Topic: Questions about Smart Arduino library for debouncing switches and buttons (Read 5495 times) previous topic - next topic
avandalen
Questions about the switch library can be asked in this topic.
See the article here:
Smart Arduino library for debouncing switches and buttons:
Coding Badly
avandalen
Do you have a Project Guidance question?
No, it's meant to collect here all the questions about the swich library.
azeo
swenodor
Nice work, Thank you!
My question is how to modify the .cpp, in order to add a Single-Click feature - this could be very, very useful!
The problem is that the singleClick needs to return a TRUE only when there is a Click && doubleClickPeriod is exired.
I thought it would be quite easy, but since I am new to the Arduino I didn't get it to work.
Cheers!
avandalen
Use pushed() for the Single-Click feature.
swenodor
The thing is that pushed() is good when you want to get just the Single-Click. But if you want your button to do one thing on Single-Click, and something different on a Double-Click - that's not an option - Double-Click will be made up from two Single-Clicks, and this would mess things up.
Of course, you can always fix this in the void loop() with some code, but having a singleClick() function is very handy.
Fortunately, I managed to get things working now - and given my coding skills, this should be considered a miracle :)
Here's the code:
(you need to modify the Switch.cpp & Switch.h with the lines commented with '// ADDED' or '// REPLACE' below, most of the code is omitted)
Code: [Select]
/* --------------------------------------------Switch.cpp------------------------------------------------ */
bool Switch::process()
{ singleClickFlag(); // ADDED these two functions
  calcSingleClick(); // ADDED these two functions
void inline Switch::calcDoubleClick()
{ _doubleClick = false;
  if(_switched && !(debounced^polarity))
  { _doubleClick = (ms - pushedTime) < doubleClickPeriod; // pushedTime of previous push
    dcFlag = (ms - pushedTime) < doubleClickPeriod; // ADDED flag for double-click
pushedTime = ms;
scFlag = false; // ADDED flag for single-click, nullify on push
lpFlag = false; // ADDED flag for long-press, nullify on push
void inline Switch::calcLongPress()
{ _longPress = false;
  if(!longPressDisable)
  { _longPress = on() && ((ms - pushedTime) > longPressPeriod); // true just one time between polls
longPressDisable = _longPress; // will be reset at next switch
  else lpFlag=true; // ADDED condition to flag a long-press
//============================================================ ADDED the two functions below
void inline Switch::singleClickFlag()
  if(_switched && (debounced^polarity)) scFlag=true; //on release, flag for singleClick action
void inline Switch::calcSingleClick()
{ _singleClick = false;
  if(scFlag && !dcFlag && !lpFlag) // conditions for singleClick
_singleClick = (ms - pushedTime) >= doubleClickPeriod; //produce a single click once the doubleClickPeriod is expired
scFlag=!_singleClick; //break to exit
bool Switch::singleClick()
{ return _singleClick;
/* ------------------------------------------end of Switch.cpp------------------------------------------------ */
/* ------------------------------------------begining of Switch.h--------------------------------------------- */
public:
  bool singleClick(); // ADDED singleClick definition
 protected:
  void inline calcSingleClick(); // ADDED
  void inline singleClickFlag(); // ADDED
//============================================================REPLACE the line below
  bool input, lastInput, equal, deglitched, debounced, _switched, _longPress, longPressDisable, _doubleClick, _singleClick, dcFlag, lpFlag, scFlag;
//============================================================that's it
/* ------------------------------------------end of Switch.h--------------------------------------------- */
avandalen
Note that a doubleClick() always will be preceded by pushed() from the first push. This can't be avoided, because then the pushed() function would have to wait on a possible second click, which would introduce an annoying delay. So, the action on doubleClick() has to undone the previous action on pushed().
blackketter
I really like the Switch library, thanks for creating it!
Will you be publishing it on GitHub?  If not, I'd be happy to do it.
Thanks!
-dean
avandalen
Thanks!
-dean
Yes, if you can do that for me!
blackketter
Ah, I never got notified of your response!
I've uploaded the library here: https://github.com/blackketter/Switch
Let me know if you have any issues...
cesart050892
cesart050892@gmail.com
Github - cesart050892
distelg
Hello, excellent library. Congratulations ..!!
I want check 4 similar buttons.
The abbreviated code:
Switch ButtonMODE = Switch(PinMODE);
Switch ButtonDOWN = Switch(PinDOWN);
Switch ButtonSET  = Switch(PinSET);
Switch ButtonUP   = Switch(PinUP);
but I don't want write
 /*** CHECK BUTTON MODE ***/
 ButtonMODE.poll();
 if (ButtonMODE.pushed())
 /*** CHECK BUTTON DOWN ***/
 ButtonDOWN.poll();
 if (ButtonDOWN.pushed())
 /*** CHECK BUTTON SET ***/
 ButtonSET.poll();
 if (ButtonSET.pushed())
 /*** CHECK BUTTON UP ***/
 ButtonUP.poll();
 if (ButtonUP.pushed())
I want use 'for', for example:
for(x=0;x<=3; x++)
 /*** CHECK BUTTON x ***/
 Buttonx.poll();
 if (Buttonx.pushed())
Sorry, but I donĀ“t know C++
Thanks very much ..!!
Brittond14
distelg
Thanks Brittond14
Here is my abbreviated code:
Code: [Select]
#define BUTTON_A 22
#define BUTTON_B 23
#define BUTTON_A 24
#define BUTTON_C 25
Switch Button[CANT_BUTTONS] =
  Switch(BUTTON_A, INPUT_PULLUP, LOW),
  Switch(BUTTON_B, INPUT_PULLUP, LOW),
  Switch(BUTTON_C, INPUT_PULLUP, LOW),
  Switch(BUTTON_D, INPUT_PULLUP, LOW)
   for(byte f = 0; f < CANT_BUTTONS; f++)
      Button[f].poll();
      if (Button[f].pushed())
