first, thanks for a great library for the tlc5940!
I had no problems getting it to work with 16 leds and using the basic use sketch.
I want to use it for LEDs which draw more current than what the tlc5940 can handle, and after some research here in the forums I found two solutions, either using a mosfet or a NPN transistor.
I decided to go with the NPN solution.
I hooked up 5 high current leds (3W, drawing 700mA each) on the first five channels, and used normal leds for the rest of the channels.
I used a 10k pull-up resistor for each of the high current channels, each channel connected to a tip122 (through a 1k resistor) which again is connected to the led and a constant current regulator (LM317).
The Iref resistor is 2k (so about 20mA current from the tlc5940).
See the schematic for more details.
http://www.bek.no/~hc/downloads/powerled_schematic.pngAs exected the values are reversed so 0 is on and 4095 is off.
I made an extremely simple sketch, first one with only turning on/off channel 0, the first of the high current leds.
The led turned on/off as expected. However, the other channels behaved strangely, going on and off more or less randomly (at least I haven´t found a logic to it yet), often many of them turning on/off at the same time.
When I expanded the sketch to turn on/off all the high current leds in a sequence, they behaved as expected, but again, now and then the other channels behaved strangely.
First I thought the tlc5940 was drawing too much current, but the chip was not hot at all.
Maybe I am missing something obvious in the code?
#include "Tlc5940.h"
Tlc.init();
// I added these two lines to see if it helped, but they didnt make a difference
Tlc.clear();
Tlc.update();
tlcflash(0);
tlcflash(1);
tlcflash(2);
tlcflash(3);
tlcflash(4);
void tlcflash(int tlc) {
Tlc.set(tlc, 0);
Tlc.update();
Tlc.set(tlc, 4095);
Tlc.update();
thanks for any input.
hc
