Loading...
Pages: 1 ... 3 4 [5]   Go Down
Author Topic: Problems with 0021 on Ubuntu 10.04 Lucid Lynx  (Read 8504 times)
South Africa
Offline Offline
Newbie
Arduino rocks
View Profile
WWW
w00t! Thank you stimmer!  ;D
I 'bricked' my Uno with one of those example sketches and, following your instructions, I managed to upload the new firmware! smiley-grin
Logged
Offline Offline
Sr. Member
View Profile
The fixed firmwares are now in the latest release of the IDE. So anyone having trouble downloading them from the git repository website should download the 0022 IDE and look in the arduino-0022/hardware/arduino/firmwares/arduino-usbserial directory, the firmwares are in there.
Logged
Oxford, UK
Offline Offline
Newbie
Arduino rocks
View Profile
Updating the 8u2 firmware as per post #34 has fixed the problems I was having with the OneWire library not working on my Uno  smiley
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
I have the same problems with serial.println in linux.
Can anybody translate post 34 for someone who has about 40 flight hours with Linux. It is not very clear what I need to do.
Regards
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
i tried flashing like in post #34
actualy twice but it still behaves like before, unable to upload anything to arduino uno.
checksum of Arduino-usbserial-uno.hex is 8e01ee236e70bbea43f7eb4e11c9688a
this is how i did it with messages from my system opensuse 11.3
sudo dfu-programmer at90usb82 erase
sudo dfu-programmer at90usb82 flash --debug 1 Arduino-usbserial-uno.hex
Validating...
4058 bytes used (99.07%)
sudo dfu-programmer at90usb82 reset
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Vega 77
One quick check - did you unplug the uno after you reflashed it? On my mega2560 it didn't go back to the normal USB ID until I did this
When you've replugged it, what does lsusb report?
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
yes i did unplugg it both times
lsusb:
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 003: ID 0951:1606 Kingston Technology
Bus 001 Device 004: ID 05e3:0505 Genesys Logic, Inc.
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 002: ID 2341:0001
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 002: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
OK, good news - 2341:0001 is an arduino uno or mega2560, so the flash has worked
Now the 8u2 based arduini use the USB modem driver, not the FTDI serial. Run dmesg just after you plug in the uno, and you should see something like
usb 3-1.2: new full speed USB device using uhci_hcd and address 18
cdc_acm 3-1.2:1.0: ttyACM0: USB ACM device
and /dev/ttyACM0 should now exist. If the acm line is missing, run lsmod and look for cdc_acm (the modem driver). If it's not present, you need to build the USB modem driver in your kernel. Try
modprobe -v cdc_acm
anyway, just to check if you have the modules.
One other possibility is the java serial library not looking for ttyACM devices. See reply #56 to make /dev/ttyS7 a symlink to /dev/ttyACM0
In the IDE, with the uno plugged in, what serial ports does it offer you?
I had failures due to a run-away avrdude. Shut down the IDE, and run
ps -ax | fgrep avrdude
Kill all the avrdudes you see, and restart the IDE. Now check the serial ports, and that you've set the board type to Uno. Upload might now work  smiley
Good luck
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
i tried your tips on two diffrent pc's.
And i'm much closer now. Thx man !
one with opensuse 11.2 and one with opensuse 11.3
opensuse 11.3:
had to make a symlink to ttyS8 like this:
ln -s /dev/ttyACM0 /dev/ttyS8
was able tl select a com port then.
But i get this message:
Binary sketch size: 450 bytes (of a 32256 byte maximum)
avrdude: Yikes!  Invalid device signature.
         Double check connections and try again, or use -F to override
         this check.
opensuse 11.2:
no symlink needed, but i needed to rub arduino as root.
but i get this error:
« Last Edit: January 04, 2011, 12:57:17 am by vega77 » Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Reply #34 fixed this for me too. Uno board running 32bit Ubuntu 9.10 Karmic.
