Loading...
Pages: [1]   Go Down
Author Topic: Problem with NeoCat's Twitter Library  (Read 700 times)
London, England
Offline Offline
Edison Member
Go! Go! Arduinoooo !!!
View Profile
WWW
Trying to use NeoCat's Twitter library and it won't compile under 0021
http://www.arduino.cc/playground/Code/TwitterLibrary#Download
Numerous errors:
Code:
/Applications/Arduino.app/Contents/Resources/Java/libraries/EthernetDHCP/EthernetDHCP.cpp:32:42: error: ../Ethernet/utility/types.h: No such file or directory
/Applications/Arduino.app/Contents/Resources/Java/libraries/EthernetDHCP/EthernetDHCP.cpp:34:40: error: ../Ethernet/utility/spi.h: No such file or directory
In file included from /Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/WProgram.h:6,
                 from /Applications/Arduino.app/Contents/Resources/Java/libraries/SPI/SPI.h:15,
                 from /Applications/Arduino.app/Contents/Resources/Java/libraries/EthernetDHCP/../Ethernet/utility/w5100.h:14,
                 from /Applications/Arduino.app/Contents/Resources/Java/libraries/EthernetDHCP/../Ethernet/utility/socket.h:4,
                 from /Applications/Arduino.app/Contents/Resources/Java/libraries/EthernetDHCP/EthernetDHCP.cpp:33:
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../../avr/include/math.h:439: error: expected unqualified-id before 'double'
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../../avr/include/math.h:439: error: expected `)' before 'double'
In file included from /Applications/Arduino.app/Contents/Resources/Java/libraries/SPI/SPI.h:15,
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/WProgram.h:17: error: declaration of C function 'uint16_t makeWord(byte, byte)' conflicts with
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/WProgram.h:16: error: previous declaration 'uint16_t makeWord(uint16_t)' here
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/WProgram.h:27: error: declaration of C function 'long int random(long int)' conflicts with
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../../avr/include/stdlib.h:504: error: previous declaration 'long int random()' here
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/WProgram.h:28: error: declaration of C function 'long int random(long int, long int)' conflicts with
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/WProgram.h:27: error: previous declaration 'long int random(long int)' here
/Applications/Arduino.app/Contents/Resources/Java/libraries/EthernetDHCP/EthernetDHCP.cpp: In member function 'int EthernetDHCPClass::begin(uint8_t*, int)':
/Applications/Arduino.app/Contents/Resources/Java/libraries/EthernetDHCP/EthernetDHCP.cpp:115: error: 'iinchip_init' was not declared in this scope
/Applications/Arduino.app/Contents/Resources/Java/libraries/EthernetDHCP/EthernetDHCP.cpp:116: error: 'setSHAR' was not declared in this scope
/Applications/Arduino.app/Contents/Resources/Java/libraries/EthernetDHCP/EthernetDHCP.cpp:117: error: 'setSIPR' was not declared in this scope
/Applications/Arduino.app/Contents/Resources/Java/libraries/EthernetDHCP/EthernetDHCP.cpp:119: error: 'sysinit' was not declared in this scope
/Applications/Arduino.app/Contents/Resources/Java/libraries/EthernetDHCP/EthernetDHCP.cpp: In member function 'int EthernetDHCPClass::_startDHCPSession()':
/Applications/Arduino.app/Contents/Resources/Java/libraries/EthernetDHCP/EthernetDHCP.cpp:145: error: 'SOCK_CLOSED' was not declared in this scope
/Applications/Arduino.app/Contents/Resources/Java/libraries/EthernetDHCP/EthernetDHCP.cpp:145: error: 'Sn_SR' was not declared in this scope
/Applications/Arduino.app/Contents/Resources/Java/libraries/EthernetDHCP/EthernetDHCP.cpp:145: error: 'IINCHIP_READ' was not declared in this scope
/Applications/Arduino.app/Contents/Resources/Java/libraries/EthernetDHCP/EthernetDHCP.cpp:146: error: 'Sn_MR_UDP' was not declared in this scope
/Applications/Arduino.app/Contents/Resources/Java/libraries/EthernetDHCP/EthernetDHCP.cpp:155: error: 'uint16' was not declared in this scope
/Applications/Arduino.app/Contents/Resources/Java/libraries/EthernetDHCP/EthernetDHCP.cpp:155: error: expected `;' before 'port'
/Applications/Arduino.app/Contents/Resources/Java/libraries/EthernetDHCP/EthernetDHCP.cpp:158: error: 'Sn_DIPR0' was not declared in this scope
/Applications/Arduino.app/Contents/Resources/Java/libraries/EthernetDHCP/EthernetDHCP.cpp:158: error: 'IINCHIP_WRITE' was not declared in this scope
/Applications/Arduino.app/Contents/Resources/Java/libraries/EthernetDHCP/EthernetDHCP.cpp:163: error: 'Sn_DIPR0' was not declared in this scope
/Applications/Arduino.app/Contents/Resources/Java/libraries/EthernetDHCP/EthernetDHCP.cpp:163: error: 'IINCHIP_WRITE' was not declared in this scope
/Applications/Arduino.app/Contents/Resources/Java/libraries/EthernetDHCP/EthernetDHCP.cpp:169: error: 'Sn_DPORT0' was not declared in this scope
