Pages: [1] 2   Go Down
Author Topic: Arduino control the 2.4" TFT LCD  (Read 4921 times)
Useing the 2.4 inch TFT LCD , which is used ILI9325 controller ,  65K color , 320*240 (resolution).
Connect the pins to Arduino
DB0-DB16 to pin D0-D13 , pin A0-A1 of Arduino
RESET to A2
CS to A3
WR to A4
RS to A5
Use the 16 bit data bus which is 2 timer faster than 8 bit. but it used up all the pins of the Arduino.
#define LCD_RS 19
#define LCD_REST 16
#define LCD_WR 18
#define LCD_CS 17
void main_Write_COM(int DH)
 Â unsigned char i;
 Â int temp;
 Â digitalWrite(LCD_RS,LOW);
 Â digitalWrite(LCD_CS,LOW);
 Â for(i=0;i<16;i++)
 Â {
 Â   temp=(DH&0x01);
 Â   if(temp)
      digitalWrite(i,HIGH);
 Â   else
      digitalWrite(i,LOW);
 Â   DH=DH>>1;
 Â }
 Â digitalWrite(LCD_WR,LOW);
 Â digitalWrite(LCD_WR,HIGH);
 Â digitalWrite(LCD_CS,HIGH);
void main_Write_DATA(int DH)
 Â unsigned char i;
 Â int temp;
 Â digitalWrite(LCD_RS,HIGH);
 Â for(i=0;<16;i++)
 Â {
 Â   temp=(DH&;0x01);
 Â   if(temp)
 Â   else
 Â   DH=DH>>1;
 Â }
void main_W_com_data(int com1,int dat1)
 Â main_Write_COM(com1);
 Â main_Write_DATA(dat1);
void address_set(unsigned int x1,unsigned int y1,unsigned int x2,unsigned int y2)
 Â main_W_com_data(0x0002,x1>>8);     // Column address start2
 Â main_W_com_data(0x0003,x1);    // Column address start1
 Â main_W_com_data(0x0004,x2>>8);     // Column address end2
 Â main_W_com_data(0x0005,x2);    // Column address end1
 Â main_W_com_data(0x0006,y1>>8);     // Row address start2
 Â main_W_com_data(0x0007,y1);    // Row address start1
 Â main_W_com_data(0x0008,y2>>8);     // Row address end2
 Â main_W_com_data(0x0009,y2);    // Row address end1
 Â main_Write_COM(0x0022);
void main_init(void)
 Â digitalWrite(LCD_REST,HIGH);
 Â delay(5);
 Â digitalWrite(LCD_REST,LOW);
 Â delay(10);
 Â delay(20);
 Â //  VENDOR
 Â main_W_com_data(0x0046,0x00A4);
 Â main_W_com_data(0x0047,0x0053);
 Â main_W_com_data(0x0048,0x0000);
 Â main_W_com_data(0x0049,0x0044);
 Â main_W_com_data(0x004a,0x0004);
 Â main_W_com_data(0x004b,0x0067);
 Â main_W_com_data(0x004c,0x0033);
 Â main_W_com_data(0x004d,0x0077);
 Â main_W_com_data(0x004e,0x0012);
 Â main_W_com_data(0x004f,0x004C);
 Â main_W_com_data(0x0050,0x0046);
 Â main_W_com_data(0x0051,0x0044);
 Â //240x320 window setting
 Â main_W_com_data(0x0002,0x0000); // Column address start2
 Â main_W_com_data(0x0003,0x0000); // Column address start1
 Â main_W_com_data(0x0004,0x0000); // Column address end2
 Â main_W_com_data(0x0005,0x00ef); // Column address end1
 Â main_W_com_data(0x0006,0x0000); // Row address start2
 Â main_W_com_data(0x0007,0x0000); // Row address start1
 Â main_W_com_data(0x0008,0x0001); // Row address end2
 Â main_W_com_data(0x0009,0x003f); // Row address end1
 Â // Display Setting
 Â main_W_com_data(0x0001,0x0006); // IDMON=0, INVON=1, NORON=1, PTLON=0
 Â main_W_com_data(0x0016,0x00C8); // MY=0, MX=0, MV=0, ML=1, BGR=0, TEON=0   0048
 Â main_W_com_data(0x0023,0x0095); // N_DC=1001 0101
 Â main_W_com_data(0x0024,0x0095); // PI_DC=1001 0101
 Â main_W_com_data(0x0025,0x00FF); // I_DC=1111 1111
 Â main_W_com_data(0x0027,0x0002); // N_BP=0000 0010
