Loading...
Pages: 1 [2]   Go Down
Author Topic: How to: soil moisture measurement?  (Read 8752 times)
0
Offline Offline
Sr. Member
Arduino rocks
View Profile
Can't find the link but how far apart do nails need to be? I'll going to make a probe to see the moisture in the garden is getting there.
Logged
Offline Offline
Sr. Member
Arduino rocks
View Profile
Hi Chris,
Not so far. In order to have them at under constant distance, i used an old wall plug connector. So the terminals works such as the nails... They could not go so deep, but it could be used like an "standard".
Take a look to what i did here:
http://ardudrop.jottit.com
In any case, you decide the distance, because it require a calibration by the 10K pot and also by code... Select you distance, and calibrate it to 0% of water and 100% of water in the soil.
I hope it could be useful for you.
Cheers,
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
hi, I want to ask, which is better and more accurate  between the simple circuit and Botanicalls twitter DIY? can somebody help me to make a decision.
Thank You
Logged
Offline Offline
Sr. Member
Arduino rocks
View Profile
Hi Noor Raihan,
I can not say to you exactly which one is better...
In fact, somewhen during next weeks i will try to develop and test this other soil moisture sensor:
http://gardenbot.org/howTo/soilMoisture/
I will report differences with the other sensors that we discussed here...
Cheers,
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Hi madepablo,
I really appreciate your effort to help me. Actually I don't have any experience to do this. I hope I can learn more from this forum. Thanks a lot.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
If I don't want the part for the twitter message, what I've to do to the project so that the result will just appear on the arduino software? Can somebody teach me how to do it.
http://www.botanicalls.com/archived_kits/twitter/
This is the link I refer to.
Thank You.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Is anyone here had an experience in order to build Soil Moisture Sensor? If there any, can u share ur knowledge with me because I never do this kind of project before by using arduino. Actually my project is about to detect the soil moisture by using Vegetronix VG400 Soil Moisture Sensor probes. It will change the analog to digital value so that it can be easily determine the moisture. If the moisture too dry (RED LED blinking), if the moisture wet (GREEN LED blinking) and if the condition of the soil is not too dry and wet (YELLOW LED blinking). I also wanna make an alarm when the moisture too dry. Can somebody help me to figure it. Thank You
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
Quote
You want to make one or buy one? If you want to buy one, go ahead. You have our permission. Not our paypal number or credit card, though.
Quote
Typically, red and yellow indicate problem conditions, and green means good.
Quote
I'd suggest a wave shield with some of these:
http://www.songarea.com/music-codes/dry.html
Quote
What's left to figure out? Just the threshold between too wet/just right and between just right/too dry, and that will depend on the plant(s) you are monitoring.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Thanks for the reply. Actually what I means from the previous post is how to do the coding part. Is there any link which I can refer to?
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
Sure. http://arduino.cc/en/Reference/HomePage
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
thanks a lot  smiley
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
