Author Topic: #defines in the middle of code  (Read 834 times)
Knivsta,Sweden
Low level's cool
In my current project, I have a few #defines in the middle of a sketch, and it seems to work fine. (arduino-0018).
But I've seen posts on the forum indicating that it might be safer to put all #defines at the top. Why is that, and what might happen otherwise?
Phoenix, Arizona USA
Where's the beer?
I'm not sure it really matters, but I am willing to learn otherwise...btw, you really should use the const keyword for constants instead:
http://www.arduino.cc/en/Reference/Define
Also - putting them at the "top" of the code makes it easier for maintenance and debugging...
 smiley
Knivsta,Sweden
Low level's cool
I do. (promise!)  The defines are for things like:
#define num(arr) (sizeof(arr) / sizeof(arr[0]))
and I have them in the middle of the code because they are to be used together with a class defined there.
Seattle, WA USA
Seattle, WA USA
There is a bug, at least in 0017 (and not documented as fixed) in how the pre-processor scans the code for pre-process directives. It apparently stopped looking when the first executable statement was encountered.
Why isn't the class defined in a separate file?
Knivsta,Sweden
Low level's cool
You mean the pre-pre-processor which adds function prototypes?
So as long as I declare functions before they are used, it is possible to have defines anywhere?
Because I don't have any Arduino hardware. I write the code and send it to a friend for testing. It's easier to send one file than several.
Where's the beer?
ZIP file?
Knivsta,Sweden
Low level's cool
ZIP file?
.. would introduce the extra steps of zipping and unzipping, and I'm lazy   smiley-wink
« Last Edit: August 04, 2010, 03:50:40 am by drhex » Logged
UK
Sub-version repo? smiley-wink
Seattle, WA USA
Seattle, WA USA
No, I mean the preprocessor that looks for # statements.
That you define function prototypes means that the pre-pre-processor does not need to. It does not mean that the IDE knows that it doesn't need to call the pre-pre-processor.
I don't know what possible relationship this could have with the bug in the pre-processor, though.
Knivsta,Sweden
Low level's cool
Alright. But isn't that preprocessor a part of the standard c/c++ compiler and thus independent of Arduino?
Seattle, WA USA
Seattle, WA USA
It's part of the acr-gcc compiler, yes.
Knivsta,Sweden
Low level's cool
Forgive me for sounding stupid here, but...   surely there is nothing avr-specific about the #define, #include and #ifdefs handled by the preprocessor. So it ought to be a part of gcc/g++.   Therefore I do not understand why the bug in question is referred to as a "bug in Arduino 0017".
« Last Edit: August 04, 2010, 01:23:34 pm by drhex » Logged
Seattle, WA USA
Seattle, WA USA
The thread I read that discussed the issue said the OP was using Arduino 0017. That is what I based my statement "at least in Arduino 0017" on. It may be more widespread than that. It may have been fixed, or not. I don't know. Or care. I put #defines at the top of the code where they belong.
If you don't, and it works for you to put them in the middle, great. If you put them in the middle, and they don't work, you know what to do about the problem.
