Pages: 1 ... 16 17 [18]   Go Down
Author Topic: Library for TLC5940 16-channel PWM chip  (Read 12643 times)
ACleone
Im studying your library version "mux" , and I would like to know the kind of modifications I should take into account in order to use it on a generic non-arduino board.
Any advice will be appreciated.
thank you
UK
wewt
Im using the TLC5940 in conjuction with an arduino to fade pairs of leds down a line in a wearables project. I have come across a bizarre problem that occurs after 12 cycles of the LED's fading. After the 12th cycle the sketch seems to crash as all the LED's power on permanently unless you hard reset the arduino. I do not know how to rectify this and have tried many things. Is the buffer becoming full? if so how do i reset it? Here is my code:
#include "Tlc5940.h"
#include "tlc_fades.h"
TLC_CHANNEL_TYPE channel;
boolean resetFades = true;
void setup (){
  /* Call Tlc.init() to setup the tlc.
     You can optionally pass an initial PWM value (0 - 4095) for all channels.*/
  Tlc.init();
void loop () {
  // Tlc.clear();
   channel = 0;
     if (resetFades == true ) {
       resetFades = false;
      uint16_t duration = 900;                                               //fade length
      // Change these for pairs of LEDS
      uint32_t startMillis = millis() + 50;
      uint32_t endMillis = startMillis + duration;
      fadePairs(0,  startMillis, endMillis, duration, 100, 100); //Adjust Brightnesses of the Individual LED's in a pair.
      startMillis = millis() + 300;
      fadePairs(2,  startMillis, endMillis, duration, 200, 200);
      startMillis = millis() + 600;
      fadePairs(4,  startMillis, endMillis, duration, 300, 300);
      // Fade in twos
      //LED 0
      //tlc_addFade(channel, 0, maxValueB, startMillis, endMillis); //fade in
      //tlc_addFade(channel, maxValueB, 0, endMillis, endMillis + duration);// fade out
      //tlc_addFade(channel+1, 0, maxValueR, startMillis, endMillis); //fade in
      //tlc_addFade(channel+1, maxValueR, 0, endMillis, endMillis + duration);// fade out
      Serial.println("resetting");
     int fadesRemaining = tlc_updateFades();
     if (!fadesRemaining){
       // all fades are done
       resetFades = true;
     delay(25);
      Tlc.update();
//Our LED fading function
void fadePairs(TLC_CHANNEL_TYPE channel, int startMillis, int endMillis, int duration, int maxValueR, int maxValueB){
any help would be appreciated . Thanks.
ok first of all, a quick THANK YOU to whomever wrote this wonderful TLC library.
and now, regarding the TLC_FADE_BUFFER_LENGTH issue -
mistergreen: i took your advice and changed the value of that variable to 64 which gave me some more tlc_addfadez, but after ~45 this would stop working. Has anyone solved this issue or worked-around it or hacked something i could use?
thanks!
hello, i take it all back. all is fine and dandy when changing buffer size.
thank you anyways.
Hello
I am new to arduinos and any type of programming but I've been working on a project requiring me to fade 4x16 LEDs off of one arduino (atmega 328). I've played around with the tlc fade code and everything works well unless multiple sets of LEDs are triggered simultaneously. Each "pod" of LEDs goes through two waves of fade up and a fade down after the sensor has been triggered with an exception to stop an existing wave if the sensor is triggered during a previous pulse. I have included my code which I've tried to comment to the best of my abilities. Any advice on coding or my specific problem would be much appreciated. Thanks.
PS. This code shows only two tlcs but i will ultimately be using four.
#include "Tlc5940.h"                                                     //TLC library general
#include "tlc_fades.h"                                                   //TLC library fades
int calibrationTime = 10;                                                //time in seconds for PIR to calibrate
int counter1 = 0;                                                        //counter is the variable for the specific pin on the TLC5940
int counter2 = 0;                                                        //counter is the variable for the specific pin on the TLC5940
uint16_t LEDSpeed1 = 200;                                                //time between each LED
uint16_t LEDSpeed2 = 1000;                                               //time between each LED
uint16_t duration1 = 1600;                                               //duration
uint16_t duration2 = 30000;                                              //duration
uint16_t maxValue = 1000;
uint16_t midValue = 10;                                                   //as counter gets higher max brightness decreases
boolean isFading1 = LOW;
boolean isFading2 = LOW;
const int irInput1 = 6;                                                  //pin for PIR 1
int irState1 = 0;
const int irInput2 = 4;                                                  //pin for PIR 2
int irState2 = 0;
const int sensorDelay = 8000;                                            //time in milliseconds after sensor is toggled high before it will take another reading
uint32_t currentTime1 = 0;                                               //time of the last PIR toggled HIGH
uint32_t currentTime2 = 0;                                               //time of the last PIR toggled HIGH
TLC_CHANNEL_TYPE channel;                                                //TLC code for defining channel
  Tlc.clear();
  Tlc.init();
  pinMode(irInput1, INPUT);
  pinMode(irInput2, INPUT);
  for(int i = 0; i < calibrationTime; i++){
  Tlc.clear();                                                            //clear pins
  isFading1 = LOW;        //set channel to zero
  isFading2 = LOW;
  //sample sensor
  if (millis()>(currentTime1+sensorDelay)){                               //confirm it has been a long enough wait for PIR to take another reading
    irState1 = digitalRead(irInput1);                                     //read PIR
  if (millis()>(currentTime2+sensorDelay)){                               //confirm it has been a long enough wait for PIR to take another reading
    irState2 = digitalRead(irInput2);                                     //read PIR
  // fadeout