/Applications/Arduino.app/Contents/Resources/Java/libraries/EthernetDHCP/EthernetDHCP.cpp:169: error: 'uint8' was not declared in this scope
/Applications/Arduino.app/Contents/Resources/Java/libraries/EthernetDHCP/EthernetDHCP.cpp:169: error: 'port' was not declared in this scope
/Applications/Arduino.app/Contents/Resources/Java/libraries/EthernetDHCP/EthernetDHCP.cpp:169: error: 'IINCHIP_WRITE' was not declared in this scope
/Applications/Arduino.app/Contents/Resources/Java/libraries/EthernetDHCP/EthernetDHCP.cpp: In member function 'int EthernetDHCPClass::_sendDhcpMessage(DhcpMessageType_t)':
/Applications/Arduino.app/Contents/Resources/Java/libraries/EthernetDHCP/EthernetDHCP.cpp:208: error: 'Sn_TX_WR0' was not declared in this scope
/Applications/Arduino.app/Contents/Resources/Java/libraries/EthernetDHCP/EthernetDHCP.cpp:208: error: 'IINCHIP_READ' was not declared in this scope
/Applications/Arduino.app/Contents/Resources/Java/libraries/EthernetDHCP/EthernetDHCP.cpp:234: error: 'vuint8' was not declared in this scope
/Applications/Arduino.app/Contents/Resources/Java/libraries/EthernetDHCP/EthernetDHCP.cpp:234: error: expected primary-expression before ')' token
/Applications/Arduino.app/Contents/Resources/Java/libraries/EthernetDHCP/EthernetDHCP.cpp:234: error: 'write_data' was not declared in this scope
/Applications/Arduino.app/Contents/Resources/Java/libraries/EthernetDHCP/EthernetDHCP.cpp:242: error: expected primary-expression before ')' token
/Applications/Arduino.app/Contents/Resources/Java/libraries/EthernetDHCP/EthernetDHCP.cpp:251: error: expected primary-expression before ')' token
/Applications/Arduino.app/Contents/Resources/Java/libraries/EthernetDHCP/EthernetDHCP.cpp:258: error: expected primary-expression before ')' token
/Applications/Arduino.app/Contents/Resources/Java/libraries/EthernetDHCP/EthernetDHCP.cpp:265: error: expected primary-expression before ')' token
/Applications/Arduino.app/Contents/Resources/Java/libraries/EthernetDHCP/EthernetDHCP.cpp:267: error: expected primary-expression before ')' token
/Applications/Arduino.app/Contents/Resources/Java/libraries/EthernetDHCP/EthernetDHCP.cpp:276: error: expected primary-expression before ')' token
/Applications/Arduino.app/Contents/Resources/Java/libraries/EthernetDHCP/EthernetDHCP.cpp:278: error: expected primary-expression before ')' token
/Applications/Arduino.app/Contents/Resources/Java/libraries/EthernetDHCP/EthernetDHCP.cpp:284: error: expected primary-expression before ')' token
Anyone got this library working in the new IDE yet?
« Last Edit: October 06, 2010, 09:59:04 am by zooto68 » Logged
Liverpool, UK
Offline Offline
Newbie
Arduino rocks
View Profile
WWW
Try adding:
#include <spi.h>
into your sketch.  I haven't moved to 0021 yet myself, but there was discussion about it on the developers mailing list recently and I think that's the required solution.
See http://arduino.cc/pipermail/developers_arduino.cc/2010-September/003249.html for the archive of the discussion.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
That`s not the solution. I added this one automatically and it didn't help.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Same issue with 0021 - which leaves me kind of stuck since I need 0021 to upload to my Uno...
Logged
0
Offline Offline
Newbie
NeoCat.jp
View Profile
EthernetDNS library by georg kaindl ( http://gkaindl.com/software/arduino-ethernet ), which my Twitter Library depends, doesn't support 0021 yet.
I tried porting the EthernetDNS to 0019 or later, for temporal usage until the official version supports newer IDE.
You can get it from http://www.arduino.cc/playground/Code/TwitterLibrary.
« Last Edit: October 24, 2010, 12:47:04 pm by NeoCat » Logged
NeoCat
0
Offline Offline
Newbie
Arduino rocks
View Profile
Thanks NeoCat! Verified working with an Uno and 0021.
Logged
UK
Offline Offline
Newbie
View Profile
WWW
I just seem to get:
Quote
connecting ...
failed : code 403
Any ideas?
Thanks,
Ian
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Did you try to determine what a 403 error code means?
Quote
403 Forbidden
    The request was a legal request, but the server is refusing to respond to it.[2] Unlike a 401 Unauthorized response, authenticating will make no difference.[2]
Logged
UK
Offline Offline
Newbie
View Profile
WWW
But why would the server refuse to respond?
Thanks
Ian
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
The forum is not a money-making operation. As a result, our crystal ball was re-possessed.
If you want help, your really going to have to provide some details and some history.
What have you done to register with the server so that it knows that it SHOULD respond to you? What code are you using to access the server?
Logged
Pages: [1]   Go Up
Print
Jump to:
