I've spent the last couple of days beating my head against a number of problems with the official Ethernet library. There are a variety of problems with the Client code that manifest themselves as connections that fail to close, and the inability to open multiple connections without running into a 35 second delay.
While there were a number of issues I addressed, the primary problem was in the stop() method that is meant to disconnect a connected client. The code was erroneously closing the connection without sending a FIN to gracefully disconnect, and then followed that immediately with a disconnect() which tries to gracefully shutdown with a FIN. This was causing the connection to get stuck in a FIN_WAIT state which made it unavailable for use until the state timed out after 35 seconds.
There were also a few scary opportunities where an array out-of-bounds condition could be triggered if the sketch called some of the client methods out of order. This could have led to memory corruption in the sketch.
There were too many changes to list the parts to patch here, so I'm simply making the revised Client.cpp file available. You can download it from:
*EDIT* Link removed because it is no longer valid *EDIT*
NOTE! This code is based on the Ethernet library included with Arduino-0015. Compatibility with previous versions is unknown.There are a lot of comments detailing the changes included in the code.
Simply replace (after you back up) the Client.cpp file in your Ethernet library (hardware/libraries/Ethernet).
Be sure to delete the old Client.o file or the code won't recompile.
Here's a sample sketch that demonstrates the improved client code by making 50 connections to a webserver as quickly as possible. Be sure to update the ip[] and server[] with addresses that are appropriate for you.
// Sample sketch to demonstrate the fixes to the Ethernet library Client
// Connect to a webserver 50 times as quickly as possible and read the resulting page
#include <Ethernet.h>
byte ip[] = { xxx, xxx, xxx, xxx };
byte server[] = {yyy, yyy, yyy, yyy };
uint8_t connectStatus;
uint8_t closeStatus;
int ignore;
Client client(server, 80);
Ethernet.begin(mac, ip);
for (int i=1; i<=50; i++) {
Serial.print("Connection Attempt ");
Serial.print(i, DEC);
ConnectToWebserver();
delay(1);
// Enter an infinite loop to "stop" the sketch
while (true);
void ConnectToWebserver(){
if (client.connect()) {
Serial.print(" - Connected");
// Send the HTTP GET to the server
client.println("GET / HTTP/1.0");
client.println();
// Read the response
Serial.print(" - ");
Serial.print(ReadResponse(), DEC);
Serial.println(" bytes received");
// Disconnect from the server
client.flush();
client.stop();
// Connection failed
Serial.println(" - CONNECTION FAILED!");
int ReadResponse(){
int totalBytes=0;
unsigned long startTime = millis();
// First wait up to 5 seconds for the server to return some data.
// If we don't have this initial timeout period we might try to
// read the data "too quickly" before the server can generate the
// response to the request
while ((!client.available()) && ((millis() - startTime ) < 5000));
while (client.available()) {
char c = client.read();
totalBytes+=1;
return totalBytes;
I've successfully tested a run of 5000 consecutive connections successfully so the code appears solid. The only thing I've noticed is an occasional failure to connect on the initial attempt. I think this might be related to a reset and how quickly you start trying to make connections. The reality is you need to write your code to be "tolerant" of failed connections. Connection failures happen in the real world - even in a controlled environment with a local web server.
Another common mistake I see in peoples' code is not allowing time for the server to generate a response before attempting to read from the client. Sometimes web servers take time to respond. They almost always take longer than the time it takes the MCU to execute the few lines of code people typically have between their connect() and read()'s. The example sketch demonstrates how to wait for response with a timeout.
Let me know how testing goes.