  if (tlc_fadeBufferSize < TLC_FADE_BUFFER_LENGTH - 2) {
    if (irState1 == HIGH){                                                  //if pin is high stop the fades and fade all LEDs out before starting waves
      counter1 = 0;
      currentTime1 = millis();
      Tlc.clear();
      tlc_updateFades();
      for (int i = 0; i < 16; i++){                                                 //cycles through channels 0 - 15
        uint16_t stopValue = Tlc.get(i);                              //find the current channel value
        tlc_removeFades(i);                                           //take fade off of that channel
        tlc_updateFades();                                                  //update
        Tlc.set(i, stopValue);                                        //set the channel to previous stop value
        uint16_t duration = (stopValue + 1)*2;                                //set fade duration to stop value plus one so there are no zero duration fades
        uint32_t startMillis = millis();                                    //start fade at current time
        uint32_t endMillis = startMillis + (duration);                      //end fade at current time plus duration
        tlc_addFade(i, stopValue, 0, startMillis, endMillis);         //take fade from previous stop value to zero for the specified duration
        irState1 = LOW;                                                     //reset irState1 LOW
      counter1++;
    if (irState2 == HIGH){                                                  //if pin is high stop the fades and fade all LEDs out before starting waves
      counter2 = 0;
      currentTime2 = millis();
      Tlc.clear();
      tlc_updateFades();
      for (int i = 16; i < 32; i++){
        tlc_removeFades(i);
        tlc_updateFades();
        tlc_updateFades();
        irState2 = LOW;
      counter2++;
  // i s F a d i n g
    if (tlc_isFading(i) == 1){
      isFading1 = HIGH;
      break;
      isFading2 = HIGH;
      break;
  // w a v e 1
    if ((counter1 == 1)&&(irState1 == LOW)&&(isFading1 == LOW)){
      Tlc.clear();
      for (int i = 0; i < 16; i++){                                                //from channel 0 - 15
        uint32_t startMillis1 = millis() + ((LEDSpeed1*(i+1)));               //start time is a function of LEDspeed constant, channel and how many waves have occured
        uint32_t endMillis1 = startMillis1 + (duration1);                       //end time is start time plus duration
        tlc_addFade(i, 0, maxValue, startMillis1, endMillis1);                         //add Fade up
        tlc_addFade(i, maxValue, midValue, endMillis1, endMillis1 + (duration1*4));    //add fade down
        tlc_addFade(i, midValue, (maxValue*.5), endMillis1 + (duration1*4), (endMillis1 + (duration1*4))+duration1);                         //add Fade up
        tlc_addFade(i, (maxValue*.5), 0, (endMillis1 + (duration1*4))+duration1, (endMillis1 + (duration1*4))+duration1 + (duration2));    //add fade down
        irState1 = LOW;                                                        //set IRstate low
      Tlc.clear();
      tlc_updateFades();
      counter1++;
    if ((counter2 == 1)&&(irState2 == LOW)&&(isFading2 == LOW)){
      // Tlc.clear();
        uint32_t startMillis1 = millis() + ((LEDSpeed1*(i-15)));
        tlc_updateFades();
        irState2 = LOW;
      Tlc.clear();
      tlc_updateFades();
      counter2++;
  Tlc.clear();
  tlc_updateFades();
« Last Edit: May 17, 2010, 11:14:40 pm by fabr1cat3d » Logged
Good day all and Hopefully I can be pointed into the correct direction. I tried using the search function but couldn't find exactly what I was looking for.
Currently my friend and I are trying to build a dancing light bar.  We have a RGB LED Strip, some TLC5940NT's and are slowly building this.  We got the TLC Chip via this tutorial to dance standard LED Lights.  However, we wish to move to highscale and do not wish to blow the Arduino.  I am wondering how we can push 12V via the diagram in the tutorial for these chips without hurting the arduino.
We wish to learn as much as we can on our own.  However, we are both Programmers trying to learn all of this.
Check out this link. http://www.ti.com/litv/pdf/slva280
The transistor method is definitely less expensive but a lot more tricky, especially if you have RGB.
Although my guess is you've either fried everything or found a working solution :-P
not yet we kind of shelved it for now.
thanks for the pdf we will see if we can unshelve this and continue with making light goodness smiley
any help will be greatly appreciated.
Leiden, Holland
There were some people mentioning in this thread that they were trying to control small vibrating motors with the TLC5940. Did anyone had any results? I am trying to do the same with some of those that are 2,3 V and 85 mA. I need to hook up 16 of those. Although I can control their intensity-speed when I try to use the fade functions they don't seem to respond.
any ideas??
The most useful functions:
Hello all,
Does someone know if it's possible to use 21 daisy-chained TLC5940 (just daisy-chain, not multiplexing) with an Arduino? All the TLCs would be on the same PCB to avoid too long wires... In the datasheet, TI says that the limit is 40, but what in real life?
Thank you for your answers!
hey a new one here smiley-grin
i wished i get only the half of that informations.
i just recieved the tlc5940 and tried the first examples.
they also worked but i do not really understand how the code works, maybe someone could helf my explain the commandos. :s
After understanding them i want to controle RGBs (like more or less everybody else smiley-wink )but thats shouldn't be your probleme.
i do not have any sample code because everything i tried didnt worked.
So i think i first should start understand the basics of that IC and thats where i nead YOUR help smiley
loooking forward
max
PS: sorry for my english
hi acleone   smiley    i was wondering if with the TLC5940Mux library, can i add more that 8 rows?? if so can you tell how?? plz?? (obviously im a noob so...)
because i want to have like 50 rows...
« Last Edit: November 27, 2010, 05:29:24 pm by narutoxela » Logged
Pages: 1 ... 16 17 [18]   Go Up
