Topic: brilldea polkadot51 (Read 610 times) previous topic - next topic
seenu@SDC
hi,
I want to control daisy chained polkadot51s. Can any one suggest me to write the code for it ?
http://www.brilldea.com/product_PolkaDOT51.html
The following code can control one polkadot51
int datapin  = 10; // DI
int latchpin = 11; // LI
int enablepin = 12; // EI
int clockpin = 13; // CI
unsigned long SB_CommandPacket;
int SB_CommandMode;
int SB_BlueCommand;
int SB_RedCommand;
int SB_GreenCommand;
  pinMode(datapin, OUTPUT);
  pinMode(latchpin, OUTPUT);
  pinMode(enablepin, OUTPUT);
  pinMode(clockpin, OUTPUT);
  digitalWrite(latchpin, LOW);
  digitalWrite(enablepin, LOW);
void SB_SendPacket() {
  SB_CommandPacket = SB_CommandMode & B11;
  SB_CommandPacket = (SB_CommandPacket << 10)  | (SB_BlueCommand & 1023);
  SB_CommandPacket = (SB_CommandPacket << 10)  | (SB_RedCommand & 1023);
  SB_CommandPacket = (SB_CommandPacket << 10)  | (SB_GreenCommand & 1023);
  shiftOut(datapin, clockpin, MSBFIRST, SB_CommandPacket >> 24);
  shiftOut(datapin, clockpin, MSBFIRST, SB_CommandPacket >> 16);
  shiftOut(datapin, clockpin, MSBFIRST, SB_CommandPacket >> 8);
  shiftOut(datapin, clockpin, MSBFIRST, SB_CommandPacket);
  delay(1); // adjustment may be necessary depending on chain length
  digitalWrite(latchpin,HIGH); // latch data into registers
  digitalWrite(latchpin,LOW);
  SB_CommandMode = B01; // Write to current control registers
  SB_RedCommand = 127; // Full current
  SB_GreenCommand = 127; // Full current
  SB_BlueCommand = 127; // Full current
  SB_SendPacket();
  SB_CommandMode = B00; // Write to PWM control registers
  SB_RedCommand = 1023; // Maximum red
  SB_GreenCommand = 0; // Minimum green
  SB_BlueCommand = 0; // Minimum blue
  SB_SendPacket();
  delay(250);
  SB_RedCommand = 0; // Minimum red
  SB_GreenCommand = 1023; // Maximum green
  SB_SendPacket();
  delay(250);
  SB_BlueCommand = 1023; // Maximum blue
  SB_SendPacket();
  delay(250);
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
