Topic: an alternative arduino ide ? (Read 3295 times) previous topic - next topic
25pinjo15
Hi
first sorry for broken english i'm french canadian from quebec
second sorry i'm a begginer in arduino
So my question is there is a alternative or mod for original ide I should install. I found great site with suggestion but alot are outdated or don't run on win xp
I have a laptop that I only use for my uno and mega . win xp 32 bit 2 go ram . core 2 duo .
I'm looking for something with lot of color to easily track my program since i'm new to c++
and with easy integration of library. maybe auto suggest or other fonctionnality for begginer and ect
Thank you very much and have a nice day
25pinjo15
I have succed to instal eclipse with baeyen. But the indexer is fucktop sometime work work partialy or dosent. I try multiple fix but nothing change. One in baeyen sote tell to go in c++ indexer and add file bit i dont have option to add file
Robin2
#2
Feb 20, 2016, 06:26 pm Last Edit: Feb 20, 2016, 06:27 pm by Robin2
Why not just use the Arduino IDE?
Or do your program editing with a text editor such as Geany which I use.
I think Windoze people use Notepad+
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
25pinjo15
Because i want indexer. Auto suggest and all variable / function listed in a separate windows . Text color ect
Robin2
By the time you have found it you will be sufficiently experienced not to need it  :)
...R
25pinjo15
Well i just make eclipse run . Just sometime i got indexer problem. But work fine. If you got good c++ basic tutorial ill take it . I dont want to copy existing code then modify it .
Robin2
Tutorial about what? - Building an IDE ?
...R
25pinjo15
Robin2
sstaub
Have a look to platformio.org, the IDE based on atom have what you looking for, autocomplete, linter ...
sstaub
taoyuan
Atom with PlatformIO is good option. But I'm prefer to use CLion, and using Arudino-CMake to enable arduino aupport for CLion.
Or a lighter and better option to use iotor with CLion, Atom or any ide/editor that you like.
After initializing, adding or deleting files run
Code: [Select]
# in <project>/build dir
$ cmake ..
When you want to upload:
Code: [Select]
$ make upload
Erel
#11
May 13, 2016, 04:35 pm Last Edit: May 13, 2016, 04:46 pm by Erel
B4R is another, completely free, alternative IDE: http://forum.arduino.cc/index.php?topic=393937.0
V1.00 will be released next week.