 Â main_W_com_data(0x0028,0x0002); // N_FP=0000 0010
 Â main_W_com_data(0x0029,0x0002); // PI_BP=0000 0010
 Â main_W_com_data(0x002a,0x0002); // PI_FP=0000 0010
 Â main_W_com_data(0x002C,0x0002); // I_BP=0000 0010
 Â main_W_com_data(0x002d,0x0002); // I_FP=0000 0010
 Â main_W_com_data(0x003a,0x0001); // N_RTN=0000, N_NW=001    0001
 Â main_W_com_data(0x003b,0x0000); // P_RTN=0000, P_NW=001
 Â main_W_com_data(0x003c,0x00f0); // I_RTN=1111, I_NW=000
 Â main_W_com_data(0x003d,0x0000); // DIV=00
 Â delay(1);
 Â main_W_com_data(0x0035,0x0038); // EQS=38h
 Â main_W_com_data(0x0036,0x0078); // EQP=78h
 Â main_W_com_data(0x003E,0x0038); // SON=38h
 Â main_W_com_data(0x0040,0x000F); // GDON=0Fh
 Â main_W_com_data(0x0041,0x00F0); // GDOFF
 Â // Power Supply Setting
 Â main_W_com_data(0x0019,0x0049); // CADJ=0100, CUADJ=100, OSD_EN=1 ,60Hz
 Â main_W_com_data(0x0093,0x000F); // RADJ=1111, 100%
 Â delay(1);
 Â main_W_com_data(0x0020,0x0040); // BT=0100
 Â main_W_com_data(0x001D,0x0007); // VC1=111   0007
 Â main_W_com_data(0x001E,0x0000); // VC3=000
 Â main_W_com_data(0x001F,0x0004); // VRH=0011
 Â //VCOM SETTING
 Â main_W_com_data(0x0044,0x004D); // VCM=101 0000  4D
 Â main_W_com_data(0x0045,0x000E); // VDV=1 0001   0011
 Â delay(1);
 Â main_W_com_data(0x001C,0x0004); // AP=100
 Â delay(2);
 Â main_W_com_data(0x001B,0x0018); // GASENB=0, PON=0, DK=1, XDK=0, VLCD_TRI=0, STB=0
 Â delay(1);
 Â main_W_com_data(0x001B,0x0010); // GASENB=0, PON=1, DK=0, XDK=0, VLCD_TRI=0, STB=0
 Â delay(1);
 Â main_W_com_data(0x0043,0x0080); //set VCOMG=1
 Â delay(2);
 Â // Display ON Setting
 Â main_W_com_data(0x0090,0x007F); // SAP=0111 1111
 Â main_W_com_data(0x0026,0x0004); //GON=0, DTE=0, D=01
 Â delay(1);
 Â main_W_com_data(0x0026,0x0024); //GON=1, DTE=0, D=01
 Â main_W_com_data(0x0026,0x002C); //GON=1, DTE=0, D=11
 Â delay(1);
 Â main_W_com_data(0x0026,0x003C); //GON=1, DTE=1, D=11
 Â // INTERNAL REGISTER SETTING
 Â main_W_com_data(0x0057,0x0002); // TEST_Mode=1: into TEST mode
 Â main_W_com_data(0x0095,0x0001); // SET DISPLAY CLOCK AND PUMPING CLOCK TO SYNCHRONIZE
 Â main_W_com_data(0x0057,0x0000); // TEST_Mode=0: exit TEST mode
 Â //main_W_com_data(0x0021,0x0000);
void Pant(unsigned int color)
 Â int i,j;
 Â address_set(0,0,239,319);
 Â for(i=0;i<320;i++)
 Â {
 Â   for (j=0;j<240;j++)
 Â   {
      main_Write_DATA(color);
 Â   }
 Â }
 Â unsigned char p;
 Â for(p=0;p<20;p++)
 Â {
 Â   pinMode(p,OUTPUT);
 Â }
 Â main_init();
 Â Pant(0xf800); //Red
 Â delay(1000);
 Â Pant(0X07E0); //Green
 Â delay(1000);
 Â Pant(0x001f); //Blue
 Â delay(1000);
More information about the demo code and the screen :
http://iteadstudio.com/application-note/itdb02-2-4-display-with-arduino
I am going to write a library for this controller , and there are the 2.4 and 3.2 inch LCD use the same controller that can use this library smiley-wink
« Last Edit: May 10, 2010, 09:14:41 pm by ITead » Logged
Itead Studio - Make innovation easier
Seattle, WA USA
Seattle, WA USA
Useing the 2.4 [glow]inch [/glow]TFT LCD
Rats. Going by the thread title, I was hoping to find a LARGE TFT that I could use in a  project.
