Topic: Shield detected, but can't find any networks or connect (Read 12233 times) previous topic - next topic
matei1987
I can run the firmware check example and it returns the mac address of the shield, so I know that the board is seeing it. The green power light is also on.
When I run the scan networks example, it doesn't find any and just keeps going with the println's every few seconds. When I try to connect to wifi, I get the attempting to connect notifications, but no success.
I've updated the firmware to 19.4.4, and I've tried running it from the wall, a usb, and batteries all with no luck. The wifi, network, and error leds have never once lit up.
I'm going a little crazy here and I feel like I'm running out of options. Is there anything else I can try before  defaulting to hardware defect? I'd really appreciate any info!
Other details - Mac OSX, IDE 1.6.7, UNO board.
matei1987
Well I emailed customer support last night. Hopefully someone answers that email. $50 dollars well spent /s
Sean1188
same thing man, same situation, tried the same things.
matei1987
I went to a local Microcenter, found the old version of this shield (the one with the SD card), and got it running after a Firmware update.
I really hope they fix my 101 because I'm not eating 60+ dollars with shipping. How's their customer support normally? I haven't heard anything from them and I'm starting to get worried here.
Sean1188
this.
and its the weekend man, aint nobody got time for that.
matei1987
this.
Exactly that. I was so freaking excited to get this in and connect my remote server to my home monitoring and that's all I got. Super disappointed. And the worst part is that I bought the official version from them on purpose, thinking that I'll avoid any issues that way. Lesson learned. Still haven't heard back from them.
JG_225
I too am having this issue... at first my issue was with the compiler, I had to go to an older version of IDE to get the library to compile, and now this!
you said that the original Wifi shield works well?
I am using the Arduino UNO R3... I wonder if the WIFI101 works better with the Ardunio ZERO... can anyone acknowledge this?
Sean1188
If there are no replies to any solutions, I will be returning the module next week.
Matthewholloway10
I am having the same issue.  Did you have any luck returning your shield?
Matthewholloway10
I got mine to work by installing the 0.7.0 version of the library
Phil42
I'm experiencing the exact same phenomenon.  Asking the board to scan networks or open a network causes the example to hit an exception & restart. Can anyone else confirm that installing 0.7.0 of the library is a fix?   Has anyone heard from customer support?  This is ***VERY*** frustrating!
xarvey
jjko
I fixed by following Matthews suggestion and installing 0.7.0 version of the library
JG_225
yes, I to can confirm that going back to 0.7.0 version of the library works, I can now connect and get an IP from my wireless network  using WPA
xarvey
Same here, TIL rollback the version if it doesn't work