Sooo glad I found this thread as I realised that my serial output was blocking upload of new sketch. Had to register on the forum first to be able to access the explanation about grounding pins, but that's great as I wanted to join.
Have now completed my first robot, based on my kid's old "Wacky Wiggler" toy. One motor and one servo, two contact switches. Basic obstacle avoidance. Now working and uploaded sketch, thanks again!!!
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
fired up an old pc and installed winxp  today>smiley-sad
Worked fine to upload sketches then so my arudino uno is working fine.
probably try ubuntu again later on.
For now i will play with my arudino smiley
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
In case it helps anyone: I just updated a few more mega2560, and I noted the USB IDs.
If you have succeeded in entering DFU mode, lsusb will report
03eb:2ff7 Atmel Corp
(Note you do not need to unplug and reconnect to enter DFU, indeed doing so will revert to normal IDs !)
Once flashed, unplugged and reconnected, the mega2560 is
2341:0010
Earlier messages suggest that the Uno is
2341:0001
HTH  8-)
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Quote
got it also working on my mega2560 after some trouble:
- on my debian in standard repository was only dfu-programmer Version 0.4.3. The at90usb82 device was not recognized (dfu-programmer: no device present) , although the device is listed when dfu-programmer is called with no options.
- upgraded to dfu-programmer 0.5.2 from source
reference: [removed - see original post]
Code:
svn co [removed - see original post]
/dfu-programmer dfu-programmer
cd dfu-programmer/trunk/dfu-programmer/
./bootstrap.sh
./configure
make
sudo make install
- dfu-programmer now recognizes the at90usb82
- erased with no error message
- when trying to flash got the message: Something went wrong with creating the memory image
- after some time of troubleshooting I found that the downloaded .hex file was wrong. I don't know why, but it was not possible to download the raw file with epiphany
- downloaded the .hex file with wget, flashed it and it works perfectly.
Smiley Reinhard
I'm using an Uno with Ubuntu 10.04. The USB IDs indicate normal and DFU modes.
I'm experiencing this same problem with dfu-programmer not recognizing the device. I tried downloading the SVN code for v0.5.2 but when I run make, it fails. From the best I can tell, it is not finding usb.h in the src/ directory.
Any ideas? The output of make is below:
Code:
jmazikowski@maz-notebook:~/dfu-programmer/trunk/dfu-programmer$ make
make  all-recursive
make[1]: Entering directory `/home/jmazikowski/dfu-programmer/trunk/dfu-programmer'
Making all in src
make[2]: Entering directory `/home/jmazikowski/dfu-programmer/trunk/dfu-programmer/src'
gcc -DHAVE_CONFIG_H -I. -I..    -Wall -g -O2 -MT main.o -MD -MP -MF .deps/main.Tpo -c -o main.o main.c
main.c:29:17: error: usb.h: No such file or directory
main.c: In function 'main':
main.c:62: warning: implicit declaration of function 'usb_init'
main.c:81: warning: implicit declaration of function 'usb_set_debug'
main.c:110: warning: implicit declaration of function 'usb_release_interface'
main.c:123: warning: implicit declaration of function 'usb_close'
make[2]: *** [main.o] Error 1
make[2]: Leaving directory `/home/jmazikowski/dfu-programmer/trunk/dfu-programmer/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/jmazikowski/dfu-programmer/trunk/dfu-programmer'
make: *** [all] Error 2
« Last Edit: January 12, 2011, 09:07:34 pm by mazikowski » Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Problem solved. Installed libusb-dev (sudo apt-get install libusb-dev) and dfu-programmer v0.5.2 compiled just fine. Flashed the firmware and the serial monitor is working like a charm!
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
I was having the same issue. Post #34 worked like a charm on Ubuntu x64 10.10. Thanks!
Logged
Pages: 1 ... 3 4 [5]   Go Up
Print
Jump to:
