Loading...
Pages: 1 [2]   Go Down
Author Topic: Measurement of Bandgap voltage  (Read 4487 times)
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Cool, something to play with tonight.
So is the purpose of this so that the A/D conversion is performed in a quieter condition then normal non-sleeping condition? I have noticed that on the code I've posted that if I perform just one read of the bandgap voltage it has not settled down to a stable count value. Three reads is OK, within a count or two, and four has the same stable count reading that stays the same no matter how long the function continues. I recall reading in the datasheet about having to perform multiple A/D conversions before obtaining a stable reading, but I thought that was only when changing voltage references, which I'm not doing?
Again thanks for posting the code.
Lefty
« Last Edit: January 15, 2011, 03:03:30 pm by retrolefty » Logged
Global Moderator
Dallas
Online Online
Shannon Member
View Profile
WWW
Quote
Exactly.  I've notice some difference on the ATmega processors.  There seems to be less jitter in the least-significant bit.  I've notice a huge difference on the ATtiny processors.  The values are rather erratic in "polling mode" but rock solid in "noise reduction mode".
Quote
My 168 and 328 processors behave the same way.  The first reading after switching ADMUX to "measure the bandgap" is garbage.
Quote
About the same here.  I usually have a short time delay between readings so, in my case, the readings are stable by the third one.
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
