7' was not declared in this scope
pro.ino: In function 'void loop()':
pro:92: error: case label does not reduce to an integer constant
pro:97: error: case label does not reduce to an integer constant
pro:102: error: case label does not reduce to an integer constant
pro:106: error: case label does not reduce to an integer constant
pro:110: error: case label does not reduce to an integer constant
pro:114: error: case label does not reduce to an integer constant
pro:118: error: case label does not reduce to an integer constant
pro:122: error: case label does not reduce to an integer constant
pro:126: error: case label does not reduce to an integer constant
pro:130: error: case label does not reduce to an integer constant
pro:134: error: case label does not reduce to an integer constant
pro:138: error: case label does not reduce to an integer constant
pro:142: error: case label does not reduce to an integer constant
pro:146: error: case label does not reduce to an integer constant
pro:150: error: case label does not reduce to an integer constant"
AWOL
#1
Feb 03, 2016, 10:36 am Last Edit: Feb 03, 2016, 10:37 am by AWOL
Code: [Select]
Code: [Select]
case 0xFD807F:
case 0xFD40BF:
etc. is my best guess.
Please post the code that caused the error.
"Pete, it's a fool (who) looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