North Yorkshire, UK
Haha I didn't notice the 2.4 foot in the title!  ;D
Well at least there are a load of these 2.4" displays hanging around now to choose from.
This place looks pretty cheap though. I wonder how much international shipping to UK is...
Mowcius
Left Coast, CA (USA)
Measurement changes behavior
The fact that is uses up every I/O pin on a standard Arduino kind of limits it's application doesn't it?  smiley-wink
Plan on using a Mega board if you are going to the trouble of writing a library for it, otherwise it's kind of useless, no?
Lefty
North Yorkshire, UK
meh
I would use an rDuino LEDhead which is standard arduino form factor but has extra pin pads on the board as it uses an 644 chip smiley
Mowcius
It's a Low-level errors... 2.4“ GLCD  smiley-wink
« Last Edit: May 10, 2010, 09:19:15 pm by ITead » Logged
Plan on using a Mega board if you are going to the trouble of gifwriting a library for it, otherwise it's kind of useless, no?
Arduino really with a pool resources of I/O .. so 16bit will use up all the pins of Arduino , if you want to use the touch and the SD card , then just can choose the 8bit mode -- which more slower than you can imagine  smiley-sad Mega has enough I/O for the LCD ,touch , SDcard even the external flash .
Even in the 16bit mode work in 16M , the refresh rate is not faster than 1 frame per second ... so you can used the arduino to show the UI menu or a static image , but the video beyond its capacity -- STM32 is a good choice, I like the DMA smiley-wink
#define LCD_RS 8
#define LCD_WR 9
#define LCD_CS 10
#define LCD_REST 11
void LCD_Writ_Bus(char VH,char VL)
 Â   unsigned char i,temp,data;
 Â   data=VH;
 Â    for(i=0;i<8;i++)
 Â   {
       temp=(data&0x01);
       if(temp)
       data=data>>1;
 Â   }
 Â   data=VL;
 Â   for(i=0;i<8;i++)
 Â   {
       temp=(data&0x01);
       if(temp)
       data=data>>1;
 Â   }
void LCD_Write_COM(char VH,char VL)
 Â   LCD_Writ_Bus(VH,VL);
void LCD_Write_DATA(char VH,char VL)
void Address_set(unsigned int x1,unsigned int y1,unsigned int x2,unsigned int y2)
 Â   LCD_Write_COM(0x00,0x20);LCD_Write_DATA(x1>>8,x1);
 Â   LCD_Write_COM(0x00,0x21);LCD_Write_DATA(y1>>8,y1);
 Â   LCD_Write_COM(0x00,0x50);LCD_Write_DATA(x1>>8,x1);
 Â   LCD_Write_COM(0x00,0x52);LCD_Write_DATA(y1>>8,y1);
 Â   LCD_Write_COM(0x00,0x51);LCD_Write_DATA(x2>>8,x2);
 Â   LCD_Write_COM(0x00,0x53);LCD_Write_DATA(y2>>8,y2);
 Â   LCD_Write_COM(0x00,0x22);
void LCD_Init(void)
 Â   delay(5);
 Â   delay(5);
 Â   delay(5);
 Â   //************* Start Initial Sequence **********//
 Â   LCD_Write_COM(0x00,0xE5); LCD_Write_DATA(0x78,0xF0); // set SRAM internal timing
 Â   LCD_Write_COM(0x00,0x01); LCD_Write_DATA(0x01,0x00); // set SS and SM bit
 Â   LCD_Write_COM(0x00,0x02); LCD_Write_DATA(0x07,0x00); // set 1 line inversion
 Â   LCD_Write_COM(0x00,0x03); LCD_Write_DATA(0x10,0x30); // set GRAM write direction and BGR=1.
