Topic: Use BLE in Central Mode on arduino 101 (Read 10109 times) previous topic - next topic
a_guadalupi
Hi, intel released an experimental central here
https://github.com/01org/corelibs-arduino101/tree/master/libraries/CurieBLE/examples/LEDCentral
Experimental means that APIs will change in the next future since they are not very Arduino style.
Anyway if you want to give them a try remember to flash the new BLE firmware using the BLE flashpack in the release
daa43
Hi a_guadalupi,
The corelibs-arduino101 works well but I'm not able to update the firmware. I tried using the burn boatloader menu but that fails. Any suggestions?
BBato
Any updates on this.? I am not able to compile the code for arduino 101
Just an update to close this topic as solved.
I wrote a basic example code to show how 2x Arduino 101 can communicate with each other. One device acts as a peripheral with a button, and the other as a central with a LED. The button then controls the LED.
https://github.com/BBato/BLE-Genuinos-Example
Hope you find it useful.
maiche2007
Hi BBato: Is there a limitation for the version of the Arduino 101 board? I have tried to load the example code.
Load is fine no issue but for the board load BLE_Button.ino  there is no reaction at all.
 BLEDevice peripheral = BLE.available();
  if ( peripheral )
never return a true. Looks like the board can not find the LED board via BLE.
BR
maiche2007