 Â   LCD_Write_COM(0x00,0x04); LCD_Write_DATA(0x00,0x00); // Resize register
 Â   LCD_Write_COM(0x00,0x08); LCD_Write_DATA(0x02,0x07); // set the back porch and front porch
 Â   LCD_Write_COM(0x00,0x09); LCD_Write_DATA(0x00,0x00); // set non-display area refresh cycle ISC[3:0]
 Â   LCD_Write_COM(0x00,0x0A); LCD_Write_DATA(0x00,0x00); // FMARK function
 Â   LCD_Write_COM(0x00,0x0C); LCD_Write_DATA(0x00,0x00); // RGB interface setting
 Â   LCD_Write_COM(0x00,0x0D); LCD_Write_DATA(0x00,0x00); // Frame marker Position
 Â   LCD_Write_COM(0x00,0x0F); LCD_Write_DATA(0x00,0x00); // RGB interface polarity
 Â   //*************Power On sequence ****************//
 Â   LCD_Write_COM(0x00,0x10); LCD_Write_DATA(0x00,0x00); // SAP, BT[3:0], AP, DSTB, SLP, STB
 Â   LCD_Write_COM(0x00,0x11); LCD_Write_DATA(0x00,0x07); // DC1[2:0], DC0[2:0], VC[2:0]
 Â   LCD_Write_COM(0x00,0x12); LCD_Write_DATA(0x00,0x00); // VREG1OUT voltage
 Â   LCD_Write_COM(0x00,0x13); LCD_Write_DATA(0x00,0x00); // VDV[4:0] for VCOM amplitude
 Â   LCD_Write_COM(0x00,0x07); LCD_Write_DATA(0x00,0x01);
 Â   delay(50); // Dis-charge capacitor power voltage
 Â   LCD_Write_COM(0x00,0x10); LCD_Write_DATA(0x10,0x90); // 1490//SAP, BT[3:0], AP, DSTB, SLP, STB
 Â   LCD_Write_COM(0x00,0x11); LCD_Write_DATA(0x02,0x27); // DC1[2:0], DC0[2:0], VC[2:0]
 Â   delay(50); // Delay 50ms
 Â   LCD_Write_COM(0x00,0x12); LCD_Write_DATA(0x00,0x1F); //001C// Internal reference voltage= Vci;
 Â   LCD_Write_COM(0x00,0x13); LCD_Write_DATA(0x15,0x00); //0x1000//1400   Set VDV[4:0] for VCOM amplitude  1A00
 Â   LCD_Write_COM(0x00,0x29); LCD_Write_DATA(0x00,0x27); //0x0012 //001a  Set VCM[5:0] for VCOMH  //0x0025  0034
 Â   LCD_Write_COM(0x00,0x2B); LCD_Write_DATA(0x00,0x0D); // Set Frame Rate   000C
 Â   LCD_Write_COM(0x00,0x20); LCD_Write_DATA(0x00,0x00); // GRAM horizontal Address
 Â   LCD_Write_COM(0x00,0x21); LCD_Write_DATA(0x00,0x00); // GRAM Vertical Address
 Â   // ----------- Adjust the Gamma Curve ----------//
 Â   LCD_Write_COM(0x00,0x30); LCD_Write_DATA(0x00,0x00);
 Â   LCD_Write_COM(0x00,0x31); LCD_Write_DATA(0x07,0x07);
 Â   LCD_Write_COM(0x00,0x32); LCD_Write_DATA(0x03,0x07);
 Â   LCD_Write_COM(0x00,0x35); LCD_Write_DATA(0x02,0x00);
 Â   LCD_Write_COM(0x00,0x36); LCD_Write_DATA(0x00,0x08);//0207
 Â   LCD_Write_COM(0x00,0x37); LCD_Write_DATA(0x00,0x04);//0306
 Â   LCD_Write_COM(0x00,0x38); LCD_Write_DATA(0x00,0x00);//0102
 Â   LCD_Write_COM(0x00,0x39); LCD_Write_DATA(0x07,0x07);//0707
 Â   LCD_Write_COM(0x00,0x3C); LCD_Write_DATA(0x00,0x02);//0702
 Â   LCD_Write_COM(0x00,0x3D); LCD_Write_DATA(0x1D,0x04);//1604
 Â
 Â   //------------------ Set GRAM area ---------------//
 Â   LCD_Write_COM(0x00,0x50); LCD_Write_DATA(0x00,0x00); // Horizontal GRAM Start Address
 Â   LCD_Write_COM(0x00,0x51); LCD_Write_DATA(0x00,0xEF); // Horizontal GRAM End Address
 Â   LCD_Write_COM(0x00,0x52); LCD_Write_DATA(0x00,0x00); // Vertical GRAM Start Address
 Â   LCD_Write_COM(0x00,0x53); LCD_Write_DATA(0x01,0x3F); // Vertical GRAM Start Address
 Â   LCD_Write_COM(0x00,0x60); LCD_Write_DATA(0xA7,0x00); // Gate Scan Line
 Â   LCD_Write_COM(0x00,0x61); LCD_Write_DATA(0x00,0x01); // NDL,VLE, REV
 Â   LCD_Write_COM(0x00,0x6A); LCD_Write_DATA(0x00,0x00); // set scrolling line
 Â   //-------------- Partial Display Control ---------//
 Â   LCD_Write_COM(0x00,0x80); LCD_Write_DATA(0x00,0x00);
 Â   LCD_Write_COM(0x00,0x81); LCD_Write_DATA(0x00,0x00);
 Â   LCD_Write_COM(0x00,0x82); LCD_Write_DATA(0x00,0x00);
 Â   LCD_Write_COM(0x00,0x83); LCD_Write_DATA(0x00,0x00);
 Â   LCD_Write_COM(0x00,0x84); LCD_Write_DATA(0x00,0x00);
 Â   LCD_Write_COM(0x00,0x85); LCD_Write_DATA(0x00,0x00);
 Â   //-------------- Panel Control -------------------//
 Â   LCD_Write_COM(0x00,0x90); LCD_Write_DATA(0x00,0x10);
 Â   LCD_Write_COM(0x00,0x92); LCD_Write_DATA(0x06,0x00);
 Â   LCD_Write_COM(0x00,0x07); LCD_Write_DATA(0x01,0x33); // 262K color and display ON
void Pant(char VH,char VL)
 Â   int i,j;
 Â   Address_set(0,0,240,320);
 Â    {
      for (j=0;j<240;j++)
             LCD_Write_DATA(VH,VL);
 Â unsigned char p;
 Â int i,j,k;
 Â for(p=0;p<20;p++)
 Â {
 Â }
 Â
 Â   LCD_Init();
 Â
 Â  Pant(0xf8,0x00);
 Â  delay(1000);
 Â  Pant(0x07,0xE0);
 Â  delay(1000);
 Â  Pant(0x00,0x1f);
 Â  delay(1000);
 Â
The code for 8 bit mode~ connect the DB9-DB16 to the Arduino D0-D7 . pull the DB1-DB8 to GND.
The same effect as the 16bit mode , but slower than 16bit mode , if you use the 8M 3.3V Arduino Pro , about 3 seconds one frame.... but now you have the pins for SD card and the Touch.
« Last Edit: May 11, 2010, 06:58:20 am by ITead » Logged
Update :
now we release a library for the 2.4"LCD module , now the beta version just support the LCD display and not powerful enough ,the V1.0 will include more GUI functions and will support touch screen.
Google Code project :
http://code.google.com/p/itdb02
I'm kinda new, but I can get around.
This is awesome! Nice work! [smiley=thumbsup.gif] It's over $120 less than the liquidware touchscreen slide, even if it is less developed/supported.  smiley
:question I just ordered the 3.2" screen for my own development. You said that one was supported as well with your library, correct? :question
Oslo, Norway
blueblur22: You could also take a look at my libraries for these modules: http://www.henningkarlsen.com/electronics/a_l_itdb02_graph16.php
/Henning
Looks interesting. I'll give this one a try when the screen shows up in the mail. Thanks!
EDIT:
Wait... no support for the SD and the Flash? I will be needing both of these for my project as i need to use many graphics. Large storage will be needed. Any way to make this happen? Does anybody else have another library that supports both?
« Last Edit: October 24, 2010, 11:53:45 pm by blueblur22 » Logged
North Yorkshire, UK
Not really unless you switch to a Mega. The arduino does not really have the resources.
Sorry, I thought I mentioned it. I am using the Mega1280. Forgot that bit.
Oslo, Norway
I am working on support for the SD as well, but it is a long way away from being finished. My libraries does not stop you from using SD or flash in any way, so you still can use other libraries.
I am not sure if my modules even has flash on them  :-?
/Henning
"As of v2.0 there are NO support for the SD card-slot or Flash-memory."
Since you specificly mentioned there was no support for flash, I only assumed they all had it. What ever. I'm new to Arduino. I have experience for the Dragon board (RS232 chip set) and am basing everything off of that.
I don't know why I assumed I could only use one library Â
Pages: [1] 2   Go Up
